Question about Samsung DLP HL-P5663W 56" TV
My Temp light is red, the lamp and time light are green and I have no picture. What is causing this and how do I fix?
User error. Problem resolved itself.
Posted on Oct 05, 2009
Sony LCD KF-50WE610 no picture-red light blinking
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement.
Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
Jul 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Tip
Pix shuts off, green light starts flashing, pix comes back and shuts off again
If you have an issue where your picture turns off and the green power light starts flashing, you are most likely looking at a weak or old lamp. Do not be confused with a pix loss and a RED light flashing, as this can be caused by many things. The normal sequence of events for this fix is this:
1) TV turns on normally, plays for 1 to 3 minutes (may be more or less time)
2) Picture goes out and green power light begins flashing. It may flash for up to 2 minutes
3) green light turns on solid (stops flashing) and picture returns.
4) Picture goes out again and process repeats.
You may have been told that "if the lamp light isn't on, it isn't a bad lamp".
FALSE!
A weak lamp will cause the process above to occur. Other signs of a weak lamp:
The reflector in the lamp is very cloudy
You may see a "growth" or "bubble" on the vertical glass tube which is the lamp
You haven't replaced the lamp in quite some time or it is the original lamp from when you purchased the TV.
In cases like these, try a new lamp. Stick with an original Sony lamp, as there are many stories (both personally witnessed by me and also documented on the web) about problems with after market replacement lamps. And remember, lamps DO NOT have a shelf life; you can store them in a good environment (not too hot or cold!) for an indefinite period with no ill effects.
on Nov 03, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
KDF-50a12U Powers off then standby light blinks 3 times
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error.
There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error.
Thanks.
Oct 19, 2009 | Sony BRAVIA KDL-40V3000 Television
Hitachi Ultravision 50in will power on but no picture or sound!!!
Replace Ballast Board it is what turns Lamp on! Call Encompass for Part 1-800-638-3328
Sep 26, 2009 | HP Pavilion MD5020N 50" DLP HDTV
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Audio, no picture wd-65731
lamp light green is a normal code. Try turning set on 3 times and see if lamp light goes red. If it does you have a bad lamp. Also check to see if lamp is on all the time. This a problem that can happen and service tech needs to fix it. Let me know what happens.
May 23, 2009 | Mitsubishi WD-65731 65" HDTV
Red blinking light three times pause then three
Make sure that lamp door is fixed securely and pressing lamp door switch as 3 times blinks shows lamp door switch is not On.
May 13, 2009 | Sony KDF-50E2000 50" HDTV
No picture
Symptom: LAMP Led Blinking Cause: Check the door lamp switch & lamp pwr switch, boss on the door or lamp assy may not close switch. apply tape to boss.
May 13, 2007 | Hitachi 60V500 60" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
153 people viewed this question
Jerry Greenberg
Jerry Greenberg
