Question about Denso Nippondenso RS232
I have a Kenworth T-2000 and the clutch pedal stuck down and hard to push
  • 3 Answers
Sounds like a lack of proper lubrication to your clutch linkage pivot points very common issue, few people know they are there
Posted on Feb 14, 2011
  • 31 Answers
Sounds like your Clutch has failed.
you can also unhook the linkage at the clutch arm on the trans and make sure the linkage is free
Posted on Aug 10, 2010
Where do I lubricate a creaky clutch pedal on a 2014 Kenworth T800?
Spray Lithium grease at the clutch pedal pivot under the dash. But chances are the clutch pedal plastic bushing is deteriorated and the noise will quickly return.
Jul 14, 2016 | Cars & Trucks
2000 kia sportage stuck in low gear.brakepedal very hard to push
check for a vacuum leak at power brake booster and or vacuum line at transmission if good follow hoses back to engine and check connections there
Sep 22, 2015 | Kia Cars & Trucks
On a 2000 Ford Focus my clutch is stuck in the pedal won't go down
The focus clutch system is hydraulic therefor, if no movement is possible at all it is most likely that there is something at the pedal causing this. Get down there with a good light and look if the pedal swivel pin did not come out or is partially out, a foreign object that got stuck in the top movement area of the pedal ect. If there is nothing found it can be the clutch master cylinder that need repair/ overhaul.
Mar 27, 2015 | 2000 Ford Focus
Why is my clutch pedal stuck down?
Return spring is likely missing
Apr 24, 2014 | 2000 Alfa Romeo 156
Please. Break pedal are stuck Dow and can be moved. Husqvana 2000. M-2000 YTH21K46
As you are pushing down the pedal use your hand to release the pedal lock lever. Or a belt popped off the drive pulleys and is binding the idler pulleys. Or so much grass has accumulated on transaxle its binding brake/Clutch pedal.
Jul 26, 2013 | Garden
1969 Kenworth Dump Truck. Not much movement in brake pedal. Does not appear to have air to the pedal. All other air works fine.
Spray brake pedal (treadel valve) With WD-40. May have to remove foot pedal and rubber boot work up and down with pliers until moves freely.
Apr 14, 2013 | Cars & Trucks
Heavy clutch 2000 megane scenic 1.6
your pressure plate is stiff if you want it softer replace the pressure plate
Apr 07, 2013 | 2000 Renault 181
When clutch depressed starter motor dosen't work
try to move the floor mat out from under the clutch pedal and push clutch all the way down. if it starts then adjust clutch switch. if not then a full diagnosis of starter system is required
Apr 10, 2010 | 2000 Hyundai Elantra
Push clutch down and it is now stuck down
Hi, just lift the pedal back up by hand. This usually cures the problem in the short term but usually you will need to have the clutch master cylinder replaced at some point as the problem will occur more and more regularly. I'm pretty sure that VAG have a modified part now.
Hope that helps Matt..
Nov 23, 2009 | 2000 Volkswagen Beetle
Stuck clutch
The clutch has rusted to the flywheel drive the truck down the road you will have to start it in gear (1st) while driving push the clucth pedal to the floor and keep pushing up and down on the gas pedal to get the truck to rock forwards and backward the clutch should brake loose.
May 29, 2009 | 1991 Toyota 4Runner
188 people viewed this question
Top Denso Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Denso Office Equipment and Supply Expert? Answer questions, earn points and help others
