Question about Ovens
OVEN STAYS HOT
I WOKE UP THE OTHER MORNING AND MY OVEN WAS STILL HOT FROM THE PREVIOUS NIGHT'S DINNER. THE DIAL WAS TURNED OFF, SO I HAD TO SWITCH THE BREAKER OFF TO COOL THE OVEN. WHAT WOULD CAUSE THIS?
    Sergeant:
  • 186 Answers
This is somethig you should have checked by technician.Till then turn the oven off then pull straight out on the knob removing it. use a plyers to check if it's actually turning off by turning it to the left. If it does turn to the left( off position) you may just need a new knob.
Posted on Oct 04, 2009
Cooling fan came on without oven being on
There is an electronic device that bring the fan on when the oven is hot. Sound like it went flaky, as it still under warranty I would get it checked oout.
Jan 21, 2014 | Belling Ovens
Neff electric oven stays hot after turning off
This is normal...there is a cooling fan built in to your oven designed to cool the facial controls when hot and can take some time to cool to an acceptable temper?ture that's why you can feel the air blowing,, usually above the oven door...if you switch off at the mains you are risking the plastic components on the facial melting. Just leave it to Run it is a very low wattage motor and costs very little to run
Oct 10, 2017 | Ovens
Used our Whirlpool AKZ451 last night and everything was fine, but this morning, the small centre button on the front panel will not press. All the dials are set to '0' and the screen displays STOP. Usually...
the same has happened to mine. i used it last night as usual and this morning the button just wont press?? did you manage to find out what was wrong?
thank you x
Aug 08, 2010 | Whirlpool AKZ159IX Oven
My oven is saying "stop" . Previously to this is was showing F02 and the fan wouldn't turn off. We turned the main switch for oven off and back on and it now says "stop"
Previous fault F02 is indicating an overheat fault- service manual says to replace main electronic control board. However, switching off at wall has reset the clock- you need to set the time before the oven will work-press middle button until small triangle is next to clock icon, set time using temperature dial. Once clock has ben set, try using oven to see if F02 fault reappears- sometimes switching off at wall will clear fault. Good luck!!
Mar 16, 2010 | Whirlpool AKZ159IX Oven
My oven display is beeping and blinking 'PBR' on the display. What does that mean?
I had this same problem last night.. I have been having problems with the oven shutting off on preheat.. That sort of stopped. Last night lost power to the house. When it returned the oven was beeping and flashing PBR. I turned off the breaker for a few mins. last night and it returned. It was bugging me so much that turned it off the whole night. Woke up this morning turned the breaker back on and it stopped. I don't think this is the total solution. I am thinking that eventually I am going to have to replace power board in this oven. Hope it works!
Sep 23, 2009 | Jenn-Air Ovens
Oven won't turn off
I have a Kenmore model 665.95802 . When I turn the oven dial off , the broiler stays on and on the display you see the code F3 E2
Mar 02, 2009 | Kenmore Ovens
Amana oven
'F1' means the electronic control has failed. No way to stop it except turn off power.
Jun 09, 2008 | Amana Ovens
Display doesn't work, but oven works
First turn the electricity off by locating the breaker to the oven and turn it off. Now wait for an hour or so and turn the breaker back on, if the display turned back on, you need a control board (other manufatures call it a clock, PCB or ECC but it's the main elctronic board with the diaplay built in). If it didn't come back on, turn the power off again and make sure all the wire harness's going to the board are connected good. Turn the power back on and it the display still doesn;t come back on you need to replace the main electronic control board. By the way double check the model number and brand because it might be wrong. Please post back.
Oct 04, 2006 | Whirlpool RBD275PD Electric Double Oven
Ovens Logo
105 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
