Question about Dell PowerEdge 4600 Server
It takes thity minutes to power down the server
When I shutdown the system to reboot it takes almost thirty minutes for the system to power down. Any suggestions
    Problem Solver:
  • 5 Answers
In the SCSI configuration (firmware), ensure write caching is enabled. Ensure that it is only enabled WHEN SAFE.
Do NOT pull the power before it shuts down cleanly. At best, you'll have file corruption; at worst, you're facing a complete rebuild. I'm currently 36 hours into a recovery / repair /rebuild job of a domain controller that was running on one of these. Yicky. At least I've recovered all data (not bad on a RAID 5 array where the pratition info was toasted) but it cannot be repaired - at least they have a backup I can start with here.
Posted on Jun 07, 2009
  • 209 Answers
Is it carrying a lot of "load" ?
Try cleaning it somehow.
thats all I got
hope it helps
Posted on Dec 22, 2007
  • Simon Zwaan
    Simon Zwaan Jan 23, 2008
    Please rate, or respond with more details.
Dell server shutdown
Try using OMSA, which is Dell's Server Administrator. Specifically for hardware and errors.
https://servername:1311 You require a local admin or domain account to login.
May 20, 2013 | Dell PowerEdge R200 Server
I forget bios password for HP DL160 G6 server, how do i reset the password ?
  1. Shutdown your server.
  2. Go inside the server, and remove the CMOS battery. It should look like this.
3. Be sure to power down your server before taking it out. Be aware that once you take this out the system will forget a lot of it's time settings. This is the battery that keeps the computer's memory of time, date, and BIOS password when it's shutdown.
Apr 14, 2013 | HEWLETT-PACKARD HP ProLiant DL160 G6...
Server Randomly Reboots
First, go to Dell's website and update all the firmware and install the latest version of Dell Server Administrator. DSA has logs information not logged by Windows. Next, take it outside and blast the fans with compressed air, make sure all components and cables are properly seated in their slots/sockets, turn it on with the cover off and make sure all the fans are spinning. Many servers will increase the fan speed if they detect the cover is off so this is another possible cause to the problem.
Finally, Dell servers have lifetime support, this number should work: (800) 945-3355
BTW: A temporary workaround might be to use a network controlled outlet that you can remotely turn off and on. Your UPS might be able to turn outlets on and off or you could get a stand alone network controlled outlet. Some can actually ping the device and turn power off and on again if it stops replying to pings. (E.g. IP Power EV-9255 IP
Mar 04, 2013 | Dell PowerEdge T300 Server
My desktop shutdown after several minutes, reboot it again but it shutdown again. reboot again but same thing happen, pc shutdown. what is the problem?
That's like stating my car was going down the road, then suddenly died. What is the problem?
Open the hood, take a look. Maybe it's something obvious.
Same thing with a computer.
1) Computer unplugged from power, open the computer case. See if the Processor fan is dirty, and the computer case fan/s.
If so use a can of compressed air for computers, and clean.
BEFORE you reach inside your unplugged from power computer, observe Anti-Static Precautions ]
2) See if there are Electrolytic Capacitors on the motherboard.
Bad capacitors for the motherboard voltage regulator circuit, will cause rebooting.
How to identify bad capacitors,
The motherboard Voltage Regulator Circuit,
(Starts at 0:04)
3) Power Supply
Weak Voltage power rail. Caused by failing Electrolytic Capacitors.
(Radial Aluminum Electrolytic Capacitors)
Sep 04, 2010 | MSI Computers & Internet
Battery backup I have a server running 750watts powersupply, has intel xeon 1.6 (2 x quad core) 2 scsi drives, 4 SATA drives and 4gb ram. Will 1300 watts battery backup be enough?
I have a similar setup on my Small Business Server and an 1100 Watt backup. It will run my server for 30 to 45 minutes and sends the signal to shut the server down when power gets critical so my server will do a clean shutdown. I've replaced the battery once in 3 years so I would say the 1300 Watt UPS will be sufficient to operate your server for a short period of time before doing a clean shutdown. (You may get an hour or so out of it before it shuts your system down). Be sure it has either a serial or usb connection to keep your server apprised of its status.
Mar 05, 2010 | Computers & Internet
The server will not fully power down. It attempts to (sputters)and then the fans just run and the lights on the front just flicker, no alarms. AMI Megaplex 2 mother board 2816 MB ram DB 960 2...
We would issue remote shutdown commands and sometimes
the system wouldn't completely shutdown and it went into the undead state.
Anyone connected to the machine still worked but no new connections allowed
and no access to the console. Found out from Microsoft the shutdown command
isn't the greatest and so I wrote a VBScript that has resolved the issue.
This isn't the greatest code in the world, I should correct it so the values
are all defined in the variables section but use it if you find value to it.
