Question about PfaFF Creative 7570
PFAFF Varimatic 6085
I brought home this sewing machine for the weekend, and when i thread the machine and try to sew it gos for about one stitch, and then locks up. what should i do?
  • Anonymous Mar 25, 2014
    looking at front of machine found a 4" spring lifting foot gos down very hard
  • Anonymous Mar 28, 2014
    threading neddle
Did you get any feedback on this machine's problem?
i'm getting the same model by the end of the week.
thank you. chuck
Posted on Jul 28, 2008
Hi, I have a Pfaff Varimatic 6091. I sewed some 'too thick' fabric, and it has 'broken' my top tension unit. i.e. I can no longer set it at all, and when sewing the thread is all loopy.
If the upper tension unit is in fact broken, you will need to take it for service or find a replacement part.
This may be a shot--remove the upper thread, ALWAYS RAISE the presser foot, rethread from the beginning. Re-try your machine.
Apr 22, 2017 | PfaFF Sewing Machines
Change bulb on 6085 PFAFF
Looks like you bulb is a bayonet style. Push up and rotate the old bulb to remove. Install the new bulb the same way--push up & rotate to lock in place.
Note: there is also a bulb remover tool
Pfaff Varimatic 6085 Parts
PFAFF fashion Owner Manual Changing The Light Bulb
Apr 07, 2017 | PfaFF Sewing Machines
How to thread a pfaff varimatic 6085 has some threading diagrams
try youtube & ehow for video's on threading the machine
try pfaff customer service for a manual
Apr 15, 2012 | PfaFF Sewing Machines
Pfaff Varimatic 6085 purchased June 2001. Second time this has happened and it cost $60 to repair. When the needle is centered it hits the case holding the bobbin. If I move the needle to the right it...
Many users also had the similar bobbin locking problems. I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Aug 17, 2010 | PfaFF Creative 7570
Pfaff varimatic 6091 sew a rag quilt with jean and flannel,I can't get my tension right it seems to be funny on the bottom stitch,where shoulf the top tension be set at 4 1/2 ,when do I adjust the bobbin...
Hi! The bobbin tension rarely needs to be adjusted. First, make sure you're using the appropriate size needle and thread for your fabric (I'd probably use either a 'denim' needle or a universal size 14) and also that the upper thread and bobbin are threaded absolutely correctly. These can throw off the tension! Also, take the time to clean out the bobbin area. That can throw your stitch off also.
If the stitch on the bottom is loose, so that you see the top threads, then the top tension is too loose. If the top stitch is too loose and you see the bobbin threads on top, then the top tension is too tight.
It helps to thread the machine with different color thread on top and in the bobbin, and then stitch an inch or so on the same type of fabric as you're using in your quilt. Check the stitch. If you need to adjust the top tension, make sure the pressure foot is down! Adjust a little, stitch a few inches, and check again. Repeat until you don't see any (or very little) bobbin thread on the top or top thread on the bottom.
If you go through all these steps, and the bobbin thread is still loose (and you've tightened up the top tension), then there is a tiny little screw on the side of the bobbin case that you can use to adjust the bobbin tension. Turn the screw just a little bit (less than a quarter turn), stitch, check, etc. Once the bobbin tension is set, you shouldn't ever have to change it.
Let me know if this helps, ok?
Happy sewing!
Feb 10, 2010 | PfaFF Sewing Machines
My Pfaff 7550 sewing machine will ball-up thread on underside
Make sure your tension is set on 5 and you don't have dirt stuck in your tension unit.
Jan 18, 2010 | Sewing Machines
Sewing Machines Logo
1,553 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
