Question about Logitech Harmony One Advanced Universal Remote with Color Touch Screen
Logitech Harmony One remote is controlling 2 TiVOs at once.
I have a Logitech Harmony One remote that is sending signals to 2 TiVOs (Series 3) in the same room. Doing something on one TiVO will inadvertantly cause the other TiVO to do things as well. This is a problem as the second TiVO gets shows deleted from it and stops recordings and changes channels. My husband thinks it possibly has to do with the TiVO codes and thinks the Harmony One might be sending code 0 (the universal override code) to both units. The TiVOs are each set to different codes and we have no problems using the separate remotes for them. I've tried reinstalling the software on the remote and it didn't help. How would I fix this?
    Novelist:
  • 101 Answers
Please try learning the some commands from one of the original remotes for thr tivo. If this fixes the problem, i suggest that you learn all commands from that remote.
Launch the Logitech Harmony Remote software and login to your account
1. Click on the Devices tab
2. Click on the Learn IR button for the device you want to learn command(s) to.
**NOTE: When learning new commands, there are three different options available:
-You want the Harmony Remote to learn a single command that is already listed in the software
-You want the Harmony Remote to learn more than one command at a time
-You want the Harmony Remote to learn a new command, which is not listed in the software
a. Click on the Learn button next to the command you want to learn - Proceed to Step 5
a. select one or more commands by clicking on the check box next to the command(s) you want to learn and then
b. click on the Learn Selected Commands button
c. Proceed to Step 5
You want the Harmony Remote to learn a new command, which is not listed in the software:
a. Scroll down to the button of the page
b. In the Learn a New Command box click on the text MyNewCommand
c. enter the name of the command you would like to teach.
d. Click on the (Learn New Command) button
e. Proceed to Step 5
5. Follow the onscreen directions for learning commands, plugging in your Harmony remote when asked and lining up your original remote to the Harmony as illustrated on the screen.
6. When a command is successfully learned, a check mark will appear next to it. If learning more than one command, the software will then prompt you to learn the next command.
7. The commands that were learned should now be identified as from "Your original remote" and highlighted in turquoise.
8. When you have finished teaching the commands, click Done button to save your changes
9. Click on the Update Remote button to update your remote
If this does not work, try :
To teach commands for your Device that did not work properly in normal mode:
1. Click the Devices button on your home page.
2. Select the Device you wish to learn commands to.
3. Select Learn Infrared Commands.
4. Click Custom. The page will reload.
5. Select the boxes for commands you would like to teach, and click Learn Selected as Raw.
NOTE: When teaching each command, press the button on the original remote for as long as required to control the device. The commands will be learned with the exact format that is sent by the original remote.
If you have any trouble teaching the commands in RAW, complete the following steps:
1. Verify you are pointing the original remote at bottom end of your remote, and are holding the remotes 2-4 inches apart.
2. Minimize the amount of light that could interfere with the learning process by covering the distance between the remotes. Block out sunlight, or turn off the lights.
3. Check that you have installed new batteries in the original remote you are trying to use to learn commands. If the batteries are low, the signal coming from your original remote may be too weak for the remote to detect.
4. Be sure to hold down the button on the original remote for at least 1-2 seconds, otherwise the signal may be too short for the remote to process.
5. If you continue to have trouble teaching the commands, start with the remotes 2 inches apart. Then try again with, slightly increasing the distance each time (2.5 inches, 3 inches, etc).
6. Vary the angle at which the original remote is pointing at the bottom of the remote.
7. Ensure the device's original remote is sending infrared (IR) commands.
NOTE: The original remote is sending RF or UHF commands from the original remote if it will control the device from another room, through a wall).
Posted on Jan 21, 2010
My logitech harmony 550 remote control went into safe mode. How do I get it out of safe mode?
1. Remove the batteries. 2. Press and hold the 2 button on the remote while connecting it to your computer. 3. The Harmony Remote LCD screen should display "Upgrade Success" 4. Unplug and test. If that doesn't work check your remote for stuck buttons then proceed to re-install the firmware on your Harmony Remote.
1.Remove the batteries from your remote 2. Massage each button with your thumb. Press down firmly to ensure that no buttons are stuck down NOTE: Stuck buttons may not be easily visible. It is important to massage every button regardless of its appearance. 3. Re-insert the batteries into your remote. 4. Launch the Logitech Harmony Remote software and login to your account:
  1. Click on the "Downloads" button
  2. Click on the "Firmware" button. Follow the onscreen instructions to upgrade the firmware on your Harmony
  3. Once completed, you will be prompted to update your remote. Please do so. If you were not prompted to update your remote, you will need to. Click on the "Update Remote" button and follow the onscreen steps
  4. Un-plug the remote from your computer and test
Apr 09, 2010 | Logitech Harmony 550 LCD Remote Control
How do I reset the harmony 670 logitech
do a firmware upgrade. this will restore your Harmony remote to factory settings.
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Mar 08, 2010 | Logitech Harmony 670 LCD Remote Control
My 550 remote stopped working. The light under "activities" goes on, the bastteries are good, but nothing else works. Please help!
Please try re-installing the firmware.
Jan 24, 2010 | Logitech Harmony 550 Remote Control
The Logitech Harmony 890 has locked-up on the PVR screen. Any way to reset?
Jan 09, 2010 | Logitech Harmony 890 LCD Remote Control
No display on LCD screen on Logitech Harmony 520 remote
Try this.
Jun 14, 2009 | Logitech Harmony 520 LCD Remote Control
Logitech Harmony 550 will not respond.
Apr 22, 2009 | Logitech Harmony 550 LCD Remote Control
What is a ?????
The RF extender is a add-on device that communicates with the Harmony 1000 remote. You would actually hook up IR eyeballs to your equipment and then plug them into the RF extender. This allows you to have your equipment in a cabinet or closet and have the door shut. The Harmony 1000 sends RF signals to the RF extender and the RF extender sends that signal to the components. This way you don't have to point at the components to control their operation.
Hope this helps, if it did please indicate with vote.
81
Feb 14, 2009 | Logitech Harmony 1000 LCD Touchscreen...
Changes 2 channels at a time
I can help you with your Logitech Harmony 890 remote control.
The Logitech Harmony 890 remote control is programmed through the
Harmony Windows Setup Software.
I recommend resetting it up with your components to get rid of the two channel problem.
Once installed, you will simply run the program and select the devices you would like to control from menus. This program finds the right codes for you and loads them into your remote control.
You can get a copy of the Harmony 890 Manual by clicking here.
I hope that helps.
_____________________________________________
Harmony 890 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Harmony MAC Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Nov 25, 2008 | Logitech Harmony 890 LCD Remote Control
2 remotes....same problem
try a firmware upgrade if a firmware upgrade doesnt work, try e-mailing them from www.logitech.com go to contact us and send an e-mail:
Apr 04, 2008 | Logitech Harmony 880 LCD Remote Control
Logitech Harmony One Advanced Universal Remote with Color Touch Screen Logo
540 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
