Question about GE Ovens
I own a whirlpool supercapacity 465 oven/range top ... oven is not getting warm enough to cook ( max 250 F instead of 500F max temp) what could be wrong with it?
    Scholar:
  • 53 Answers
Replace the oven sensor, then the oven controller.
Posted on Oct 04, 2009
Our Whrlpool Super capacity 465 oven will only let you preheat to 260 degrees. After 260 the display showing rhe temp. will not advance any higher. It will still broil when you push the broil setting but...
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Whirlpool oven, however if you could post the complete model number I can speak directly about possible remedies instead of generalizing...
**Though it may not be necessary as I believe your disply may be set to Celsius (centigrade, like Canada and Europe) instead of Fahrenheit since 260C equals 500F thus it tops out at 260...most ovens will not exceed this temp unless in a self clean cycle.**
I suspect if you refer to your operator/owners manual it likely will instruct you how to change it back to display the temperature in Fahrenheit.
Thank you for choosing FixYa. I'll need to watch for your reply before moving forward.
Regards,
Macmarkus :)
Apr 28, 2011 | Ovens
My oven will get a little warm but it will not get hot enough to cook anything.
make sure that the bottom is actually coming on andnot just the broil portion... fi it is indeed coming on then sounds like the thermostat is bad on unit... usually is a temp probe that comes into back of oven or in the rear side ranging from 2 inches to 4 inches in length..the temp prob will go back to the control ...i would start there...good luck to you
Jan 09, 2011 | Whirlpool Ovens
Whirlpool Super Capacity 465 oven won't turn on
My Whirlpool Super Capacity 465 oven
Mar 15, 2010 | Ovens
Temp cycle span from on to off is 32 and 33 degrees respectvly
Obviously the thermostat calibration is out, most manufactures allow a tolerance of + or- 10%, so yours is outside this range.
You can compensate by setting the temperature lower by say 20 degrees, this will then bring it within accepted tolerances.
Hope this helps you.
Dec 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
Turbochef toaster oven cc temp on warm up only 265 deg ir 465
if your a commerical oven tech then just call 1-800-90turbo are you getting an error code i would probably check the convection circuit first starting with the blower motor and checking if the Windings are ok
Dec 12, 2009 | TurboChef TORNADO Electric Oven
Can't locate 110v outlet on Whirlpool Supercapacity 465 model #RS368LXKQ
there is no 110 volt accessory outlet on this model
Sep 23, 2009 | Ovens
Breaker flipped on my oven while cooking a turkey
If the oven was still slightly warm to the touch when you came home is probably fine. 45 minutes was not enough time to get the turkey hot down near the bone, so if it was cool I would discard it. But if you were lucky and it was still warm, go ahead.
Sirwriter - (Smoke and barbecue tons of chickens and capons)
May 16, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Ovens Logo
126 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
