Question about Whirlpool LER4634J Electric Dryer
Start button will not work
When pressing the start button to dry clothes nothing starts. What can the problem be?
  • 304 Answers
The problem you describe is usually caused by a thermal fuse intended to shut the dryer motor down and keep it off because of a problem with air flow within the dryer.
The following process will allow you to test the thermal fuse and replace it if you find it open.
Unplug unit and turn off gas if gas model. Check to be sure you have 240 Volts at wall outlet.
Most parts likely to fail on electric dryers are inside the rear cover. Heater is on right inside can, safety thermostat on lower left of can, High limit thermostat (non-resettable) higher left of can. On the blower housing to the left are the operating thermostat and, in some models, a thermal fuse (white plastic). ALL can be continuity checked easily. Always disconnect wire on one side of what you are testing. One will likely be open. Replace the component that fails the continuity test.
Replacing the heater, if necessary, can be done by disconnecting the wires at the lower left of the heater can on right. There will be a screw on each side edge of the lower half of the can. Remove the two screws and pull off the back lower half of the heater can and reverse the above process to install the new heater.
The thermal fuse or high limit thermostat failure generally points to a reduction of air flow due to SOME blockage either inside the dryer or in the vent pipe leading out of the house. If you find either of these parts bad be sure to check the vents after replacing parts to ensure the same parts won't fail again.Heater replacement requires lifting of top to unscrew a clip at the top of the heater housing. Under the lint filter cover there are two screws. Remove them WITHOUT dropping them into the vent or you may cause a more serious problem. Insert a putty knife between the front and top about 2 inches in on both sides. This will release the top for raising.
Posted on Oct 04, 2009
How do i do drying only
From the document I see, it is only a matter of pressing the "Dry" button. This is from the manual, available at http://www.lg.com/us/appliances/washer-dryer-combos/LG-WM3431HW.jsp and selecting the "Support" tab. On the right, there will be a "Washer/Dryer Combos Manual" link, which will download to your computer. Listed under "Dry" in Section 9 is the following.
• Drying options are easily selected with the Dry button. • For most even drying , make sure all articles in the clothes load are similar in material and thickness. • Do not overload dryer by stuffing too many articles into drum. Items must be able to tumble freely • If you open door and remove load before dryer has finished its cycle, remember to press the Start/Pause button. • By pressing the Dry button, you can select "Normal" - "More" - "Time" - "Off" - "Low Temp" - "Less" • Your dryer can handle a load of up to 9 lbs. (4 kg) dry weight of articles. • When drying cycle is completed, [Cd] (Cool Down) is displayed on the Multi display. • Cool Down is set automatically when the drying cycle is complete. • If clothes are not removed promptly when the drying cycle ends, wrinkles can form. • The Cool Down feature periodically tumbles, rearranges and fluffs the load to avoid wrinkles for up to 4 hours. • The message [Cd] will continue to display until the clothes are removed or the Start/Pause button is pressed
Hope this solves your problem. I highly recommend downloading the users manual, it is a wealth of information and will prove useful in many circumstances.
Please rate and comment Thank You Joe
Sep 06, 2011 | LG WM3431 Front Load Washer / Dryer
When I press the start button to begin drying clothes, once you take your finger off the button nothing happens..The dryer drum will turn.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 26, 2011 | Whirlpool LGB6300 Gas Dryer
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes.
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes. Kennmore 96590140.
Jan 01, 2011 | Kenmore 62602 Electric Dryer
The start button is flashing red and beeping and the drying cycle won't start. Help!
  • If the machine shakes or makes a lot of noise, make sure the dryer is level. Some shaking is normal, but it shouldn't bounce around like it's itching to go somewhere. Adjust the leveling legs. They just screw and unscrew. Check to make sure the load inside the dryer is properly distributed and is not all clumped together.
  • Match the control settings to the type of load, and make sure you're not overloading the dryer.
  • Check that the ducts aren't blocked if the clothes take too long to dry. Look for lint or missing socks. Check to make sure the ducting isn't kinked, and make sure the outside dryer vent flap moves freely and isn't blocked---by snow, for example.
  • Sort your clothes by weight if they aren't drying properly. Lightweight clothes should be dried separately from items like comforters.
  • Make sure the lint drawer is empty.
  • Press the "Stop" button or press the "Lock" button for three seconds if the controls don't work. Press the "Power" button to wake the dryer up if it won't start. Make sure the "Delay Start" button isn't flashing if the machine fails to start. Press "Start" again.
  • If you see only lights displayed on the screen and no numbers, it's normal. The dryer has detected a low level of moisture. Other normal behavior is when the time remaining jumps to a lower number---it's revising its estimated time remaining. When you can't make a selection and the dryer beeps twice, the dryness setting is incompatible with the chosen dry cycle hope this helps please tell me if it does
Dec 06, 2010 | Zanussi Dryers
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
PUSH TO START BUTTON DOES NOT WORK
its not the start button check the door switch if broken or actuator is broken you get the results as you dry
Aug 21, 2009 | Kenmore Dryers
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Sep 13, 2008 | Maytag PYE2300AY Electric Dryer
Why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Oct 28, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Blinking lights and failure to start
Suggestion: 1 Press and hold down 'spin' & 'dry' buttons to unlock controls. 2 Have u overloaded the machine with clothes? Reduce load. 3 Try 'spin' only after putting the clothes. Then put off machine & continue with main cycle. Three suggestions here........ What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Feb 07, 2007 | Frigidaire GLTF1240A Front Load Washer
Whirlpool LER4634J Electric Dryer Logo
77 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
