Question about Porter Cable Tools & Hardware - Others
Looking for operating instruction for porter cable model 5014 planer attachment
2 Suggested Answers
SOURCE: Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
Posted on May 06, 2009
Please help me find a free owners manual for my porter cable 352vs belt sander
The ServiceNet site has the manual for most Porter Cable power tools here: http://servicenet.portercable.com/ . The 352VS documentation is here: http://servicenet.portercable.com/Products/Detail/352VS . Look in the right hand column for the Instruction Manual; you'll see an option to download a PDF or have the manual sent by email. However, you need to look at the sander and attempt to find the Type number. This will be on the label with the model and serial number. There are 7 different belt sanders that were released with the 352VS model number. Use this number to get the details for your sander. The direct link to the manual for the Type 1 version, today, is http://servicenet.portercable.com/Products/GetDocument?docName=EnA00111.pdf&productId=55856&productType=12187&documentId=32863&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/Porter-Cable/EnA00111.pdf .
I hope this helps.
Nov 20, 2015 | Sander Tools & Hardware - Others
Need to find Delta 12 1/2 " Planer Instruction Manual # TP305
Porter-Cable/Delta has the manual at their Servicenet support site: http://servicenet.deltaportercable.com/Products/Detail?productNumber=TP305 . The link is on the right under downloads (the last item in the list).
I hope this helps.
May 29, 2011 | Garden
I need instructions on how to replace a new set of power planer blades for Makita 3 1/4 inch power planer
find your model number and go to "makitause.com" and you can download the operators manual with detailed instructions for this repair. REMEMBER to unplug tool before starting. If you give me the model number I will help but they had 2 different types of holders on the planers so I can't begin to help. Let me know.
Apr 09, 2011 | Makita Tools & Hardware - Others
I have a Porter Cable door planer with carbide tip blade and it has a small notch from a conceiled finish nail on an old door.The blade is still good.I would like to know how I can sharpen it.
Hi, these blades are made to fine tolerances, so I would not attempt to sharpen it. But they are also double sided. Just undo with the appropriate allen wrench and flip it over. Good luck!
Nov 15, 2010 | Porter Cable 9118 #126 Porta Plane Door...
We did not receive any instructions with our Porter Cable Finish Nailer Model # FN 250 C. The store can not help us out, can you email me instructions at donanddinah@shaw.ca
Here's a link you can go to, and downloads owners manual in PDF file .
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/N027636,DA250C.pdf
Nov 03, 2010 | Porter Cable 16 - Gauge Finish Brad Nailer...
Operating Instructions for Router model 890?
try going to Dewaltservicenet.com and typing in your model number in the middle of the site towards the botttom will pull up a schematic on this and you should be able to download an owners manual from there also.
Jun 27, 2010 | Porter Cable 8901 Router
Need a new planer blade 43233
after 5 hours searching on Google and Yahoo I settled for blade 43263 which was a lot more expensive
Nov 28, 2009 | Porter Cable 9118 #126 Porta Plane Door...
I need operating instructions
Here is a direct link to your owners manual. You can print it if you want a hard copy or you can order one from porter cable.
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=65507&typeId=14816&documentId=30657
Hope this helps.
Richard
Mar 09, 2009 | Porter Cable Porter-Cable 4216 12" Deluxe...
Tools & Hardware - Others Logo
27 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
