Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
My control is broken. Is there any way of turning the television volume down manually?
  • 115 Answers
Use the vol. down button. The buttons are located on the right side of the tv toward the top. Volume down is second from bottom.
Posted on Oct 04, 2009
Bose system is just over 1 yr old, hooked up to Smart Tv ( same age) sound was working fine, turned volume down, no sound at all after that
Hi, You have a Bose Home Theater System hooked up to your television and I'm wondering if you're controlling the volume through the Bose Home Theater System or the television because both have a volume control and if you have the television volume turned down and you're using the Bose Home Theater System for volume or visa-versa then you're not going to get a decent sound. I hope you know what I mean...... CHEERS..
Mar 31, 2016 | Bose Audio Players & Recorders
Volume Control
Look for any jammed buttons (keys) on remote control and/or on control panel.
Aug 12, 2012 | Televison & Video
The volume on my tv will not turn down. when i manually try to turn it down, it continues to go to full volume
Take the batteries out of all remotes that could control your T.V.s volume. Try turning it down. Try pushing the up button on T.V. to see if it's stuck. This T.V. doesn't really have a lot of digital controls, so it's probably a mechanical issue.
Dec 22, 2011 | Mitsubishi WS-55511 55" Rear Projection...
My olevia tv's volume is not working correctly. I
Maybe the remote or the tv manual control board is damage?Check the tv manual vol + - see if function normally.Take the remote aparts and clean it with some Q tips dip in with rubbing alchahol clean the remote PCB.Try website like Remotes.com to buy an exact to the original remote tv.
Jul 15, 2010 | Olevia LT27HVX 27 in. LCD Television
I don't have a remote how do I turn up the volume?
Use the tv manual control button volume + - to turn up or down the volume.Try website like Remotes.com to buy an exact the original remote.
Jun 23, 2010 | Fujitsu Plasmavision P42VCA30EH 42 in....
Have an Hitachi 60sx12b. the sound meter bar stays on. can manually adjust the sound up but will go back down to 0. tv remote or sat. remote doesn't work at all. Please help
It sounds either volume down button is bad that turns volume down on its own or system control chip got defective and decreasing volume level.
Press volume down button on tv front and check is it working properly.
Let me know to find out further info to solve the issue.
Thanks.
Jun 05, 2010 | Hitachi Televison & Video
Volume won't turn down
Try the setup program. When you get to the main setup screen, look for a reset all to standard setting. That may solve the problem. If it doesn't then the sound module may need to be replaced inside the TV.
Apr 11, 2009 | iLO 3200 32 in. LCD Television
The volume will not go up or down
make sure theres batterys in the controll.
try turning it up from the buttons on the tv.
else i dnt no
Feb 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
RCA P52927 volumn control
The buttons on control panel are there for convince not for everyday use. Use remote, your control panel is bad.
Nov 11, 2007 | RCA P52926 52" Rear Projection Television
Volume knob
Normal Aiwa compact shelf units use what is called a jog switch for the volume. Usually you can tell the difference if when you you turn the volume up or down. It goes a short distance and seems to spring back. In this case there are two momentary contact switches. One for up one for down. With a plastic lever on the back of the knob that bumps the approriate switch whether turning down or up. If the lever is broken it will bump up against one but not the other. If it is broken plastic you know how good gluing plastic goes it never seems to hold.
Aug 02, 2006 | Aiwa NSX-A777 Shelf System
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
