Question about Zenith Z27A11G 27" TV
Need list of codes for bell expressview 5900 and 3200 for zenith tv
0 characters
1 Points
Remote code for zenith model H27D35DT
0392,0399. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Mar 30, 2014 | Zenith Standard (CRT) Televisions
Hello, I have a Zenith Concierge model number
Codes to check with Zenith brand TVs are: 0287,0281,0288,0285. Try these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy In case of service manual, I've it with me, but cannot upload it by this window as it is in PDF.
In case of service manual, I've it with my system library, but cannot upload here by this window, as it is in PDF.
Nov 02, 2013 | Zenith C27A24T 27" TV
Program code for zenith reciever z712b
Universal remote setup codes for Zenith TV are:
0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
Jul 07, 2012 | Zenith B27A11Z 27" TV
Need remote code for zenith tv model c13a02d
remote code don't go by model, you get a list of codes and you just try them one at a time until one works, here are the most up to date remote codes for a Zenith are the three digit codes
101, 142, 149, 177, 241, 345.
remember all universal remotes have code search, so if none of these seem to work do the code search function, it is outlined in the user manual of your remote.
Jan 28, 2010 | Zenith C13A02D 13" TV
My Zenith C32V28 television does not display the top and bottom of the picture. I phoned Zenith tech support who told me that it was the satellite signal. I called the satellite provider who advised me it...
This is applicable to Bell Television Services (Canada)
I solved the problem myself after two calls to both Zenith and Bell Television satellite service. On the bottom left of the Bell remote control there is a * (STAR BUTTON). Press this * button and within two seconds you must press the channel change button up or down. This will do two things. One; it changes the channel; and also changes the ratio of the satellite signal. There are three satellite signal ratio settings. Try this when you are tuned to a TV channel such as BNN (Canada) (Business News) or The American channel which has a stock ticker usually displayed along the bottom of the TV screen. Select the ratio (setting) that allows the stock ticker to be displayed......hope this helps.........Jim McP
Nov 10, 2009 | Zenith C32V28 32" TV
Need code to program Zenith remote control
Try these codes for your remote and TV. The are the Zenith codes for a Curtis Mathes TV.
CURTIS MATHES.....002 103
............................. 112 502 506
..................... 512 601 701 704
These should work.
May 09, 2009 | Curtis-Mathis CM25011 25" TV
Zenith sms1324s doesn't exist on universal remote codes pages
You can buy a suggested substitute (original no longer available) here:
Zenith substitute remote
I wish someone would bring a suit against any of these manufacturers using the term 'universal.'
At best, they are 'multibrand' and, with the proliferation of 'brands,' there never will be one that can rightfully claim to be 'universal.'
Dec 09, 2008 | Zenith C27A24T 27" TV
Need a code for my tv zenith
Zenith Product Codes
TV Mode Zenith Code 101 - VCR Mode Zenith Code 201 - Cable
Mode Zenith Code 353 - AUX Mode Zenith Code 401.
Programming Codes---
TV - 101 149 175
Apr 27, 2008 | Zenith B27A11Z 27" TV
Zenith Concierge H25W35DT 27"
The CORRECT answer is you must purchase a LP702 remote. Google it to find one to buy. You must unlock channels and program the channels fresh.
Some standard zenith remotes allow you to reset the tv by popping off the cover of the remote and pressing an unmarked button.
Mar 09, 2008 | Zenith C27A24T 27" TV
Standard (CRT) Televisions Logo
254 people viewed this question
Top Zenith Standard (CRT) Televisions Experts
matt martin
matt martin
Anastasio Benjou
Are you a Zenith Standard (CRT) Television Expert? Answer questions, earn points and help others
