Agitator not spinning
We have a Kenmore 80 series washer. It is presently full of water and obviously wet clothes. At some point the agitator stopped spinning and just does a clicking sound.
    President:
  • 1,304 Answers
Agitartor stripped
you can order the dogs at sears
agitator dogs
Posted on Oct 05, 2009
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
My ken,ore 80 series washer agitates ok and seems
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Two things to check.
It sounds as if the tub isn't getting full power from the transmission for spinning and/or the pump/hoses are damaged or blocked.
1. Remove the cabinet.
See the following.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=7777818c689b6ece38ca9884721fffc7
and check the hoses / pump.
2. If they are OK, the problem may point to the Motor Coupler. See the following for how to check it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
3. If the pump and Motor Coupler are OK, the problem could point to the clutch.
See the following for how to pull the pump, motor and transmission.
You don't have to remove the tub!!
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the clutch bands are worn, you don't have to replace the entire clutch. Sears / Whirlpool have a band replacement kit, a lot less expensive and easier to install than a new clutch.
Jan 17, 2010 | Kenmore Washing Machines
Kenmore 80 series washer clothes are still dripping wet
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 16, 2009 | Kenmore 24032\24036 Top Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Kenmore 80 series won't spin
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
Jan 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
237 people viewed this question
Top Washing Machines Experts
