Question about Refrigerators
I own a ge side by side refrigerator and the food continually ices/frosts-is there a remedy?
    President:
  • 1,304 Answers
If the frost is in the freezer compt i do hope it is, check the ice chute flap its probably stuck open,
beyond that check all your door seals,, even the smallest of gaps can cause problems, this time of year
Posted on Oct 04, 2009
  • 70 Answers
Yes try raising the setting of your thermostat. it's the control located inside the fridge. install a thermometer and try to keep the box temp around 40 degrees fahrenheit.
GE Profile refriderator PSC25MSWA is frosting/icing on bottom of Refriderator side
Try defrosting entire unit. Put all food, freezer and refrigerator sides in coolers with ice. Unplug unit and wait at least 24 hours for unit to completely defrost, if neccessary open doors, plug unit back in and see how unit functions. By doing this lines that carry freon should become unclogged.
May 05, 2014 | GE GSS22SGM Side by Side Refrigerator
I have frost on the freezer side and both the freezer and fridge are not keeping the food / frozen items cold. The fridge seems to be running constantly
remove the rear panel in the freezer,and if evaporator coils a solid block of ice,take a hand held hair dryer and melt the ice,then remove the heater located under the coil and test it for continuity,if open replace it with g.e.# wr51x10055 heater element
Aug 07, 2011 | GE GSL25JFPBS Side by Side Refrigerator
My GE profile refrigerator's ice maker is frosting over at the exit point for the ice leaving the ice bin. I have cleaned it repeatedly and have no clue as to the cause.
The flap door that opens to let ice drop out of the door has a bad seal or the plastic mounting arm is cracked or broken,this is allowing moisture to enter and turn to frost.This will continue to happen until the flap door is repaired,and sealing correctly.
Sep 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Mar 30, 2009 | Refrigerators
FRESH FOOD SIDE OF FRIG NOT COOLING
i would take the back freezer panel off and see what kind of frost pattern your coils have.they may be frosted over and the begining of a defrost problem.
Mar 11, 2009 | GE GSH22KGM Side by Side Refrigerator
Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE fridge: Freezer working but fresh food side not cold
The problem is the refrigeration evaporator, located in the freezer section is blocked with frost and ice and not air can pass through it. Four different failed parts can cause this problem. The defrost timer, the defrost heater safety thermostat, the defrost heater, or the evaporator fan motor. Unless you are very good with a volt-ohm meter, it wiil be difficult to distinguish which one of these parts has failed. A qualifed refrigeration service tech or a good appliance service tech with a refrigeration certification can find this quickly.
Jan 13, 2009 | GE 22.0 Cu. Ft. Side-by-Side Refrigerator...
Ge SIde by side SSS25KFMDWW stopped freezing
number one,is the freezer fan working?2,is there frost forming on the back wall of freezer?let me know more-mike
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side not working
Defrost cycle not functioning. Could be defrost timer, timer motor, or defrost heater. I detailed this for someone else. see other solutions.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
