Question about GE Spacemaker JVM1640SJ Microwave Oven
The vent fan,surfacelight,clear and start buttons dont operate
  • GE Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 04, 2009
I have a Siemens Microwave Model # HF36V305/01 and the fan will not shut off? Any ideas as to how to fix this problem?
Microwave Automatic Vent Fan Operation - YouTube
? 2:07
https://www.youtube.com/watch?v=6LoK1geGXbQ
Aug 1, 2011 - Uploaded by GE Appliances
This video explains the operation of the automatic vent fan feature on over the ... We have a Hotpoint Counter ...Missing: siemens ‎hf36v305 ‎01
Microwave vent fan won't turn off - Appliance Repair Forum
Nov 26, 2015 | Siemens Microwave Ovens
Does the exhaunst fan turn on automatically when we cook or warm food items in our Samsung Microwave -- SMH 9187W?
Some interesting reading on page 8 of the owner's manual:
"Boilovers cause smoking and greasy spillovers that may ignite and spread if the vent fan is operating.To minimize automatic fan operation, use adequate sized cookware and use high heat on surface units only when necessary."
And on page 20:
"If the temperature becomes too hot around the microwave oven, the fan in the vent hood will automatically turn on at the LEVEL 2 setting to cool the oven. The fan will automatically turn off when the oven has cooled down sufficiently. This is an automated process and cannot be turned off. The fan may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. The Vent Fan will only operate in 1~4 levels modes while the microwave is working."
"Using the Vent delay off button
1. Press the Delay Off button once to turn the fan off after 1 minute.
2. Press the Delay Off button twice to turn the fan off after 3 minutes.
3. Press the Delay Off button three times to turn the fan off after 5 minutes.
4. Press the Delay Off button fiour times to turn the fan off after 10 minutes.
5. Press the Delay Off button five times to turn the fan off after 30 minutes."
If for some reason you don't have your owner's manual, you can still download it free here.
Jan 01, 2011 | Samsung Microwave Ovens
The fan, vent, light and clear button no longer
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
May 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Active Vent opens and closes continuously while unit is idle
I had GE look at the problem today (my microwave is less than a year old and under warranty). He replaced the cam louver and that seems to have fixed the problem. This is a small motor accessible by removing three screws and the active vent door. The whole visit was less than 15 minutes.<!-- from fixya rte -->
May 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
WONT START UP AFTER USING FOR 4 MINS OPEN DOOR
The oven is overheating. Ensure that all external vents on all sides are perfectly clear and that there is sufficient clearance around them as specified in the instruction manual. Also ensure that the vents inside the oven cavity are clean and clear from obstruction.
If this does not fix your problem then you probably have a failed cooling fan, this will entail removing the outer casing and testing that all fans work correctly, most microwave ovens have just one but many have two and sometimes three. A failed fan repair will require the use of a multimeter and some general electrical repair competency; if in doubt get it done professionally as some of the voltages beneath the casing of a microwave oven far exceed mains voltage and can kill you.
Labour rates for fan replacement are generally cheap as, like most jobs on any microwave oven, component replacement is usually very quick and easy for a competent person.
I hope that my posting has been of assistance to you, if so then please take a moment to rate my answer.
Jan 11, 2010 | Thermador Microwave Ovens
Venting hood not working on microwave mdel# JVM1630BJ03
Start the fan and check the outside vent first.I have found the weatherstrip on the exterior damper can get coated with grease and will become stuck and not allow the damper to open.
Apr 08, 2009 | GE JVM1630 Microwave Oven
Microwave fan won't turn off?
hi i would think that the power problem has fried the processor
cheers grant
Oct 23, 2008 | Microwave Ovens
Top front vent keeps opening and closing while fan is running
You can find your owner's manual online here.
That should help you clarify & verify proper operation.
If you still need help, you can contact Jenn-Air (Maytag) customer service here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 20, 2008 | Jenn-Air JMV8208A Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
56 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
