Question about HP C6280 All-in-One Printer
C6280 all-in-one printer stuck in shutdown
I am trying to shut down my C6280 all-in-one HP printer and the screen says "Shutdown" and has for a few hours now. I would like know if anyone has a solution for this problem.
  • 169 Answers
SOURCE: HP C6180 - IMPROPER SHUTDOWN
Not a big problem,try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Posted on Jun 20, 2009
ThiruBulls
  • 103 Answers
SOURCE: My HP C6180 is caught in a start up loop...
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Posted on Aug 21, 2009
  • 4 Answers
SOURCE: HP 6150 printer shutting on and off
Open the unit up, you'll probably find a capacitor inside that doesn't have a flat top like mine. Replace that one from your electronics supply store, usually very cheap.
Posted on Aug 30, 2009
57 varieties
  • 1653 Answers
Do the following with a USB connection if possible.
You will need to completely uninstall the application ad drivers (see below) tehn reinstall the driver & application. You can download the latest version from HP Support at the following link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1153494&lc=en&cc=us&dlc=en&lang=en&cc=us
Make sure that you chose and install the correct version for your operating system.
If this persists then it would be a very good idea to uninstall the HP drivers and application then to run a Registry clean using the Ashampoo toll (free of charge for 30 days from www.ashampoo.de) to make sure that all instances of the driver and application have been removed so as not to cause any contention between drivers and applications. Then reboot the PC and reinstall the application from scratch.
Posted on Sep 23, 2009
SOURCE: HP PHotosmart c6150 keeps shutting on and off
You need to reset the printer. I had the same exact problem with a C6150. Unplug the power cord from back "while printer power is on" (doesn't have to be fully booted just turning on). Wait 20 seconds, hold # and 6 keys together and plug power back in. Continue to hold until power goes off or semi-reset message comes up. Power up (if off) press OK for any error messages and let the printer cycle. Should be good to go. Mine sounded very noisy while it was trying to allign internally. I can only suspect that was the initial problem but this process fixed mine and it runs great now. Hope this helps.
Posted on Feb 11, 2010
My printer will not shutdown
un plug it, wait a minute then turn back on... it should then do as its told...
Jun 30, 2012 | HP Photosmart C6280 Printer
Printer hp c6280: error message "oxc18a0401" what
Please perform the following steps SWITCH ON THe PRINTER.ONCE THEERROR COMES in the display screen DO THE FOLLOWING Press and hold the * key.
Press the # key and release both keys.
Display should say Enter Special KeyCombo
Press and release the button one by one in sequence the 1, 2 and 3 buttons.
display screen says "support" R0631M.
Press and release the right arrow button until the display says System Configuration Menu.
then Press and release the OK button.
Display should say Hardware failurestatus. If not there already, ArrowKey over to Hardware failure status
Press and release the OK button..Display should say Hardware failure status: Clear. Press OK to clear.
Press and release the OK Button. Message changes to Hardware failure statusCleared. Press Cancel to continue.
Press and release the CANCEL button as many times as necessary, so that, eitherthe Welcome to Photosmart Express screen appears, or, the Ink System Failurescreen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable fromback of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cableinto the wall outlet first and then into the back of the printerTurn the unit on. The printer may display message USEPOWER BUTTON TO SHUTDOWN THE PRINTER followed by PRESS OK TO CONTINUE. PressOK. The Printer will start the ONE TIME INK INITIALIZATION PROCESS. Allow thisprocess to complete and do not interrupt. Once the initialization process iscomplete, the printer will print out a Diagnostic Page.
Aug 01, 2011 | HP Photosmart C6280 Printer
Launch start up repair
Im not sure if you are wanting to get to start-up repair or trying to get rid of it
If you want to access it, Boot system and do a hard nshut down. Restart, you will have the option to Launch start up repair or to start windows normally
If you are getting the option screen unwanted, this is primarily due to improper shutdown.
Whenever you shut down always try to use shutdown, restart options in taskbar.
If in the event you are stuck and need to do a hard shutdown try pressing Ctrl/Alt/del simultaneously
to access task manager.
Here you can end processes hung up or do a proper shutdown
Jun 22, 2011 | Toshiba Satellite Pro L300 Notebook
My HP laptop won't switch off. I am stuck on a black screen and the green light won't go off.
Hold down the power button for a few seconds, and that should force the laptop to shut off entirely.
Now if this is a reoccurring issue, then I think there might be something wrong with the operating system. Some files might have gotten corrupted that prevents the operating system to complete the system shutdown.
Good luck.
Oct 18, 2010 | HP Pavilion dv1000 Notebook
HP Pavilion PC blue screen shutdown and startup problem
the blue screen is known as the Blue Screen of death
refer to this article
http://pcpills.blogspot.com/2009/05/escape-blue-screen-of-death.html
Aug 07, 2009 | HP Pavilion tx1000z Notebook
C6180 All-in-one: On-off loop never stops
while the printer is on remove the power cable from the printer then press # and 3 on the printer together and then while pressing the buttons insert the power cord n then leave the buttons
if still problem persists then try the same thing by pressing # and 6
Jul 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer wont shutdown after paper jam
After removing paper jam, which may have been caused by using typing paper,which was a much lighter weight,computer was shut down,on startup printer had shutdown,no further problem.
Jun 14, 2009 | HP Photosmart C5180 All-In-One InkJet...
Wireless printer stucks laptop
installing an auto update fixed this problem
May 25, 2009 | HP J4680 Office Jet All-In-One Printer
HP C6280 All-in-One Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
