Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
No water coming out just hooked up hose checked filter but nothing coming out
    President:
  • 1,304 Answers
If it new you need to hold the button for several moments to fill the resivoir tank inside
depending on the model it may take 2-mins of time holding the water button
Posted on Oct 06, 2009
When my Kenmore machine is running on the wash cycle warm/warm no water is coming at all. I could run the machine only with cold water even on the cycle warm/cold.
Most likely the hot water hose is plugged up, or least likely, the hot/cold valve is broken or plugged up.
Find a large container, or better yet, hook up a garden hose that you might try the faucet where the hot water is hooked up and see if water will come out of it when the washer hose is not hooked up there.
If it will not, you have a plugged up hot water pipe or the water heater shut off valve is closed.
If you get good water pressure and hot water from the faucet, look at the filter screens that are inside the ends of the hot water hose and see if any are plugged up.
There may be several.
If not, perhaps the inlet water solenoid has failed. That plastic part is where the hoses attach to the washer itself.
God bless your efforts.
Jan 22, 2016 | Kenmore Washing Machines
Engine working fine, but water not coming out
Couple of things, is the water supply good? if that's a yes, then check to see if there is a way to engage / disengage the pump, some models offer that, if engaged and good water supply, then it has to be your pump
May 31, 2014 | Briggs & Stratton Briggs Stratton 2550...
Water dispenser beep-beep
I am wondering about the hose you shoved in and the leak stopped. Is the hose you pushed in buckled where it hooks on or is there a buckled spot where the water comes out of the fridge. Just a guess.
Mar 03, 2017 | Hotpoint HSS25GFP Side by Side...
No cold water coming out
Check where the hose connects to the washer sometimes their is a screen filter in their. If not the valve that controls the water input could be bad. Most of those valves are where the hoses hook to the washer.
Aug 22, 2012 | Hotpoint WMTL79 Top Load Washer
Whirlpool frontload WAsher. After I run a load, the clothes come out fine. Several hours later there will be an inch of water in the tub. 10 hours more there are 5 inches of water. I have checked the...
It sounds like the water inlet solenoid valve at the rear of the washer where the hose hooks up is leaking, more than likely the cold water valve.
Jan 31, 2012 | Whirlpool Washing Machines
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
Water goes thru. have hydrulic oil to level. gun semas to stick on. NOT GETTING ANY PRESSURE AT NOSSEL.
Hydraulic oil?
Is this a pressure washer?
Pump should be half full of SAE20 or SAE30 non-detergent motor oil.
Engine should have 10W30 motor oil.
If you have a pressure washer ... and not water is coming out end of gun:
Take all hoses off machine.
Look at incoming water hose connection.
The should be a filter washer.
Clean or replace filter washer.
Hook up water and turn on water.
Turn on power washer and see if water coming out of pump is pressurized.
Now hook up pressure hose without gun.
Turn on pressure washer and see if water comes out of hose and is pressurized.
Finally, the gun may be bad.
We used to replace guns when they went bad.
Oct 24, 2010 | Dewalt 3800 PSI Pressure Washer
No water coming out when I backwash. I cleaned
water level must be about the discharge (eyeball) in the pool to back wash. Check the hose connections to make sure that hoses off the the filer head are going to the right place Look for the words "Pump" , "pool" and "waste" molded into the valve. I've seen it a number of times where "Pump" and "pool" were connected the wrong way.
Jul 04, 2009 | Hayward SAND FILTER, PRO SERIES
Water lne plugged
Remove spray tip and clean with a paper clip, Check pump oil resevior and add 10w 30 pump oil if needed, also look for turn knob ,usually black with -+[plus /minus symbols ] and turn towards plus for extra pressure. May need new pistol/wand assembly and make sure hose is clear by seeing if water will run through hose freely and generously.
Thanks cnbode and please vote me a Fix Ya!!!
JJ505
Apr 12, 2009 | Garden
No Ice or Water
The water inlet solenoid valve orifice may be plugged. Locate the water solenoid valve where you connected the water line to. Shut off the water and then check this orifice and screen.
Apr 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
43 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
