The agitator does not completely rotate unless you press down on it.
  • 5,911 Answers
If this is a Whirlpool manufactured top loader with a split agitator design, this is commonly caused by worn agitator dogs. The upper portion of the agitator (called the auger) has a cam assembly with small agitator dogs that act as a clutching mechanism to drive the auger during the wash cycle. They wear out over time and need to periodically be replaced. The following link explains what they are and how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link I provided. You can purchase replacements at appliancepartspros.com for about $5. For a little more you can purchase the entire cam replacement kit which includes the dogs, cam, seals and washers.
If you have any questions, please let me know. If this is not a Whirlpool manufactured washer (which includes Kenmore, Roper, Estate, Frigidaire, Kelvinator) please let me know. If you are in doubt, please provide a model number and I can confirm for you. I hope this helps you.
Posted on Oct 04, 2009
How do i replace the agitator in my old heavy duty whirlpool washing machone?
Hello.
The Whirlpool Ultimate Care II washing machine is atop-loading clothes washer. The washer has several cycles to choose from,including cycles for washing normal clothes, permanent press items, delicateand items marked "Hand Wash." To do its job, thewashing machine relies on an agitator, located in the center of the wash tub.The agitator rotates during the wash cycle, moving the clothes around the washtub so that they are cleaned equally. If the agitator is broken, it will notsufficiently agitate the clothes and must be replaced. ·1 Unplug the washing machine from the wall outlet or turn off the power supplyin your service panel. · 2 Open thewashing machine lid and remove any clothes remaining inside. · 3 Remove thefabric softener cup by squeezing the bottom lip of the cup and lifting itstraight off. · 4 Pry theagitator cap off of the top of the agitator with a flat-head screwdriver. · 5 Remove thebolt at the bottom of the agitator, using the socket wrench with extension, andthen remove the agitator from the washing machine. Tip the agitator to removethe bolt and washer. · 6 Install thenew agitator onto the drive shaft. · 7 Secure thenew agitator with the bolt that you originally removed. · 8 Press theagitator cap and fabric softener cup back into position on top of the newagitator. · 9 Restore powerto the washing machine to complete the repair.
Thanks.
Sep 07, 2011 | Whirlpool Washing Machines
How do you fit a blade into a dw933 jigsaw
hi, sorry if the text is a bit small :P Full instructions available here: http://service.dewalt.co.uk/PDMSDocuments/EU/Docs//docpdf/dw933_eur.pdf
Fitting and removing a saw blade (fig. A, B & I)
The DEWALT tool-free system ensures quick and easy changing of saw blades.
• Pull the rotating handle (10) up completely. • Unlock the handle by rotating it as shown. • Insert the saw blade into the blade holder (8)
guiding the back of the blade into the groove of
the guide roller (6). • Turn the rotating handle (10) towards locked
position until a click is heard. • Press the rotating handle halfway down
(freewheeling position) and continue rotating the
handle towards locked position. • Press the handle (10) down completely. • To remove the saw blade proceed in reverse order.
Jan 14, 2011 | Saws
WILL NOT AGITATE, SPIN OR DRAIN. WASHER FILLS WITH WATER, HOWEVER, WHEN AGITATOR CYCLE BEGINS, MOTOR HUMS AND BELT WILL NOT MOVE.
Open the back cover and start the washing cycle. When the agitator cycle begins check if the motor rotates. If it does not and the humming sound comes there is problem is withe motor. Also check the tightness of the belt. Even if it is loose it does move but it is slippery movement unless it is completely loose. Anyway the problem is with your motor and the connecting bearing/pulley. You have to ask a technicians to help you out
Sep 29, 2010 | Washing Machines
My screen has rotated how do i switch it back?
You didn't mention by what degree has it rotated, Is it a 90 degree rotation or a complete 180 degree rotation. Anyways here's the solution to your problem.
Hold down Ctrl+ Alt and then press the Up or the Down arrow key to rotate it by 180 degrees.
OR
Hold down Ctrl+ Alt and then press the left or the right arrow key to rotate it by 90 degrees.
Nov 16, 2009 | Samsung NC10-14GW Notebook
Tub rotates CW during agitation, out of balance, hits side of metal cabinet, but no error code
Hello srcoray,
Did you replace the clutch, just trying to get a feel for your hands on experience with the machine? If you did the work did your machine use the upper roller clutch bearing along with the clutch pulley mounted roller clutch bearing?
The FAV6800AW uses a reversing motor and motor controller that powers the motor and clutch pulley to rotate CW in Wash/Agitate cycle and CCW in Spin Cycle.
In Wash/Agitate cycle the roller clutch bearing should rotate freely CW allowing the agitator shaft to drive the transmission in wash cycle driving the tumblers to rotate only not the wash basket. In spin cycle the roller clutch bearing will lock up (one-way roller clutch bearing) driving the spinner shaft to rotate the wash basket and transmission CCW. Unless my thinking is wrong it sounds like the one way roller clutch bearing is frozen or dragging and not rotating freely in wash cycle rotating the wash basket CW. I’m an owner like you and will try to help.
