Question about Dewalt 2 Dc925 18v ½ Hammer Drill / Driver 18 Volt
Dewalt DC925 hammer/drill
Chuck will not hold bits. looks like the screw inside chuck has been pounded flat.
4 Suggested Answers
stug_57u
  • 99 Answers
SOURCE: removing the dewalt DC925 'rohm' chuck
It should have a retaining screw as far as I know. It may be a torx head in this machine though. Normally left hand thread screw, then normal thread for the actual chuck. It's always worth tightening the chuck a bit before removing the inner screw as it can put pressure on it and make it harder to loosen.
Posted on Nov 29, 2008
  • 12 Answers
SOURCE: Dewalt Drill DC728. Chuck came out of drill body
If you find that the end of the screw inside the chuck is actually broke then you have a gear problem inside your drill. This is actually a very common problem. Sometimes people push too hard on their drills and the gears inside wear out and break. This prevent the motor from wearing out, but, the gears have to be replaced.
If it is the gears and not the chuck. you broke the minimium of the front gear or gears inside your drill. YOU CANNNOT repair gears. they need to be replaced. you may be able to find some off brand gears to work but, you run the risk that they are not as strong as your original ones, or may not be exactly grooved correctly.
so, if replacing your chuck does not work. find replacement gears. IF you cannot find the gears from the manufacturer see about replacing your drill.
If the chuck is still good, keep it. If you buy the same model, keep your old drill for replacement parts, ie, switch, armature, cord, etc.
hope this helps somewhat.
Posted on Jun 11, 2009
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
Posted on Oct 18, 2009
How to get the chuck off a dcd950 dewalt hammer drill
Only the screw in the centre of the chuck would be l/h tread, the chuck should be normal thread and come off in an anti clockwise direction. Please confirm drill model number.They did a version where you needed a service tool to remove it and refit. It is torqued on.
Nov 15, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Removing chuck from dewalt dcd925
open chuck and look in the bottom of it (chuck)there is probably a screw there. think it will be left hand thread
Oct 25, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Dewalt cordless releases bit when unscrewing under pressure
In the past when this has happened to me I have had to replace the chuck. Problem is, the chuck is not a normal one and the correct chuck has a list price of about 65 pound and needs a special service tool to take it off and put it on again.
Jun 15, 2012 | Dewalt DC925 Cordless Drill
THE CHUCK WON'T TURN WITH THE MOTOR RUNNING. YOU CAN HOLD IT IN YOUR HAND AND FEEL IT CLICKING AND HEAR IT WHAT COULD BE WRONG WITH IT?
The DCD950 drill has a chuck that does not require the reverse-threaded lock screw. It is put on with lok-tite and a good deal of torque. It is hard to remove without the Dewalt vice tool to hold it but not impossible. Some can be removed by tightening the chuck in a vice and, using the drill handle for leverage, apply steady, even, strong pressure until it breaks free. Using this method usually bends the part of the chuck in the vice making it useless. Another reason for the chuck not turning when the motor is turning is a broken transmission. If the chuck works properly in tightening down and releasing bits, your problem may be in the transmission. If you go to http://www.ereplacementparts.com/ and search for your model number you can look at a breakdown of your drill and what you're looking at to replace the transmission.
Feb 12, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Dewalt dc925 drill, the chuck jaws appear to be jammed tight shut and will not open. any ideas?
Hi, soak the chuck in crc overnight then put the drill in low speed and reverse. Hold the chuck by hand or with multi grips and pull the trigger. Hope this helps, regards Phil.
Jul 23, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How can i remove the chuck from my cordless dewalt power drill
Hello, W/D here.
To remove your chuck, open the jaws of the chuck fully, but don't open them so tight that they lock in the open position. Remove the screw inside the chuck. Spray the inside of the chuck with penetrating oil. Tap around the edge of the chuck, while pulling it away from the motor.
It should come right off, with a little effort.
Best regards, --W/D--
Feb 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
DeWalt DC925XE Keyless chuck keeps undoing when reversing screws releasing driver bits.
You must never oil the chuck so if this has been done then it can be the cause of your problem
Sep 28, 2010 | Dewalt DC925 Cordless Drill
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
Removing the dewalt DC925 'rohm' chuck
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
Feb 16, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt 2  Dc925 18v ½ Hammer Drill / Driver 18 Volt Logo
51 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
