Question about Bally Total Fitness Exercise Ball
I have a model 1092 bally blackjack pinball mach.The problem is that when I press the switch in the coin board the machine keeps adding up a score in goes from zero score to max and back repeating this. And it gives credits. I cant control flippers or any thing else. I have a very large schemaic for the unit.I have training electronics repair.
  • 1 more comment
  • LARRY WOODING Oct 04, 2009
    I have a bally model 1092 pinball machine eletro. mech. The is when I press the start button on the coin panel the score numbers keep spinning & the solonoid in the coin door keeps activating.
    I have a bally model 1092 pinball machine it is an older model electro. mech. HAS NO PC BOARDS.The problem is when I push the game start switch the numbers on the display board keep cycling 0 to max and back again. Also The solenoid in coin board keeps cycling.Lights on but nothing else works
  • LARRY WOODING Oct 09, 2009
    Ihave a bally model 1092 blackjacj pinball machine which is a E/M made in 1976 no pc boards. The problem I have is when I start it up the all the lights come on & the # one player numbers keep cycling and wont stop until I turn the game power off. Nothing else works.
  • 1,861 Answers
I have worked on quite a few Ballys. One of the most notorious for the same issue you speak of was the old Delta Queen.
Before you do anything else, take a good long look at the rotating unit, in the center of the lower mechanical panel. I will bet you that some of the fingers that hit the make/break contacts are not breaking the contact. The fingers all register to the side board relays, which resets the back unit. Once you isolate the fingers/contacts that do NOT break when the center unit cycles, you are on the path to getting her fixed.
Posted on Oct 09, 2009
    Sergeant:
  • 247 Answers
I have an 8-ball deluxe machine,work on it as much as i play it,bee a while scince i worked on any other models,if i understand correctly ,when you start a game it automatically racks up points continuously,is that correct?
Posted on Oct 04, 2009
  • todd gentile
    todd gentile Oct 04, 2009
    if so ,try to determine the increment in whitch the score is rising,look for a target in the playing feild that scores that amount,the contacts may be stuck,there may be more than one of them doing it,flipper buttons are usually common fail spots,cleaning the contacts helps for a while,but eventually replacement is required,check continuity through it when depressed,hope this helps,if i didnt understand the problem,post me a comment,and ill try to help more,at least you have a schematic,thats half the battle,aloha from maui todd0708
    President:
  • 1,564 Answers
Sounds as though a thyristor is at fault and is allowing only a weak signal to respective diodes which cannot respond correctly
    President:
  • 1,734 Answers
This game has some self diagnosis tests implemented. You will need to run them before doing ANYTHING. See the procedure attached:
Hi. I have a 1964 Happy Tour Bally EM Pinball Machine. This is basically the same as the Grand Tour machine. It won't reset.
Hey Bill, if you have facebook, look up Tilt (Bar in toronto canada). the owner may be able to help you if you message him.
Jan 14, 2017 | Video Game Consoles & Games
My whitewater pin keeps on blowing fuse F114. display read check fuses F114/F115. Changed 114 but keeps on blowing.
Pinball problems are commonly discussed on pinball forums. For your case go to http://pinballbash.com/forum/index.php?topic=2526.msg23570#msg23570 and look for a very long append from VisitorQ. He gives a nice detailed description of the possible causes.
Aug 22, 2016 | Game Room Guys Flipper Opto Board Williams...
I have a 1966 Williams Cassnova pinball machine that is seems to be locked up. What can I do?
You need to describe what you mean by "locked up". If you mean mechanically locked and you don't have the key then you will probably have to drill out the lock. Sometimes people will screw a spare key under the cabinet but if so consider that a lucky find. If you mean electrically locked up such that you turn it on and it does not initialize correctly then you need to describe exactly what it does. Quite often these old electro-mechanical models will go into an endless loop trying to reset the score reels to zero. Even if they display all zero's the machine might not be detecting it properly. If so you can open up the back (also called the head) and clean each and every switch with a business card (to clear accumulated carbon from the contacts. The score reels are removable. If you are not up to this you can go online to a pinball forum (like www.pinside.com ) ask for a local pinball repair person. You would be surprised at how many of them are out there.
