Question about Frigidaire GLTF2940ES Front Load Washer
Ddo code My washer will turn on but in 5 sec it go to the ddo code and will not start
  • 15,935 Answers
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Posted on Sep 16, 2010
How to run a diagnostic for washer model MHWE450WW01 Maytag
Starting Error History Software Version and
Diagnostic Test:
NOTE: Washer must be empty and the control must be in the
OFF state.
1. Close the door.
2. Select any one key (except "STOP/CANCEL" and "CONTROL
LOCK" and follow the steps below using the same key:
Press/hold for 2-5 seconds, Release for 2-5 sec, Press/hold for 2-5 sec, Release for 2-5sec, Press/hold for 2-5 sec
3. Upon release, all yellow/green console LED lights will turn ON
for 5 sec.
4. If there are any failure codes stored by the washer, the display
shows them.
Note: The last four errors will be displayed.
5. Press the same key to advance to the next code.
6. After the indication of error codes, the UI, CCU, and MCU SW
version will be displayed.
7. The number of cycles since last clean washer cycle is displayed.
8. All green console LED lights will turn ON for 5 seconds.
9. Next the washer begins the automated diagnostic test.
10.To cancel out of service mode, press the "STOP" button.
Apr 10, 2014 | Maytag Washing Machines
Error code DDo ON A FRIDGEDAIRE FRONT LOAD WASHER
Hello geraldinerid - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a further diagnosis is recommended to have a professional check the reed switch.
Apr 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
Computer shows ddo &won't finish the wash
Hello noella_30 - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a professional needs to check reed switch.
Dec 02, 2012 | Frigidaire GLTF2940ES Front Load Washer
My GLTF2940ES0 WON'T START it's cycle. An error code "ddo" displays
The meaning for ddo error means "Dispenser Drawer Open"
To rectify this problem you should try opening and closing the door shut. There will be a magnet which shows that the door is closed or open.The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself to view the magnet. If the magnet is missing you have to replace it.
Thank you !!
Jun 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
The water wont start filling up - it beeps and then has the code "ddo" on the screen.
Thank you !!
May 25, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front load washer with ''ddo'' code
The DDO trouble code means that the detergent(D) dispenser(D) door is not closed properly((O)open).
The door uses a reed switch and a magnet to send the door closed signal to the control card.If the
magnet becomes dislodged you will get this code.You will need to have the magnet replaced in
its proper position to clear this code.
Apr 05, 2010 | Frigidaire GLTF2940ES Front Load Washer
Ddo
Hi
This ddo error code means Dispenser Drawer Open.Check to see if the Dispenser Drawer is open or the small tubular Magnet # 51 is missing. The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself, you will see snapping clips to unsnap, then you will see the magnet#8 in diagram#1 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=117979
reference
http://www.fixya.com/support/t2180388-code_ddo
Mar 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
Code ddo
Hi
This error code appears in the frigidaire washer which means--
ddo error--- Dispenser Drawer Open
GLTF1670AS0
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 08, 2009 | Washing Machines
Error code ddo will not start wash
This indicates a problem with the door interlock switch and until resolved the machine will not start.
Sep 18, 2008 | Frigidaire GLTF2940ES Front Load Washer
Buzzing sound then "ddo" flashes on panel
Push the button down on the back side of the soap dispenser that says push down or push here (to take the tray out). When you have it out you will want to turn it over and there are 3 or 4 white tabs. You will want to pop the front part of the drawer off and then on the bottom about an inch in/down there is a small slot to put it into. It is the same size as the magnet and the magnet goes with the squares on the top and bottom. You cannot actually see the magnet when the drawer is put back together. When I talked to the service man he said they did away with the magnet on the new model. How stupid to put it there to begin with!! Hope that helps
Aug 08, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
60 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
