Question about GE Energy Star WCVH6260F Front Load Washer
My dryer sounds like golf balls r rolling around in it with very few clothes in it
  • 71 Answers
That's actually a really easy fix....the dryer should have 4 roller wheels that the drum rides on and one or more of them must be worn out that is where your noise would be coming from.
Posted on Oct 04, 2009
My dryer sounds like there are metal balls rolling around inside when clothes are drying
Sounds like the rollers are worn out. If they are fine then see if the dryer has glides on the drum.
Apr 23, 2014 | GE Profile Wizard DPSE592EAWW Electric...
Clothes roll into a ball on matag dryer
As you insert the clothing into the dryer make sure you open up the larger pieces fully so they do not ball up. Frequently people put large bed sheets in before opening them up and everything gets rolled inside them. If your load is too small, that might happen, also!
Jan 10, 2013 | Dryers
MY CROSLEY CDE8000 DRY SOUNDS LIKE IT HAS A BALL ROLLING AROUND IN IT
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 01, 2011 | Crosley Dryers
Inteli dry regular cycle, timer gets stuck and won't advance. other cycles work fine. thanks
An unusual noise coming from a running clothes dryer can cause concern, although these noises are rarely indicative of a more serious problem. Once the source of the noise has been located, a few simple repairs or adjustments will usually solve the problem and restore peace to your laundry room.
    Gas
  1. A gas dryer may emit an occasional clicking sound. This noise is caused by the gas valve and is a normal operating sound. The clicking sound coming from the gas valve can not be eliminated and it does not indicate any mechanical problem with the dryer.
  2. Warm Up
  3. A newly installed dryer, or a dryer that has been left unused for a period of time, may exhibit a thumping noise during the first few minutes of the drying cycle. According to the Maytag company, this noise is normal and should not be a cause for concern. If the noise continues for more than a few minutes or repeats on subsequent loads, however, then steps should be taken to locate the origin of the noise.
  4. Clothing
  5. Clothing can become knotted and balled up in the clothes dryer. This can cause vibration or a load thumping noise. When this happens, open the dryer and remove the knotted clothing. Separate the articles of clothing and place them back in the dryer. The thumping noise should not continue unless the clothing has become knotted again.
  6. Vibration
  7. Place your hands on top of the dryer and push down firmly; if the dryer tilts to one side, the clothes dryer is not level. This can cause the dryer to vibrate during the cycle and if the vibration is severe enough, the surrounding walls could be damaged by the dryer. Maytag dryers have four leveling legs installed into holes on the bottom of the dryer. These legs are included with the dryer and should have been screwed into the holes during installation. A wrench can be used to adjust the legs until the dryer is stable and level.
  8. Foreign Objects
  9. Small objects such as coins, buttons, or paperclips can become lodged between the drum and the sides of the clothes dryer. These items usually end up in the dryer after being left in clothing pockets during laundering. Turn the dryer off and remove any clothes to a laundry basket. Allow the dryer to cool down so that you won't burn your hand on any metal surfaces inside the dryer which may be hot. Look inside the dryer and pay special attention to the front and rear edges of the dryer drum. Run your fingers along the grooves where the drum connects to the dryer to locate any foreign objects. These objects could be bouncing around the dryer causing noise during the cycle, and then settling into the grooves when the dryer stops making them difficult to locate. Remember to remove all items from clothing pockets before laundering in the future to avoid this problem.
  10. please comment on these solution on how helpful
Dec 30, 2010 | Maytag SDE5401AYW Electric Dryer
Dryer makes lots of noise when drying..squeaky ans sometimes a "thump"
heatman101
Dec 07, 2010 | Kenmore 64882 Electric Dryer
Weak Dryer exhaust
I have seen the blower unit in those machines split where the impellor is fastened to the shaft. This causes the fan to not spin fast enough to move a lot of air.
Mar 04, 2017 | Dryers
Sheets aren't drying
Sounds like out take, something blocking the vent, pinched line, birds nest, snow?
Feb 11, 2009 | Dryers
Clothes roll into a ball on kenmore gas dryer #11062202101
Just get the filter out and remove the 2 phillips screw init's housing on top. Then use a putty knife to press against the spring clips that hold down the top Then just roll the drum around to the top where the holes are to reattach the baffle, get some screws and put it back.87656db.jpg
Dec 15, 2008 | Kenmore 63942 Dryer
Kenmore dryer
could be;
belt slipping
over loading
tumble veins inside drum broken
Dec 13, 2007 | Kenmore 62802 Electric Dryer
GE Energy Star WCVH6260F Front Load Washer Logo
107 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
