Question about Kenmore 24032\24036 Top Load Washer
Water fills slowing in washing machine, kenmore ultra fabric care
Takes a long time for water to fill up in machine, load takes about four hours
    President:
  • 1,776 Answers
Check the water inlet valve. If there is a problem it can cause a slow fill condition. Unplug the machine, turn off the water and remove the water supply hoses. Check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris. The solenoids can be tested using a multimeter or ohmmeter. A lack of continuity means a bad solenoid and the valve assy will need replaced. I will attach a photo for reference. Hope this helped and best wishes.
Posted on Oct 04, 2009
I have a kenmore ultra fabric care 80 series washing machine.. it will not stop filling up with water.. I have to turn off the water or it will over flow. it is very used machine... Please Help...
most likely a problem with the diaphragm of the water shutoff solenoid
diaphragms are available or get a complete unit
if it has hot and cold solenoids ( hot and cold water hoses ) and you are not using the hot just swap the hoses over and only use the hot water settings
that way the cold water comes in through the hot water solenoid
Nov 18, 2016 | Kenmore Washing Machines
KENMORE 22442100 WONT FILL UP WITH UP WATER
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Aug 23, 2010 | Kenmore 22422 Top Load Washer
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
Kenmore 110 Top Load Washer-cold water fills extremely slowly
No it is probably the screen that is either in the end of the hose that attaches to the machine, and/or the screen is placed so that the cone is toward the machine instead of pointing away from the machine.
If the cone is pointing towards the machine any debris in the lines would collect and eventually fill the screen cone and slow or shut off water flow.
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Front Loading machine, does not drain the fabric softener
We had the exact same situation with the fabric softener not draining and here is how we fixed it. Turn the water off first, then remove the water lines that bring water into your washer. (They are near the top.) There is a screen in the end of the line, do not remove it, but take an old toothbrush and brush the gunk out and clean it as best you can. Do both the hot & cold sides. The screens keep any debris out of the washer, so after a while it collects and slows down the water intake time (has your washer been slow to fill also?) Screw back the lines, making sure to put the hot and cold back as they were originally, then test that they do not leak. Put your washer back in place and viola - problem solved! I hope this works for you, and good luck!
Sep 03, 2006 | Kenmore 44102 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
142 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
