Question about Acer Computers & Internet
Water was poured on the laptop - Acer Computers & Internet
  • 403 Answers
I'm sorry to tell you that your computer is most likely ruined. You can try turning your computer opened upside down so any water can drip out. Do this for a couple of days. Then us a blow dryer on medium heat to blow dry it. Make sure that the blow dryer is far enough back as not to get the laptop to hot. Remember your just trying to dry any moisture still in the lap top. Do not power it up until you do this as you will fry your components. Sorry for your bad luck. You might consider craigslist as you can get some good deals.
JimmyC
Posted on Oct 04, 2009
    Sergeant:
    Champion:
  • 208 Answers
Ouch, you really should pull the battery and disassemble the laptop and dry the component ASAP. Water is really bad for your laptop. You didn't list the model, so can't help you with the disassembling instruction, but in general, the disassembling starts with the top.
How do you get a bunn pour omatic coffe maker to pour water into the hopper. I put water where it's supose to go it heats up but no water come out. Is there something I'm not doing. Its an older one.
did you pour in another pot of water? It heats up the reserve tank so you always have hot water instantly, but to get that water you need to pour in another pot of water to replace it.
Manual:
www.bunn.com/sites/default/...manuals/10424.0000.pdf
May 12, 2016 | Bunn Coffee Makers & Espresso Machines
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
My dell laptop doesn't power on due to some water poured on it
Damage to the motherboard I would look for a replacement laptop.
Dec 13, 2013 | Computers & Internet
HOW DO I CLEAN THIS COFFEE POT
I suggest you use vinegar acid.
You need a solution with half part water and half part vinegar acid.
1) pour 4 cups of water into your coffee machines water tank.
2) pour 4 cups of vinegar acid into your coffee machines water tank.
3) turn on your coffee machine to decalc.
4) refill tank with clean cold water and let it run through ( 2 times)
REMEMBER !!! ALWAYS POUR ACID into WATER !!!! AND NOT THE OPPOSITE !!!
If you pour water into acid it can explode and make terrible damages and cause chemical burns!!!
Hope this will help ypu
Jun 28, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
Water pouring out the vent back into the reservoir...
i have a water problem but mine is .. when i turn the machine on it just starts pouring water out and does not stop.. and the machine still says not ready all the time the water is pouring out.. anybody know how to fix this ??
Jun 20, 2010 | Keurig Elite B40 Coffee Maker
Pour water intu laptop
any laptop technician may fix this. However, at some points the keyboard can no longer be fixed.
Nov 11, 2009 | IBM Lenovo ThinkPad T400 7417 Notebook
Water keeps pouring into ice maker and doesn't shut off.
does water come into cabinet if the icemaker is unplugged? if so, the water valve is leaking thru and needs to be replaced
May 06, 2009 | Refrigerators
Anyone solve the pitchers in puzzle 78
1) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher. (leaves 7 litres in Pitcher 16)
2) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher. (leaves 2 litres in Pitcher 9)
3) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
4) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
5) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 5 litres in Pitcher 16)
6) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 4 litres in Pitcher 9)
7) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
8) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
9) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 3 litres in Pitcher 16)
10) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 6 litres in Pitcher 9)
11) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
12) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
13) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 1 litre in Pitcher 16)
14) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 8 litres in Pitcher 9)
15) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (Pitcher 16 also has 8 litres)
YOU NOW HAVE 8 LITRES IN THE 16 & 9 LITRE PITCHERS.IN 15 MOVES.
Apr 24, 2009 | Nintendo Professor Layton & the Curious...
Water gets hot but doesnt pull water to grounds
It sounds like the tank isn't full. Unplug the machine and make sure there is a pot underneath to catch water. Pour clean water into the tank until it starts flowing out. Plug the machine in and let it heat up. Then try brewing coffee.
The way your machine works is that there is a holding tank for the water and it isn't actually brewing with the water you just poured in, it is using the holding tank water. If the holding tank gets low, and you pour water in all it does is fill the tank but nothing will come out.
Hope this helps.
May 13, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Computers & Internet Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
