Question about Texas Instruments TI-84 Plus Calculator
My calculator won't install to my pc - Texas Instruments TI-84 Plus Calculator
  • Texas Instru... Master
  • 7,993 Answers
From education.ti.com download the TI connect software. Install it on your computer. Then run TIconnect software and connect you calculator with the USB cable or the TI SilverLink cable. In the main window of TIConnect click the TI DeviceInfo button. The software will communicate with the calculator to retrieve its info. It this communication is succesfull you will be able to install apps, capture the calculator screen, etc.
Hope it helps.
Posted on Oct 04, 2009
How can i install in my Nokia 2690 phone a calculator without Restore a phone with the help of Nokia PC Suite
download calculator jar file connct yo phone and make sure its detected on the pc suite.then just double click on the file and walla: its installed to the phone
Mar 03, 2014 | Nokia 2690 Cell Phone
Casio hr100tm won't print, shows E, won't feed paper. It calculates in On mode only.
mi sumadora, de repente se queda en E y no me deja seguir sumando cantidades que solucion tiene esto
Aug 22, 2012 | Casio HR-100TMPlus Calculator
Trying to download apps but it won't register the fact that my calculator is connected
Use the TI USB Silver cable or a standard USB to Mini USB. The calculator shipped with one or both cables.
Before it can be recognized you must install the drivers. Download TI connect and install it on the computer before connecting the calculator. If you use the Graph link (black cable) you need to have a serial port on the computer.
COM3 is serial communication port. On newer computers (laptops) that port is no longer available.
Feb 03, 2012 | Texas Instruments TI-84 Plus Calculator
It takes too much time to turn on
Is the screen off during this time? it might be the batteries Try buying new batteries. I recommend you rechargeable batteries. If it doesn't work try installing the latest firmware from hp.com/calculators
Dec 26, 2011 | HP 50g Graphic Calculator
Our t84 won't hold any battery life. we have changed both the lithium and the tripl a's and you can only use the calculator one and then its out of battery......what is going on?
Possibility: Some third-Party programs (games essentially) are installed on the calculator. They may be ill-designed and circumvent/turn OFF the Power saving features of the calcuator.Also, Texas Instruments recommends to use alkaline (non-rechargeable) batteries only.
Sep 16, 2011 | Texas Instruments TI-84 Plus Silver...
Won;t power up at all. New batteries but I did not replace back up battery. should I? Tried the contrast fix. Son said he dropped it and it got kicked down hall at school. One year old. Any hope?
If new batteries did not solve the problem, the next thing to check would be the battery terminal.
If the battery terminal is rusty, the battery power won't contact and the calculator won't turn on. So, use a flat small screw drive to scratch the battery terminal so that there would be contact.
If the above is not the problem, the next to check would be the wire connecting the battery terminal to the the calculator's main board. There is a wire between the battery terminal and the calculator board. When the battery is inserted, the power from the battery goes from the terminal to the board through this wire. There is a possibility that this wire is cut in-between or is loosing contact. In this case, you need to get a small screw driver and carefully disassemble the calculator in order to check the wire.
If the wire is intact, use a light brush to brush the calculator board as there might be dust on the board.
If non of the above helps, then it means the calculator is dead and needs a replacement.
Regards.
Sep 13, 2011 | Texas Instruments TI-84 Plus Calculator
I put in fresh batteries but the calculator won't turn on.
Regards.
Sep 13, 2011 | Texas Instruments TI-83 Plus Calculator
My student's ti nspire won't turn on. They have the 84 face plate on it.
Put in new batteries and try again.
Regards.
Sep 12, 2011 | Texas Instruments TI-Nspire Graphic...
"ON" button doesn't work; calculator won't
In most cases this cannot be economically repaired... the cost to repair would be more then the calculator is worth...
heatman101
Jun 18, 2011 | HP 48gx Calculator
How do i set my danon dk100i for use on PC
This calculator is plug & play. No drivers are required for installation.
You just connect it to your Windows laptop or PC with the supplied USB cable and the required drivers will be automatically installed.
After the installation is complete, you can use the calculator as an external numeric keypad.
After you connect and install the drivers, opennotepad or calculator application and use the connected DK100i's keypad to input numbers.
If you did not receive the USB cable with the calculator, contact your dealer.
Nov 07, 2009 | Canon DK100I Calculator
Texas Instruments TI-84 Plus Calculator Logo
111 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
