Question about Nelson Hemorrhage Paintballs Rounds Shell / Fill
Nelson rain date electronic water timer. dim digital readout
Nelson rain date electronic water timer. I have two that the digital read out is to dim to see. Even with new batteries
3 Suggested Answers
  • 5245 Answers
SOURCE: I want to print the manual for the nelson l r 56610 electronic water timer
Open following link:
http://waterheatertimer.org/pdf/Nelson-5945-56610-Instructions.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jun 25, 2012
SOURCE: A Nelson controller won't accept programming commands
Where is the reset button located on my Nelson Turf Pro Jr. 8300
Posted on Jul 29, 2012
Nelson 8200 e z pro everything works but it chirps every couple minutes
Just a WAG, but My first suspicion is your internal battery has become very weak. It's down low and behind the control panel. Similar to a smoke detector when the battery is getting weak. Hope this helps!
Jul 13, 2014 | Nelson L R 56610 Electronic Water Timer
There is a flashing arrow next to "event" and when I check the programming for the schedule, the arrow is solid pointing to "event and even". I want to be certain that the "event" schedule is running. It...
I can't be sure without going outside (it's raining) and checking my own controller, but I'm thinkin' that the arrow pointing to "even" indicates that the program will only water on even numbered days. Can you change it so it points to event and "All"?
Aug 29, 2013 | Nelson L R 56610 Electronic Water Timer
My et103c will not manually or electronically turn off my pool pump.
Copy following link to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET-series
Unknown if this is new installation, or old installation that stopped working.
Check battery. The timer requires a battery. Located below the buttons.
ET103C digital electronic timer is discontinued but some folks still sell on ebay... selling possibly used timer. Timer has 1 year limited warranty from date of manufacture.
Timer has error code messages... if you receive no error code, then battery could be problem.
Line noise can cause timer not to function, such as fluorescent lights on same circuit etc.
ET103C clock mechanism is 120Volt 60 Hz. If pump and circuit are 208-240Volt, or 277V etc then this timer is not best choice unless neutral wire is available..
Add a comment and describe situation in more detail.
May 02, 2013 | Intermatic & Indoor/Outdoor Rain Tight...
Owners manual for nelson ezpro 8300
Copy following link for sprinkler timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Jul 04, 2012 | Nelson L R 56610 Electronic Water Timer
LED not visible anymore. Can't see the numbers or just barely. Can it be fixed?
Try new batteries. If the display is facing direct sunlight, you might try shading it, too.
Jul 27, 2011 | Nelson L R 56610 Electronic Water Timer
I have the Nelson Controller EZ Pro. Jr. 8006. AC is OK, Batteries are OK. but I lose set program after a day or two for no reason. Please help Thank you
Are you having power blinks? A real problem in my area. If so, replace the lithium battery inside. A little more hassle to get to than the AA batteries (but not impossible), but quite possibly the problem.
Jul 24, 2011 | Nelson L R 56610 Electronic Water Timer
Look for a 'master reset' in the manual. This should put everything back to 'default setting'. Then start over in your programming. Don't forget to save after you program your parameters.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 23, 2009 | Nelson L R 56610 Electronic Water Timer
Nelson Hemorrhage Paintballs Rounds Shell / Fill Logo
348 people viewed this question
Top Nelson Sport & Outdoor - Others Experts
Bill Eager
Are you a Nelson Sport and Outdoor - Other Expert? Answer questions, earn points and help others
