Question about Kenmore 24032\24036 Top Load Washer
Machine won't shut off water when filling up.
Kenmore series 80 washing machine won't shut off water when filling up.
  • 5,911 Answers
The water level is controlled by the pressure switch which is located behind the load level selector knob on the control panel. Before assuming you have a defective pressure switch, however, read the following link:
http://www.fixya.com/support/r762094-washer_overflows
In many cases the small air hose comes loose from the pressure switch and causes the symptoms you are experiencing. The air hose is used to sense the differential in pressure as the water level rises in the wash tub. Without it and the pressure switch will not shut off the water. Check the air hose to ensure it is still attached to the pressure switch and check the electrical connections to ensure they are not corroded. If the air hose IS attached, make sure it doesn't have any leaks or cracks in it. You may have to inspect the entire length of it to be sure. If these preliminary measures do not work, replace the pressure switch. If the pressure switch requires replacement, you can search for the best price at these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
If the water level never seems to reach the correct level and drains as it fills, you may have a condition known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If your washer exhibits these symptoms, it may be a simple matter of drain hose placement.
If you have questions, or require additional assistance, please let me know. I hope you find this information helpful.
Posted on Oct 04, 2009
  • Jeff Rockwell
    Jeff Rockwell Oct 04, 2009
    NOTE: I almost forgot, another cause of a washer that does not shut off can be a failed water inlet valve. An easy test to determine if this is the case, is to leave the water source on while unplugging the washer. If the washer continues to fill while unplugged, this is a water inlet valve failure. If the water stops, check the pressure switch as I described above.
    President:
  • 1,776 Answers
A machine that overfills or underfills can often have a faulty water level switch. It's a diaphragm like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level, it activates the switch to shut off the water. Make sure there is no damage to or obstruction in the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad switch. Really sorry for your trouble and I hope this helped. Best wishes.
How many gallons of water does a Kenmore series 80 model 110 extra capacity plus washing machine hold at max and at 1/2 max
The Series 80 washer has a max capacity of 20 gallons. At the lowest water level setting you would have between 14.5 and 15 gallons.
Dec 23, 2014 | Kenmore Washing Machines
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore series 80 model 110 wont stop filling!
There is a clear plastic hose that runs from the load selection switch to the side of the washer drum. This hose connects the fill sensor to the load switch. without it being in good condition and connected properly the washer won,t get a signal that it's full.
May 09, 2013 | Kenmore Washing Machines
My kenmore 80 series washing machine makes a horrible noise and cold side fills about half speed when filling with water. What should I check?
For the slow water issue, you will need to replace the water inlet valve. Here is a link to the part.
Could you describe the noise and where it is coming from?
Oct 19, 2012 | Kenmore Washing Machines
Kenmore 80 series fills with water then doesn't
the lid switch under the control panels bad replace it and it will again wash,they just unsnap out of the top of the cabinet after you remove the control panel
Jul 07, 2011 | Kenmore Washing Machines
Kenmore hd 80 series,extra capacity plus. cold water will not fill tub?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jan 23, 2011 | Kenmore Washing Machines
Kenmore series 80 washing machine overfills, it will not start washing, it just fills and runs over
Hi, The first part to check is the inlet valve. If you shut the washer off, will the water stop? If the water continues when the power is off to the washer, change the inlet/mixer valve.
If the water stops filling when the power to thee washer is shut off, the water level switch needs checked.
Please let em know if either of these help so I can assist you further.
Vic
Jun 20, 2009 | Washing Machines
Kenmore Washing machine
ck lid switch also ckd hinge screws that looks like newer moder with switch under left side of console try pressing left rear corner of lid or listen for clock when lid is shut slowly
Jun 03, 2008 | Kenmore 24032\24036 Top Load Washer
Hot water wont shut off
solenoid valve is jammed open
replace
Mar 31, 2008 | Kenmore 24902 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
83 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
