Question about Dryers
Gas Dryer will not heat
I have a Kenmore Gas dryer that I bought back in 1999. About 8 months ago I had the same issue. I replaced the igniter and that solved the problem. I assumed the igniter went bad again. So I bought and installed a new igniter. That didn't solve the issue. It still will not ignite the gas.
Ge gas dryer is change a new coil e the gas dryer no heat.thanks
Posted on Oct 29, 2008
I replaced the thermal fuse and it fixed the problem. I had to remove the blower housing cover on the front of the machine to get to the thermal fuse. There was was an incredable amount of lint in there that I cleaned out. I used one of those lint brushes on a regular basis to make sure the machine is clean. That brush doesn't do a very good job. My wife said that the clothes dry about 10-12 minutes faster.
Posted on Dec 26, 2007
Kenmore 300 gas dryer..not getting hot only nine months old
Hello there:
If your dryer doesn't heat, check these: IIgniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Sep 26, 2010 | Kenmore Dryers
Dryer doesn't get hot enough to dry clothes
Hi
Thanks for using FixYa. The first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. If this I fine then you’ll need to check the thermostat, igniter and coils. Also as its only 3 months old so it is recommended to use the warranty to avoid any further issues. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Samsung 7.3 Cu. Ft. 7-Cycle Gas Dryer -...
Kenmore dryer thats not drying
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | Dryers
Kenmore gas dryer wont heat up
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Aug 11, 2009 | Kenmore 73952 Gas Dryer
No heat burner comes on for a few minutes and then goes out
Check the following to address this issue.
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 02, 2009 | Kenmore 72062 Gas Dryer
No heat
the most common problem is the thermostat if its bad the dryer thinks its overheated you can us ally jump them however its not recommended because of safety issues
Apr 30, 2009 | Dryers
Dryer does not glow or lite up but it runs
I just diagnosed the same problem with my estate model by wirlpool. It is most likely the thermal fuse located in the back (behind the panel) It is a $12.00 part. My neighbor fixed his father's unit with same issue 2 weeks ago.
Mar 07, 2009 | Whirlpool LGV4634JQ Gas Dryer
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
KENMORE GAS DRYER - MYSTERIOUS HEAT PROBLEM
Most times I replace the coil assy. on gas control valve. OR could be the sensor.Or both.
Nov 27, 2007 | Kenmore 73952 Gas Dryer
Model 11060052991 kenmore elite dryer
For heat issue I had replaced the heat relay switch a year ago and that worked. For the start button holding issue I replaced the motor relay switch and the dryer is fine again.
Nov 25, 2007 | Kenmore 63942 Dryer
Dryers Logo
116 people viewed this question
Top Dryers Experts
Marvin
Marvin
