Question about Gateway GT4022 PC Desktop
Standby problems My computer just started messing up. It was in standby and would not start back up. You could here it power back up, but the power light was still flashing and the keyboard and mouse would not work. I held the power button until it supposedly powered down, but when I pressed the power button again, the fan just started blowing and it would not come on. The only way to make it restart is to cut all the power and let it totally discharge. I turned off the standby feature and it works fine. I was taking it in for warranty work, but when checking it to make sure that was still happening, it worked fine. Now after a day of working (and not taking it in since it was no longer malfunctioning and couldn't be checked), it is doing it again. When it is not operating properly, you can't even do a restart. It starts powering down but never shuts off completely to reboot.
  • kaipodog1 Aug 31, 2008
    I have a Gateway GT5648E and I usually keep it in standby mode and I usually do a restart for systems updates about once a week. The other day I went to my computer and move the mouse and nothing happened. The blue power light on the tower was still blinking so I touched the ENTER key and still nothing happened. I then pressed the blue POWER button and the fan came on but it sounded like the hard drive never kicked in. I repeated this a couple of times and still nothing. I then cut all the power to my computer and waited a few moments and tried it again. This apparently worked but I can no longer have my tower shut down unless I cut all the power to it to start it back up. I had to go to power options in the control panel and set it to NEVER as a sleep option.
  • waywardson Jan 19, 2009
    It was actually a faulty motherboard and power supply at least the first time)! It is now at Best Buy for the 4th time. They said those Gateways have a significant motherboard failure rate. Hopefully the repair center will junk it out this time since they can't seem to fix it. If it wasn't under warranty it would have alrady been used for target practice!
  • 4 Answers
It is NOT the power supply!!!!! It is a problem Gateway has with the motherboard. Called support to learn this. This model has a defect, if u have a warranty u should get it fixed, if not u will have to buy a new motherboard or just get a different comp
One way around this is to unplug the power cord at the tower, hold down the start button for 20 seconds, then replace the power cord at the tower connection. It should start up then. But u have to do this every time lol. Good Luck.
Posted on Jan 17, 2008
  • 482 Answers
The power box is going out, I would replace it before it goes and when it does it will short out your motherboad as well. and you well have to replace bouth of them. if you replace it now, you will save the motherboad. get the numbers off the power box and check the kind you have, then look on ebay, there is new ones on there that are cheep.
Posted on Dec 22, 2007
My daewoo model dsj-4710 turns on but goes right to standby need help finding out whats the problem
main power supply which has the standby supply with it--look for those pesky puffed up filter caps.
Dec 16, 2012 | Televison & Video
My xbox was working and it cut off 5mins into me starting, the power supply light turned red. so i unplug evrythng plug it back up, the light is on standby (,yay) try to turn it on and the light turns...
I wouldn't recommend messing with it. The power supply is defective, and messing with a power supply is very dangerous. get a new power supply, just make sure that it is compatible with your xbox(there are 3 different versions of xbox power supplies out there)
Mar 10, 2011 | Microsoft Xbox 360 Console
Dell pc with windows xp wont come out of standby mode to be able to power up pc and use it
First, how do you know it's in standby mode?
I would turn it off and disconnect from the power source. Then plug it back in and try to start it. If possible, start it in safe mode to see if you can identify what is happening. If in safe mode, do a system restore back a day or two.
var fctb_tool=null; function FCTB_Init_889fec04667049cfad3405862ebb395a(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_d9758fe2c8fa4d33bc34f8b0b6f0496c(t) { fctb_tool=t; start(fctb_tool); }
Jan 02, 2011 | Microsoft Windows XP Home Edition
Compaq F572US won't start (led turns on, but nothing happens)
I have been having the same problem. At first I thought that the motherboard was fried and the laptop was a paper weight, but I kept it plugged in and kept pressing the power button several times over the days. It would always seem to start (screen remained off/black) and then it would just go off again in seconds. But persevarence has paid off, finally almost after a week it started up like normal and started working again as normal. I then had the same episode repeat a few weeks later, the computer was useless for a few days and again started up as I kept pressing the power button several times a day.
I believe the problem is with the standby mode. Each time the problem happened, it seems like the computer was going into standby mode and the power button was pressed again before it could competely go into standby or the button was pressed again while it was coming out of standby.
To sum it up, nothing is wrong with the cimputer components, there is some problem with the standby routine. Keep pressing the power button and hopefully you can get lucky in getting the computer to start again. Long term, I am thinking about checking whether there was a new flash update that came out that could fix this problem. I purchased the laptop compaq F72US in 2008 and never updated anything. Also worth noting that I called HP and they didn't stand behind their product.
Sep 28, 2009 | Compaq Presario F572US Notebook PC
Comuter will not stay in standby mode.
So why do you need the computer in stand-by mode anyway? My computers are either on or off. Off saves power and hardware.
Dec 25, 2008 | Computers & Internet
My screen will not power up. If I disconnect the current, wait a few seconds then re-connect - the standby light will go on. As soon as I try to turn on the computer - the standby light turns to green, a...
Hi rj05
I'm sorry to have to say this but you will have to take the monitor in to a repair shop. There is a definate hardware failure inside the monitor.
Dec 15, 2008 | Computers & Internet
This computer 5310s ser#0035081700 has all of asuden when sets idle it shuts down on its own also put it on stand byit shuts down and when turned back on it comes up on windows log just like it had been on...
get to the control panel and get to the power options and configure it to yor specifications concerning, the power button, standby and shutdown options, thnx
Jul 29, 2008 | Gateway Computers & Internet
Won't start from standby
sounds like charger is bad or dc jack plug broke inside on motherboard.
if u can get battery charged on another same type laptop then put back in it should start.
Sep 13, 2007 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Black Screen / Computer Stays in Standby Mode
Completely remove the battery and unplug the power cord for a few minutes. Reinsert battery and power up. You can also hit F8 when starting and see if you can boot into safe mode.
Sep 06, 2007 | HP Compaq Presario V2000 Notebook
Gateway GT4022 PC Desktop Logo
90 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