Apr 11, 2016 | Video Game Consoles & Games
My mr and mrs pacman pinball machainght flipper not working what should I look for?
Bally uses an end of stroke blade switch for their flippers. Lift up the playfield and look for the blade switch associated with the right flipper. If there is a wire off or they are broken then resolder it or change them and it will be fixed. If you don't see any problem then put a jumper across the connection and see if it works. DO NOT LEAVE IT ATTACHED. If it worked then change the blade switch. Other possibilities are a bad solder connection on the Solenoid driver board or a bad flipper coil itself. Hope this helps
Dec 07, 2015 | Video Game Consoles & Games
IZE FUSES GO INTO A BALLY STRIKES AND SPARES PINBALL MACHINE
There are several fuses. All are 3AG size. On the Rectifier board you need:
F1=10 Amp 32V
F2=3/4 AMP, 250V SLO-BLOW
F3=4 Amp, 32V
F4=5 Amp, 32V
F5=20 Amp, 32V
F6=3 Amp, 32V SLO-BLOW
On the solenoid driver board you need:
F1=3/16 Amp
Nov 01, 2014 | Video Game Consoles & Games
All balls shot out
I need to know what machine are you working on? Different era machines have different answers.
Feb 08, 2014 | Bally/Midway/Williams Video Game Consoles...
Im looking for a 1978 bally's fireball manual
Bally made Fireball in 1972 and 1976
They made Fireball II in 1981 and
Fireball Classic in 1986
some of the manuals can be downloaded for free
from the net just search IPDB on the web
Aug 10, 2013 | Video Game Consoles & Games
1976 Gottlieb Buccaneers Pinball Manual
The reason for this behavior (constantly running but not starting the game) is that the machine is trying to reset to score reels to zero. They may actually go to zero but the switch that tells the machine that they are in the zero position is either dirty or out of adjustment.
It is a very common problem with electromechanical pinball machines. The switches are located on the score reels in the backbox.
Jul 26, 2013 | Video Game Consoles & Games
I have a ballys mr &ms pacman pinball machine and the sound works sparaticly , will come on random and work fine for 5 mins or so then just cuts out for 10 to 20 min nothing i do will make it come back...
I have a eralier 80's upright Bally's Pac Man arcade machine that I got off a freind of mine. They said that they palyed it all the time up to about a year ago. I got it home set it up and pluged it in... and nothing happens. I've hit the start buttom on the inside and the new game button but still nothing... Is there something else that I may need to check?
Oct 02, 2010 | Arcade Ms Pac Man / Galaga Cocktail Table...
Bally coin slot machine wont let the handle pull
THIS IS DOCTOR FIX. MY BUSINESS IS GAMING REPAIR. (JUKE BOX=PINBALL= SLOT MACHINES
BOWLING =POKER, FOR 68 YEARS.) IF YOU HAVE NOT SOLVED YOU PROBLEM, I ASSUME IT IS ELECTRONIC, NOT MECHANICAL. IF MECHANICAL , LET ME KNOW, I WILL TELL YOU WHAT TO DO.
ON THE ELECTRONIC, OR ELECTRIC (NO COMPUTER)
THERE IS A BAR MOVES ON TO THE CAM ON TOP OF THE CATCH, ABOUT 3 INCHES ABOVE THE BOLT THAT HOLDS THE ARM IN PLACE, WHEN A COIN IS INSERTED INTO THE COIN SHOOT, THAT METAL BAR ENGAGES THE RATCHET , TO SPIN THE WHEELS. DOES THAT HAPPEN ON YOUR SLOT.? OPEN THE DOOR PULL THE WHITE SWITCH THAT CLOSE WHEN DOOR IS CLOSED (OUT) THESE ARE A THREE POSITION SWITCH.
IN-HOME JUKE BOX REPAIR
SEYLEVITT@JUNO.COM
HOPE IT HELPS.
May 03, 2009 | Bally Walk In 9 8"" X 19 3"" X 7 6"" high...
Bally Total Fitness Exercise Ball Logo
107 people viewed this question
Top Bally Sport & Outdoor - Others Experts
Are you a Bally Sport and Outdoor - Other Expert? Answer questions, earn points and help others
