Question about Delta Faucet Delta 172-WF Waterfall Single Handle Kitchen Faucet with Matching Side Spra...
How to clean water marks on delta facuet
Water marks on facuet
  • 129 Answers
If you get 0000 steelwool, This will polish like new without scratching.
Posted on Oct 04, 2009
After trying to use sprayer in kitchen sink, now facuet will not work
The Faucet may be clogged with dirt, or screen is clogged.
Nov 15, 2013 | Plumbing
1992 Reliance electric water heater model 501 has two 4500 watt heating elements , there is no hot water.
Check the breaker and top thermostat and make sure they are not tripped. Move onto replacing elements if above is not the problem.
Turn water and power off to heater and attach a water hose to bottom of heater to drain down tank. May have to open hot side on a facuet to get it to drain.
Once drained remove elements with 1 1/2" found at local hardware stores. once elements removed and new ones in place. Turn water on and get the air out of the system. Once water is flowing from the hot side from all of facuet's in house.
Once all air is out now yaou are resady to turn power onto heater.
Oct 09, 2010 | RELIANCE ELECTRIC WATER HEATER
Price Pfister tub/shower facuet needs much force turn on and off
put water off at mains . step 1.-open your i box mixer. step 2-u will see a 2 mm pin. mabe yours looks difrent. bt there were u change between bath and shower that button... that nob wil have a pin at the back. try to put q20/oil in there or sope. if that dosent work u will have to get a plumber in to unscrew the mixer and clean out the inside. not recomended if not a plumber bt if u do wane try it ur self and the sope and oil dident do the job let me know im a plumber will walk u threw it
Jul 04, 2010 | Price Pfister 07-81PC Savannah 2 Handle...
Hot water: Pipes make a banging noise when turned on full force.
Hi, That banging is sometimes called a water hammer. It is made when the water hits an elbow in the piping with a force and bangs into the pipe itself. It is more likely to occur in a long run of pipe. This can be reduced or eliminated by installing an empty tube verticle in the piping near where the hammer is occuring. This tube can be found at most building supply stores. The tube is a pocket of air that acts to absorbe the extra pressure from the piping and stops it from hammering.
May 05, 2010 | Delta 2 Handle Lavatory With Metal Pop Up...
Hi my delta single hanlde tub/shower facuet is leaking hot water bad
If its a ceramic cartridge type then replacing cartridge is called for, HOWEVER sometimes cheaper to replace complete tap.
If not ceramic then turn mains off and replace the washer inside.
Jan 08, 2010 | Delta Classic, Single Clear Knob Handle...
THE SCALDGUARD ALLOWS VERY LITTLE HOT WATER HOW TO CHANGE TO BEABLE TO FILL TUB I HAVE A DELTA#T13220 I CAN'T THE HANDLE OF EITHER
You probably need to adjust the faucet to give you hotter water.
The other problem can be low water pressure... if your cold water pressure is low or there is a restriction in the line, it willl also restrict the hot water flow.
Follow these instructions to pull the whole valve assembly out and check the water flow of the cold water with out anything in the valve body. This will tell you if the problem is in the piping of the valve.
http://www.everyfaucet.com/Delta-T13220-DLT2970.html
Page down to near the bottom and look for the PDF attachments. They will give you the details you need to take the faucer apart and amke the neccesary ajustments.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 09, 2009 | Delta & Single Handle Shower Faucet
Leaking hot water from delta single handle facuet
I have to assume you've unscrewed the face plate, not removed it, because you can't do that without taking the handle off. Delta handle usually come off by unscrewing an allen (set) screw just under the handle itself. Sometimes these are covered by a plastic plug.
Occasionally, even after you've completely removed the set screw, the handle still won't come off. Wiggling and pulling for a few minutes will generally get it off. If not, then a hacksaw, new handle and new cartridge are the answer.
If the allen screw is stripped and that's why it won't ome off, see above.
Good Luck.
Aug 26, 2009 | Delta & Single Handle Shower Faucet
Hot water stopped working Cold is OK
may be the new facuet see if the hose is clogged detach it from the sink turn on the water and see if it comes out into a bucket if it does than its your new facuet
May 12, 2009 | Plumbing
Tub faucet
You will need to turn of the water and remove the handle, then remove the large brass or chrome ring behind the center sleave that is behind the handle. now that ring is what holds the cartridge in the valve body, you will need to remove the cartridge the rubber seats and springs will both need to be changed ,you can buy a rebuild kit for this facuet, it has everything you need even the o rings you will find in there . Hope Ive Solved your problem! Thanks
Dec 12, 2008 | Delta T13420 Chrome Classic Single Handle...
Delta Faucet Delta 172-WF Waterfall Single Handle Kitchen Faucet with Matching Side Spra... Logo
54 people viewed this question
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
