Question about Canon PowerShot SD600 Digital Camera
Camera/Battery not working after 13 months and only takes 15 pictures
My camera only takes 15 pictures before I have to take the battery out and shake it, wipe the terminals off, bang the camera,...then I get another 15 pictures and have to do the saem thing. I took the camera to a good shop and they said the battery is fine. Camera is 13 month old and out of warrenty.
  • 36 Answers
Get yourself a cheap non-Canon battery from eBay and see if that takes care of the issue.
Posted on Dec 27, 2007
This Tamron used with my Canon 1000D gives since 3 months errorcode 01 (communicationfailure between lens and body). When "off" and "on" can take one picture, then errorcode 01...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 05, 2011 | Tamron 18-200mm f/3.5-6.3 for Nikon
Im tommy from nigeria,i use hp camera cb350 but it's a battery killer.i use energizer 2500mph rechargeable.after charging the maximum shots it takes is between 5 to 10,where as some of my friends takes...
Hi, Below are the tips to you : Digital camera use high current to make it works. Your 2 units battery 2500 mAh are normally worth for your camera. Your battery will get its full capacity after charged for 13-15 hours from designated charger ( I supposed you to use energizer charger).In your camera set your flasher to auto mode. This will save the power rather than use the flasher manually / all time. If after fully charged the battery and you still get the same performance. You may have wear down battery and need replacement. New battery required 24 hours charging before use at first time. Now install your new batteries. If you still get same problem, you've got problem with your camera internally.
Dec 04, 2010 | HP CB350 Digital Camera
After taking 2 pictures with my camera, it shut off
Yeah your correct there might be a problem also in the battery., are you using the battery came form the box of your camera? or using the recommnded battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001 If yes you may call kodak toll free 1 800 235 6325, It means that your camera needs of service
Nov 01, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera won't power on.
That's what it would do if the battery had no charge. Batteries can only be recharges so many times. Pick up a replacement battery. If that doesn't solve it, at least you'll have a spare battery.
Sep 22, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
OMG!!! If you still have the camera, try this. I read in one of these forums to spray a burst of brake cleaner in there and blow dry for a few seconds and believe it or not, it worked! That's after me taking it apart to make sure the connectors weren't loose, using the pencil eraser and banging it. I am not making this up. It was my last resort and it worked. Good luck!
Dec 31, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
I bought mine 2 1/2 yrs ago too. Found this solution on this site and tried it. It worked perfectly.
Turn to TV mode, set the exposure to 15 seconds by pushing the little "arrow dial" until you have 15"
Push the button to take the picture.
Wait 7 seconds from when you push the button, then turn over and open the battery door while it is "taking the picture."
Close the battery door and turn back on.
I did this three times and the last time, it worked and the iris became unstuck.
Then I took a million pictures to get the iris moving.
Jul 11, 2008 | Canon PowerShot S2 IS Digital Camera
Black lcd screen when switch on
i had the same problem and couldn't find an anser anywhere, so i just hit it.
seems to work fine now :)
Jul 11, 2008 | Canon PowerShot S1 IS Digital Camera
Battery Problem
If you have used this camera more than three months Try changing the battery. Before using fully charge the battery. Let the battery consumed in your camera fully then you charge again. Otherwise the battery life will reduce. Try this option before trying any other option.
Best Regards
Mar 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Camera not working
Make sure the batteries aren't dead or inserted backwards.
Nov 04, 2007 | Samsung NV10 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
50 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
