Question about Refrigerators
My Jenn-Air refrigerator has a lot of moisture inside of the fridge part.
    President:
  • 1,304 Answers
Inspect your door gasket, make sure its closing tightly all the way around,
are you putting food in that has a hight temp than 90
Posted on Oct 04, 2009
I am finding brown flakes behind my whirlpool refrigerator. Why is this happening and how can I stop it? There is no ice or water dispensor on my refrigerator.
Hi Aaron !
I believe the brown flakes you are finding are coming from evaporated condensation. Let me explain ! As warm air and product hold more moisture then cold air or product when the door is opened and closed cold air in the fridge falls out and warm or ambient air replaces it. ( warm air rises and cold air falls ) The refrigeration process has an evaporator on the inside that is essentially colder than the temp you are maintaining the fridge at. Moisture is drawn out of the air and product and freezes to the evaporator thus drying the air in the fridge. When the compressor cuts out and the ice melts the moisture goes down the drain pipe and either collects in a container on top of the compressor or in a tray that has heated pipes from the refrigeration process through it. The moisture is then evaporated and leaving only the impurities of the air, dust and/or wet spills in the fridge. If you have a fan under you fridge or a breeze goes through there it is easily disturbed. Not a lot you can do as it is a part of the process. Wipe up spills, reduce door open times and keep door seal cleaned with warmed soapy water. Check fridge is level and square and doors close tight. Hope this helps tiger !
Apr 22, 2014 | Whirlpool Refrigerators
Water is leaking out the bottom of my brand new Jenn Air French door model JFC 2089 HE. Why?
likely a lot of condensate has been collecting in the catch tray, and it hasn't been able to evaporate off. You may have to slide the fridge out, and empty the tray by hand.
Nov 02, 2009 | Jenn-Air JFC2089HE French Door...
I have a Jenn Air refrigerator JFC2087HRS. The freezer compartment is working, but the fride is not working.
check the inside fan if no air blowing in to fridge fan may be frozen/blocked on need repair/replacement if fan working damper in fan duct may be closed or blocked
Oct 14, 2009 | Jenn-Air Refrigerators
Condensation in refrigerator even in the morning
Are the temps in the fridge and freerzer as cold as they should be? The air circulates through the unit and the moisture is taken out in the freezer by the evaporator coils. If they are not cold enough the moisture won't be taken out. The freezer fan has to run to do this and the damper (vent) between the freezer and fridge has to be open. A door not closing good and leaky door gaskets will cause excess moisture.
Aug 19, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn-Air Refrigerator JSD2789AES broken shelf support studs
part number is AP4069509 this fridge is such ****! i still need three parts
Dec 24, 2008 | Jenn-Air JCD2389G Side by Side...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air side by side fridge, leaking from the freezer
I'm not 100% sure here.. but I suspect you might have moisture in the lining of your fridge.. Not a good thing. It may mean your heater (to keep moisture out of the lining) is faulty. In that case it's quite difficult to fix.. The ice up in the lining is probably not due to a drip-pan. Sorry I haven't answered your question, but thought it worthwhile mentioning the other possibility. PS most drip-pans sit on top of the compressor under the fridge, accessible from behind the fridge. Usually there is a drain tube down to the pan. This can sometimes get blocked up & may need some cleaning solution like white king (bleach) pored down it, to get rid of mold or whatever's blocking it.
May 06, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Jennair JCD2389G side by side
Can you tell where in the unit the buzzing is coming from (top bottom inside outside, etc)? Need a little more information to help.
Dec 04, 2006 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
