Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos lcd tv screen gets fuzzy
My sharp aquos lcd tv has a problem with the picture quality. the screen will get fuzzy for a few seconds and then it will be fine for a minute or two and then get fuzzy again. i can still see the picture but it has squiggly lines on it. it only does this with a coaxial cable hook up, when watching a dvd with the video inputs it is fine. i believe it has a problem with the coaxial input. is this something i can replace or do i have to take it to a repairman?
  • 71 Answers
SOURCE: Sharp Aquos Color Variations
Put the OPC off and check the conection for Pb signal.
Posted on Dec 06, 2007
Highdefjeff
  • 124 Answers
SOURCE: Sharp Aquos LC-65D64U Picture Quality
You need to change your TV's settings and enhancements. Directly from the store and out of the box, the settings are adjusted for easiest sell in the store. That means that:
Your contrast is cranked to 100. Move this down to 50 to 60.
Your brightness may also be cranked up high. Lower it to a level nearer the middle range but not so dark as to lose detail in the shadows.
Your TV is set on "Dynamic" or "Vivid" mode. Pick "natural" or "normal" or standard.
Your sharpness is at least on, if not cranked up. Turn sharpness down or off, and the same with "Edge Enhancement" and "VSM", all to off.
Lastly, I bet you upgraded size and you are now sitting too close to the TV. Roughly, if you are sitting closer than 130 inches (about 11 foot) you might do some rearranging or save some money and get a smaller TV.
Posted on Apr 08, 2008
SOURCE: turn off closed caption on input(component) on Sharp Aquos 42"
ok had to post this one with reference to the above problems
My area St Augustine Fl. .. COMCAST (THOSE PAIN IN THE A--) SERVICE INSTALLED A NEW BOX IN MY HOME THE OTHER DAY ... I KEEP SEEING the box go thru dowmloads
then the very next day I started to see the colosed caption across my screen
SOLUTION ... with tv on and box on ( be in cable mode) press MENU on cable remote ,press power button, press menu again, look at screen and where it says caption make sure it is disabled
Mine was enabled ... change it and problem fixed ... I spoke to comcast finally after trying all day and they confirmed that with their new down loads to box it triggered the CAPTION to be ON
anyway problem was fixed ...
I read all prevoius posts and tried them all ... so may be this will work for problem that someone is having as of 10-9-2008 ( I could not believe that they could do that but they sure can COMCAST is just a PAIN in the A--
thanks to all who post solutions and I had to do my share and maybe be able to help someone else.
Posted on Oct 10, 2008
  • 10 Answers
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
  • 8457 Answers
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Posted on Dec 17, 2009
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
How do i change from 480i to 1080i on a sharp 52"
You don't. The TV picture will be fuzzy when watching a program in 480. If you have a lot of video in 480 or 720 you can get an up scaler. They are expensive, but that is the only way you'll ever get a Hi def picture from a low resolution signal
May 28, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Looking for solution for Sharp Aquos LC32D41U 32 "
when it goes black then check with flashlight 2 in from screen and see if you see a picture, if so then inverter board is going out, you can google your model and inverter and find the replacement.
Dec 30, 2010 | Sharp Aquos LC32D41U 32 in. LCD TV
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos 37" picture
Those lines are because of "Interlacing". a REALLY bad case of it. what are you watching when this happens?
Jan 02, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Mar 23, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
52D82U Fuzzy picture
Change your input source. You are probably on Input Source "TV". My HDMI cable is plugged in INPUT 4 so make sure that your TV is set to the right INPUT.
Oct 07, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
313 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
