Question about HP OfficeJet 6110 All-In-One InkJet Printer
Adding this printer - HP OfficeJet 6110 All-In-One InkJet Printer
    Scholar:
  • 53 Answers
Hi, perform the steps below if you are usinf Windows XP Operating System:
1. Click on 'Start' button.
2. Open 'Settings' option and Select 'Printer and Faxes' option.
3. Click Add a printer. This launches the Add Printer Wizard.
4. Click Add a local printer.
5. Use the drop down arrow to select the port. Click Next.
6. Select the Manufacturer of your printer and the model. Click Next. If your printer is not listed, click the Have Disk button. You’ll need to locate the manufacturer-supplied drivers on your computer or disk.
7. Type in a name for the printer. This is the name that will appear under the printer icon in the Printers folder. Click Next.
8. If you want to print a test page, click the Print a test page button. Click Next.
9. Click Finish
Posted on Oct 04, 2009
When adding the printer on a mac, get the message "unable to verify the printer on your network."
1. Remove the printer in System Preferences ' Print & Scan
2. Added the printer, again
3. Under the IP tab at the top of Add Printer, I chose the LPD option to the right of Protocol, instead of IPP
Aug 06, 2013 | Kyocera FS1370DN Laser Printer
Kyocera FS-2020D adding toner screen will not shut off
It is normal to do this "adding toner" operation aprox. 20 minutes. You have to wait until the printer enters in "ready" status. Take a little brake and relax, your printer needs to refill the developer unit with toner dust from the cartridge.
May 10, 2012 | Office Equipment & Supplies
The printer is added but the scanner isn"t
Might be the driver cd not supporting the OS,..down load the full feature drivers from hp site,install it & check..
Oct 04, 2011 | HP LaserJet 3030 All-In-One Printer
HP Photosmart c6380 wireless printer works fine, but windows xp does not recognize the scanner
  • First, we need to create the Ad hoc network that will provide wireless connection between your computer and printer. On the right hand portion of the Taskbar, you can right-click the wireless icon and choose "View Available Wireless Networks". Or you can double click the wireless icon, then click "View Wireless Networks". It is also accessible from the Control Panel. Either way, the same window as shown in step 2 will pop-up.
  • 2
  • setup-xp-via-ad-hoc-1.2-120x120.jpg View Wireless Networks The Wireless Network Connection window shows you all the wireless networks in range including the network where you are connected. If you have many neighbors with wireless networks, it will all show up. Click "Change advanced settings" and it will bring up the Wireless Network Connection Properties window. Choose the "Wireless Networks" tab and at the bottom click "Advanced" button.
  • 3 setup-xp-via-ad-hoc-1.3-120x120.jpg Wireless Networks Properties From the Advanced option window, choose "ad hoc" networks only. This is just to simplify the process. You should also bring this back to original setting after you are done connecting via Ad hoc. You may choose to skip this step if you wish and you should still be able to make the connection without a problem.
  • 4 setup-xp-via-ad-hoc-1.4-120x120.jpg Create the ad hoc network Click the "Add" button and type in a name for your Ad hoc network. Make it more intuitive so you can easily recognize your own network just in case there are other Ad hoc in range. Check off the automatic key and enter a 5 or 10 digit network key. This is the same key that you will input at the printer later. Click OK and then OK again. You are now connected to the Ad hoc network. You are half way through.
  • 5 setup-xp-via-ad-hoc-1.5-120x120.jpg ad hoc network Make sure the printer is ON as well as the wireless radio button. On the printer control panel, press the setup button to access the menu. Go to Wireless Menu and press OK. Press the arrow to go to Setup Wizard and press OK so the printer will automatically search for wireless networks in range. From the list of networks, find the SSID or Ad hoc name that you created and press OK and type in the network key using the alphanumeric keypad on the printer. The printer should confirm the connection in less than a minute. That's it! Try to print a test page to make sure everything is working properly.
  • Dec 06, 2010 | HP Photosmart C6380 All-In-One InkJet...
    Printer wont install when I plug in the USB cable.
    New printer would only works with the driver supports from the manufacturer only. THis is for higher printer.
    May 11, 2009 | HP Photosmart C4180 All-In-One InkJet...
    Computer slow since adding hp 7280
    turn of printer when it not in use , to make ur pc fast download reginout intel partner to make it fast to some extent
    Mar 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    Adding IP addresses to a HP 5550 DTN printer
    ok then install that printer as a network printer to one pc share ti and ad to as much pc you need after that without ip adress
    Dec 10, 2008 | HP 5500 Color Laser Printer With Internal...
    Printer ok scanner not ok
    If you have added through the add printer wizard you have added jus the printer software.....try to install through the software cd that came with it....
    Please dont forget to vote
    Cheers!
    Nov 13, 2008 | HP Photosmart C3180 All-In-One InkJet...
    Printer can not be added
    delete the printer from the printer and faxes.
    reinstall the printer from add printer.
    Oct 08, 2008 | Lexmark JetPrinter Z55 InkJet
    HP OfficeJet 6110 All-In-One InkJet Printer Logo
    95 people viewed this question
    Seeker5211
    Seeker5211
