Question about Kitchen Appliances - Others
Generator will shut off after running for 5 - 8 minutes... sputters a couple of times then cuts off. It has proper amount of oil & plenty of good fuel. I can let it cool off a few minutes and it starts right up & repeats the same cycle of cutting off. Any and all help will be greatly appreciated! :)
  • tghn1 Oct 06, 2009
    I'll give it a try then post the results. Just a side note... when it does run for the 5 - 8 minutes, it runs very well. Kind of acts like something is getting hot & losing fire.
  • tghn1 Sep 01, 2010
    Changed filters
  • 30 Answers
I would change the fuel and air filters, very inexpensive fix. A rich or lean situation on them can make it act the same way. Or if you want try one or the other first.
Posted on Oct 04, 2009
Have a diesel ETQ generator DG6LN that runs 5 minutes and then oil light goes on and shuts itself off, It has enough oil)
check whether the oil pressure sensor is working properly,display shows the correct pressure or not,otherwise replace or clean the pressure transmitter
Oct 11, 2017 | Diesel Electrical Supplies
It sputters and belches out large clouds of blue smoke
mine recommends using only detergent oil rated API service classification SG-SL. Sounds like an older model and the synthetic may be to thin. Try changing the oil to a SAE 30 to see.
Apr 24, 2016 | Garden
Hi i have a 1997 xvz 1300 and itis leaking fuel from the carby overflow when running
Add a good amount of Berryman Chemtool to the gas (half a can is OK, an engine will actually run off straight Chemtool) and run it for 3 to 5 minutes then shut it off. Let it sit overnight. Start it up the next day and take it for a ride, running it for 15 minutes and check to see if it has stopped overflowing. Should have cleaned it out. If this does the trick, get some Marvel Mystery Oil and add the proper amount each time you gas up. That will keep it clean and free of deposits.
Jul 20, 2014 | Yamaha Royal Star XVZ 1300 A Motorcycles
Generator runs for a couple minutes then shuts off
First hing to do is check the oil level as most now have an oil level switch to keep you from running with low oil.
Mar 25, 2013 | Coleman Powermate Powermate 5000W...
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
Heater cuts off after a couple minutes run time
This is a common problem with kerosene heaters. Start from scratch if you haven't done so. Drain the fuel if it is old. Change or clean the fuel & air filters. Wash out tank with fresh fuel. Fill with fresh fuel. Check to see if your ignitor is working properly & then test again. Good luck.
Dec 01, 2010 | Reddy R115DT Oil Filled Utility Heater
Starts easily, run for 5 to 20 minutes and then
If the fuel filter (strainer) is OK, carb gives enough fuel for the load you apply, air filter is dry and clean, your problem may be the low oil level protection.
Check if generator is at level position.
After the oil is distributed in all the engine its level may go less than the measuring sensor level. Try to put some more (not much) oil.
If this will not help your measuring sensor may be bad and switch off when the oil gets hot.
Jul 26, 2010 | Watts Onan Portable Generator - 5000 ,...
Briggs and straton 18k home generator cranks fine and runs for about 15 seconds and then immediately shuts down. It is hoodked into the house power panel and has worked perfectly for two years. It is on a...
If you're sure it isn't a fuel issue, also check these things:
The engine oil - it could be low on oil and shutting down on low oil pressure
If water cooled, check the coolant level. Same thing - the engine may have a low coolant sensor.
Make sure the unit isn't overloaded.
If it has overspeed control check to see if the engine is running unusually fast when it does run.
Mar 12, 2010 | Electronics - Others
Mower runs good for fifteen minutes then the
Mine did this too. THe semi-transparent fuel filter will look like no gas is in it if you have the problem I had. The gas cap on the tank has a tiny breather hole to keep it from coming under a vacuum as gas runs out. Push thru it with a toothpick to clear the hole. That's all it was. But I did have some black debris clogging the filter and had same symptom.
Aug 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Kitchen Appliances - Others Logo
80 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
