Question about Garden
I have a three year old Snapper riding lawnmower, recently it stopped starting with the electric start. I put a multimeter on the battery and consisently get 12.6 to 12.7 volts, so I dont think its the battery. It starts just fine with manual pull. When I try to use the electric start, it tries to turn over on occasion and even sometimes actually starts it. I am thinking starter solenoid or maybe the start itself. Anyhelp would be greatly appreciated
  • 389 Answers
Check your solenoid to starter output. If you are not getting 12 volts out, replace the solenoid. If you are getting a full 12 volts, check the input to the starter, if you don't get 12 volts there, check your cable for loose or corroded connections, if you do get 12 volts, replace the starter
Posted on Oct 04, 2009
Testimonial: "Thanks so much, very very helpful, I will try tonight and tell you if it worked, thanks again."
How to start it
      Stand behind the lawn mower. Use one hand to hold the engine stop lever in the operating position. Use the other hand to hold the recoil starter handle. Slowly pull the recoil starter handle until resistance is felt, then pull quickly to start the push mower engine.
      How to Start a Lawn Mower ' Starting Snapper Mowers FAQ
      www.snapper.com/us/en/support/.../how-do-i-start-my-snapper-lawn-mowe...
    Feedback
    How to start the lawnmower - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=QsRwZZwO4oc
    May 25, 2012 - Uploaded by iScaper1
    Tips on how to start a lawnmower. I asked my wife and boys today if they could start the lawnmower. One son ...
    How to Start a Push Lawn Mower: 7 Steps (with Pictures ...
    www.wikihow.com > ... > Lawn Care
    wikiHow... there's more to it than that, especially if you want it to keep running. Of course, how to start your individual lawn mower may vary according to what brand and...
Jan 12, 2016 | Garden
Starter on snapper re110 not always working
does it crank no start/hard to restart
or
no crank
BIG difference
Oct 20, 2014 | Snapper RE110 28 inch 11.5 HP Rear Engine...
Yesterday, I cut grass with my old Snapper riding mower which has an electric starter. It worked fine yesterday, but the tire went flat and I had to put the mower up until the tire was fixed. Today, the...
As I understand your problem, your electric starter will not function after a flat tire episode. Is this correct?
I don't think the two events are related. You say your Snapper is old but you do not say how old. Lawn and Garden tractor batteries typically have a 24 month life cycle. If you get more, it is free!
If this is a machine you intend to continue to use and if you continue capable of pulling the rope, this is the best and cheapest course of action. If you are going to replace the battery, and you live in the North, it would be my idea that you should wait until spring. Typically, a battery will loose 1% of its power per month while sitting doing nothing in your garage.
I hope this answers your question to your satisfaction. If there is anything else I can do for you or if this does not answer your quesiton, please post a note here.
Thank you and thank you for posting your question on FixYa.com
Plese vote
a
Nov 09, 2009 | Garden
Shearing of flywheel pin on starting 12 hp snapper
When you the key this time, put the flywheel on first then the key but this time use a little grit between the flywheel and crankshaft. Something like grinding compound. It will keep the flywheel from moving plus make sure you torque down the flywheel nut good.
HTH
Good Day.
Oct 29, 2009 | Garden
Snapper Hi-Vac riding mower that won't start with starter
You may need a 300cca battery, an ignition switch or a solenoid to get things going again. I also would check to make sure the starter gear has not locked in the flywheel teeth; it will burn up the starter. You should be able to go to the snapper website and put your model of mower in and find the parts and diagrams you need.
Good Day.
Oct 26, 2009 | Garden
Snapper rear engine lawnmower jerking and injuring.
the clutch on the engine probably needs replacing
Oct 19, 2009 | Garden
Snapper mower electric start problem
On most mowers, that red wire will connect to the battery. that could be your problem.
you didn't say if it is a rider or not, or how old it is.
Touch the wire to positive post on the battery, with the key off, remove quickly if it sparks.
if no spark, hold it to the battery while turning the key.
if the engine tries to start, connect it permanently.
Apr 14, 2009 | Garden
Garden Logo
228 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
