Question about Hitachi 43FDX01B TV
I have a bend horizontal red
I have a bend horizontal looks like the red upper and lower parts of the screen.... is it worth fixing? if so what is a fair price to pay?
    Genius:
  • 1,153 Answers
Convergence problems, sounds like you need the kit.
Posted on Dec 22, 2007
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
My SAMSUNG PPM42M6H screen has horizontal grainy lines at the top of screen measuring about 7 inches and from right to left. Lower half seems OK. What should be done or replaced?
Check the ribbon cables in side the TV that connect to the panel. They are the left side looking at the back. Make sure they are all seated propporly. If that does not fix, then your Upper Y Buffer board needs to be replaced.
Apr 10, 2012 | Samsung PPM42M6H 42 in. Plasma TV
JVC PD-42DX6BJ plasma 42 inch black horizontal lines over the pic
Here's a link to order the original the JVC upper Y-buffer board and lower Y-buffer board for this model from a major parts distributor if needed:
JVC "PD-42DX6" Replacement Part Upper Y - Buffer Board (LJ41-02760A)
JVC "PD-42DX6" Replacement Part Lower Y - Buffer Board (LJ41-02761A)
Based on the symptoms: It is possible that the Y-buffers are faulty, which may require the replacement of the Y-sus board as well. You may want to get a local technician to diagnose the unit and provide a second opinion.
Apr 01, 2009 | JVC PD-42DX6 42 in. Plasma Television
Bowed flickering green screen, black on bottom
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 25, 2009 | JVC AV-48WP30 48" Rear Projection...
I have a Phillips Magnavox Model number 42PF9936D/37. A red pixel looking 2" X 7" rectangle has appeared on the plasma screen and can be seen underneath the image. How can I fix this?
We chatted previously, remember to reseat the cables that go to the section of the screen that is distorted. The Y drive boards will be on the left side of the tv (when viewed from back) and there will be about 8 ribbon cables hooking these board to the plasma panel. If you can, look at each square black chip on the board. Each chip drives the picture (row - horizontally) so one chip may be blown causing your issue. It will likely have a small pin sized hole burned in it if bad. You can replace the corresponding board (upper y, lower y) to fix the issue. Hopefully reseating the cables will do it, for a part free fix. Let me know when you get the TV open and I'll assist more. Thanks again!
Dec 09, 2008 | Televison & Video
Red horizontal convergence PT-47WX49E
converge outputs getting tired or limiting resistors opening up. adjusting this incorrectly will make the situation worse keep in mind that overdriving these chips will cause a fold over of your image when you see this carefully adjust in the opisite direction as you may be overheating the outputs
Oct 08, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence
did u do a repair in recent days
by replacing the convergence ICs?
Jun 18, 2008 | Toshiba 43A10 43" Rear Projection...
RED LINE
If the line is vertical in nature then most likely then the plasma display panel is bad and won't be worth fixing because of cost. If the line is horizontal then the issue might be a lower or upper Y-buffer module.
Jun 08, 2008 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Samsung HPR4252 with red horizontal lines accross the screen
I just had my HP-R4252 repaired on 12.05.09 with a similar problem. The picture is covered in horizonal, broken lines and the color is predominately red. They lines are grouped together in large bands across the screen.
The tech replaced the Y-Buffer boards (Up) and (Low) in about 20 minutes.
Samsung BN96-02034A BOARD, Y BUFFER UPPER ASSY
Samsung BN96-02216A BOARD, Y LOWER BUFFER ASSY
Feb 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Hitachi 43FDX01B TV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
