Question about Simplicity SL370 Mechanical Sewing Machine
First time user simplicity sl 370
Fisrst time try to use a simplicity sl 370 serger.The loop is not forming.Any sugestions?
  • MARVALYN Jan 05, 2008
    THE SCREW IS MISSING FOR THE NEEDLE.
RickE1
  • 202 Answers
SOURCE: problems threading a Europro serger
Probably the needle hit one of the loopers and left a burr on it that is catching the thread. Run your finger nail acroos the edges of the loopers. If you find a burr it can be polished off using very, very fine crocus paper from a hardware store.
Or the needle hit a the upper looper and knocked it slightly out of position.
After you have it threaded (correctly) turn it slow by hand and watch the loopers very closely. You will probably see what is happening.
Posted on Dec 12, 2008
  • 1116 Answers
SOURCE: just got a used simplicity serger how to use and
Sergers are used to finish raw edges.
Not the best choice for quilting and purse making.
Posted on Apr 06, 2010
Tally Girl
  • 1133 Answers
SOURCE: I need a manual for a Simplicity Easy Lock Serger
You can purchase a manual for this machine from the following link for $US14.99
http://www.sewingpartsonline.com/instruction-manual-simplicity-sl4300.aspx
I can't see it anywhere for free download unfortunately. But you may find that looking at a manual for another 4 thread overlocker may get you started. If you try this link http://www.singerco.com/accessories/instruction-manuals you can look at the free Singer downloads,
try this link for their 654 3/4 thread model http://www.singerco.com/uploads/download/555_14sh644_654-(e_s_f)-(new-led-version).pdf
it may give you some help now.
Essentially, to change the stitch width you can either move the lower fixed blade wider to cut less fabric or tighten up the upper and lower looper threads in order to close up the stitching.
Moving the blade usually means opening up the front cover door, putting pressure on the upper blade and swinging it up out of the way. Then you can adjust the lower blade, usally by turning a knob near to it. Sometimes this knob will be marked 1, 2, 3.
Adjusting the looper tensions is done by changing the tension dial settings for the thread needing adjusting. If its a standard four thread overlocker that produces a "marrow" seam it will have two needles and two loopers, upper and lower. Generally on most overlockers, the upper looper will be the second from right tension dial and lower looper will be right most tension dial - turn up one half number to tighten, or down one half number increment to loosen, then test stitch again. The needles shouldn't need adjusting too often.
I usually start with all tension dials on 5, test stitch, then adjust from there. Some fabrics will tunnel (pull in) if the seam is too wide so you need to either move the blade to the left and trim more fabric or loosen off the loopers. Or in the reverse, like you are getting, the threads will hang off the edge.
There is some good serger information on Debbis Cosgrove's pages www.sewing.about.com but if you have never used a serger, then getting the genuine manual is probably best.
Posted on Oct 17, 2011
99rannellis
  • 12695 Answers
SOURCE: FREE Manual for my Simplicity easy lock sewing machine serger SL 850.
Search for:
Make Model manual
Posted on Apr 26, 2017
My serger singer finishing touch will not make a loop... unthreaed all and rethread and still same.. is it my tension and/or dials...??
Could be the machine is out of time. Be sure to try new needles, but if the threads still do not form a loop, then it may be time to take it for service.
Feb 22, 2017 | Singer Sewing Machines
The serger will not form the initial chain. Have checked threading and have new needles, any ideas?
It's an odd thing but on my serger, it actually matters the order in which I thread it. I *try* to tie the new thread to the old and pull it through rather than re-threading, but when I've had to re-thread, I've had trouble getting it to loop again when I thread left to right. It seems that the loopers only loop if the right looper is threaded before the left.
Apr 16, 2015 | Sewing Machines
I need to know how to oil a simplicity serger-easy lock-with differential feed
I have a Simplicity serger SL880 that was my mothers. She past away about 8 years ago. I was trying to use it but appears the motor may be locked up that moves the feed dogs. Is there a place to oil it? If so where? Thank you.
Apr 18, 2011 | Simplicity Serge Pro SW432 Mechanical...
Simplicity SL370 Mechanical Sewing Machine Logo
62 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