Just a few other questions;
If you have a load of wet clothes in the wash basket and you select Spin Only cycle will the spin cycle complete with out dc/UC errors?
With the lid raised can you rotate the wash basket CW? It should not; it should only rotate CCW and do that with very little resistance.
Rich
May 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
One part of agitator moves the other part doesnt.
Two-Piece Agitator: Bottom Works, Top Does Not - Whirlpool brands
Some Whirlpool brands washing machines employ a two piece agitator. The bottom is call the agitator and the top is usually referred to a 'Mover'. A multi-piece cam and bearing assembly connects the two and allows the top portion to index.
If the bearing or cams become stripped or damaged, the mover will often not work. Fortunately, Whirlpool produces a cost effective agitator repair kit that replaces all of the critical components in this cam assembly. There are three different repair kits. They differ in the height of the cam.
Agitator Removal Instructions:
Remove Dispenser or Cap:
Some models of washing machines utilize a fabric softener dispenser that resides on top of the agitator. This dispenser simply snaps onto the top of the agitator. Other styles utilize a decorative cap. To remove the dispenser, simply grab it and firmly pull up. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (mover). Use a twisting or prying action to pop the cap off of the agitator.
Remove Internal Debris Cap:
Inside the agitator you will see a cap with a raised handle, much like that of your automobile. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring.
Remove Agitator Stud:
When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt (agitator stud).
Remove the Upper Agitator (Mover):
With the bolt removed you should be able to remove the upper half of the agitator (mover) by simply pulling up. Sometimes pulling up will actually remove the whole agitator assembly. If this happens, place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator.
Remove the Cam and Clutch Dogs:
When you remove the upper agitator (mover) it contains the cam and clutch dogs. Tun the assembly upside down. The cam and dogs should then come out.
-- Stop Here if Replacing Cam Kit --
Remove O-ring:
The lower agitator remains on the transmission shaft. On the top of the agitator, there is an o-ring. Remove this o-ring.
Pull the Lower Agitator:
All that remains is the lower agitator. This can be removed by simply pulling straight up on the agitator.
Agitator Installation Instructions:
Set Lower Agitator:
Slide the lower agitator onto the transmission shaft. Rotate the lower agitator until the splines in the shaft match those in the agitator. Once aligned press the agitator down. Install the o-ring into the top of the lower agitator.
-- Start Here if Replacing Cam Kit --
Assemble Cam and Dogs:
Turn the cam upside down. Place the small round ear of the dog into the corresponding slot on the cam. Repeat this for each of the four cams.
Install Cam and Dogs into Upper Agitator:
Invert the Upper Agitator (mover) and slide the cam/dog assembly inside. The cam should be pushed into the mover until it shoulders. Then rotate the whole assembly upright.
Install the Upper Agitator (Mover) on the Lower Agitator:
The lower agitator has two tabs that stick up that are 180 degrees apart. These tabs fit into two slots on the bottom of the cam. Align the matching tabs and slots and place the Upper Agitator (mover) and cam assembly onto the lower agitator. Push down until the cam snaps onto the Lower Agitator. If the dogs fall out during this step it is necessary to return to the 'Assemble Cam and Dogs' section above and start over.
Install the Agitator Stud:
Place the bolt (agitator stud) into the hole in the bottom center of the cam. Use a socket kit or nut driver to tighten the bolt .
Install Internal Debris Cap:
Install the o-ring into the groove on the OD of the debris cap. With the o-ring in place, push the cap into the Upper Agitator (mover). It is important that the cap is pushed past the ports in the Upper Agitator (mover) so that the wash water can enter and exit as designed.
Install the Dispenser or Cap:
The final step is to replace the top cap. Both the cap and the dispenser simply snap into place. Just make sure they are installed as far down a they will go and are firmly in place.
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator not rotating
I have had to replace the agitator gear just inside the agitator, mine did the same thing, I took the agitator apart, removed the plastic gear, the gear has a number on it, you can call sears service dept with the number, also a good idea is to have the model and serial number of the washer, the part was really inexpensive as well, my washer has been working great now for over a year since I replaced mine, if you don't want to get into it like I did, sears also offers service, but I would try to call and get the price on the part first before calling in a service tech, thanks again for your Question, hope that provided you the solution, please rate this for us,
mr.grzz
Jan 25, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator will not move unless you press down on it.
If the agitator is slipping, you may have worn out agitator dogs. Yes, there is such a thing. These are small plastic clips that act in the manner of a clutch for the agitator. The following link explains:
The link also explains how to remove the agitator. If you require addtional assistance, please let me know. I hope this helps you.
Jan 09, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