Option Explicit
' Program - RemoteReboot.vbs '
' Author - Paul Bergson '
' Date Written - 08/15/07 '
' Description - Is a more drastic remote reboot '
Dim OpSysSet
Dim OpSys
Dim strComputer
Dim iMsg
Dim iConf
Dim Flds
Dim strSubject
Dim strHTML
on error resume next
strComputer = WScript.Arguments.Item(0) 'Get server name
If WScript.Arguments.Count = 1 Then
Set OpSysSet = GetObject("winmgmts:{(Shutdown)}\\" _
& strComputer _
& "\root\cimv2").ExecQuery("select * from Win32_OperatingSystem where
For Each OpSys in OpSysSet
Wscript.Echo "Server Name required. Reboot operation Aborted!"
End If
'Send out an e-mail on the reboot
set imsg = createobject("cdo.message")
set iconf = createobject("cdo.configuration")
Set Flds = iConf.Fields
With Flds
..Item("") = 2
..Item("") =
End With
strHTML = strComputer & " has been automatically rebooted by YourServerName"
& " on " & FormatDateTime(Date(),1) & ", " & FormatDateTime(Time(),3)
strSubject = strComputer & " has been rebooted"
With iMsg
Set .Configuration = iConf
..To = "Notification" ' Destination e-mail address
..From = ""
..Subject = strSubject
..HTMLBody = strHTML
End With
set imsg = Nothing
set iconf = Nothing
Jan 27, 2010 | AMI MegaPlex II 9U (S657820000000) Server
Dell PE1800 psu wont swith off...Computer powers down but psu fan continues to run. Have to pull the power plug to shut it down.
Sounds like the PSU is overheating. Some PSU's are designed to keep the fan running to cool it down even after system shut down. I would let the fan run after shutdown to see how long it takes to shut itself off. If there are no environmental issues tat are causing overheating you might want to consider replacing the PSU.
Sep 13, 2009 | Dell PowerEdge 1800 Server
APC UPS 1500 w/full load forces immediate reboot at pwr failure
With a 980watt load the run time is only 7 minutes on a brand new battery. If you have the system on full load your run time will be much less and it has likely damaged the battery. here is the APC web site page for your model. If you are running that much equipment I think you need either a bigger UPS or another 1500 and spread the load out.
Corporate Computer
Jul 24, 2009 | APC Smart-UPS 1000VA UPS System
Override laptop automatic shutdown after inactivity
Easily done! Right click your desktop and choose Properties. Select the Screen Saver tab and at the bottom choose Power. In the Power Schemes drop down box choose Always On and the PC will never turn off. You might also want to disable or set the time higher for your screen saver.
Please rate this solution accordingly. Thanks for using
Jan 10, 2009 | Dell Latitude D600 Notebook
Xerox Fiery Xp12 - Problem (INVALID LICENCE) apears on the screen
You will need to use what came with your machine.
The note from Xerox states this.
NOTE: You will need the Fiery Restore / Update Server Software CD and the User Documentation v2.0 CD that came with your EX12 v2.0 Software
And here is the loading process
  1. Visually check to make sure the Fiery LCD is at the Idle screen before you proceed. This will make sure the Fiery is not in use.
  2. Insert the Fiery Restore / Update Server Software CD into the Fiery EX12.
  3. Press [Menu] button on the Fiery Server.
  4. Press the [Down arrow] button.
  5. Press the [Shut Down] button.
  6. Press the [Reboot System] button. The message 'Rebooting System' will display and disappear after a few moments. The Fiery Server will reboot and complete internal testing. The Restore / Update CD menu will be displayed.
    NOTE: Ignore the message 'It's now safe to power off the system'.
  7. Press the [Up arrow] or [Down arrow] button to scroll to 'Restore System' so this is highlighted. Press the [OK] button. The 'All data will be Deleted. Continue?' message will be displayed.
  8. Press the [Up arrow] or [Down arrow] button to scroll to 'Yes' so this is highlighted. Press the [OK] button. The 'Restoring System...' message will be displayed.
    NOTE: The System Restore will take approximately 7 minutes, during this time the message 'Restoring System...' will continue to be displayed.
  9. Press the [OK] button when the 'Restore Complete!' message is displayed.
  10. Press the [Up arrow] or [Down arrow] button to scroll to 'Exit' so this is highlighted. Press the [OK] button.
  11. Remove Fiery Restore / Update Server Software CD from the EX12.
  12. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
    NOTE: Wait 10 seconds before powering ON.
  13. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  14. The EX12 will prompt you to insert the User Documentation CD. Insert the CD and the Fiery will continue with the process. When the process is complete, the Fiery LCD will display the message 'Please remove CD'.
  15. Remove the User Documentation CD
  16. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
  17. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  18. Using the Configuration Report as reference, re-enter the network settings on the EX12.
  19. Install any required patches, as needed. Refer to the Updated Information section on the Configuration Report.
  20. If needed, restore any data that you previously archived. See the Related Items.
Jan 10, 2008 | Xerox DocuColor 12 Printer
Dell PowerEdge 4600 Server Logo
150 people viewed this question
Alun Cox
