WASHER WILL FILL WITH WATER, BUT WILL NOT DRAIN
Washer will fill with water but will not drain. Then it makes a humming noise like it is trying to drain and spin but nothing happens. It smells like something is burning.
  • 70 Answers
The bearings are bad if it is an older unit you are better off buying a new one
Posted on Oct 04, 2009
Ge GTWN2800D1WW washer wont fill on start but will do drain and spin cycle....help
What do you mean? It not fill up or no water is coming in?
Did you hear some humming noise?
Check the input water tap... close be closed or blocked...
Dec 01, 2015 | GE Washing Machines
When i close lid it just makes humming noise and wont start
If washer hums but doesn't fill, water isn't getting to washer check screens where fill hoses connect to washer. Screens may be blocked. If washer fills then hums check to make sure belt is on. Tip machine up to view belt underneath.
Sep 26, 2013 | Maytag Ensignia MAV2757AWW Top Load Washer
My Electrolux washer will not drain water or fill water, it will spin. It is also making a humming noise
You need to check for the Humming noise as this can be the indicator to the problem, if this comes from the motor then the capacitor is faulty. Failure to switch on the INLET and the DRAIN pump can be related to fault in the control panel or this can also be due to faulty electric line voltage on the outlet.. So please check this out.
Also check the inlet and drain filters for clogging as a clogged drain pump can also hum.
Jan 12, 2013 | Washing Machines
Washer just shuts down
If the washer is turning off mid cycle then the problem most likely has something to do with the draining or the filling.
First check the drain hose is not to far down the standpipe. If it is to far down then the water might siphon out during fill. The water would fill and drain at the same time. One cycle I would like you to try is the "Rinse Only" cycle. This is a simple, short cycle that should just fill once, drain and spin. If the washer will do this then the major components are most likely okay.
Make sure the water drains out and let me know if the drain pump is the source of the noise you hear.
Oct 19, 2012 | Washing Machines
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
The washer makes a humming noise....sounds like it is trying to drain. Is there a screen or filter that could be clogged? Also, it defaults to pause.
i dont think it was making any noise it was trying to fill with water and it was leaking could the spring be used to attach the rubber seal to the drum?
Jul 30, 2009 | Frigidaire GLTR1670A Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool LHW0050PQ - Water wont empty or fill
This sounds like a plumbing problem. Lets see if we can isolate it. Turn the valves off behind the washer and remove them from the washer. Remove the washer drain hose from the stand pipe. Stuff one of the hoses into the now vacant drain line and turn the water on. Then do the other hose. Any noise? Now reconnect the fill hoses to the washer and reinstall the drain hose to its' place. Turn on the water valves at the wall, set the washer to a cold/cold cycle and start it up. Listen for noise. Now shut the machine off and set it for a hot/cold cycle and turn it on. Listen for noise. If you get no noise now, it's all good. If you're getting noise from just your hot water, your water heater is set too high and you have steam propagating in your plumbing. Your washer water valves (where the hoses connect to your machine) will only do this if you have low water pressure coming from the wall. Still, it'll be a plumbing problem.
Jul 28, 2007 | Whirlpool LHW0050PQ Front Load Washer
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
