Question about GE GSL25JFPBS Side by Side Refrigerator
I need to know what bulbs I need fo rthe GE
I need to know what bulbs I need for the GE GSL25JFPD refrigerator I need. I can't seem to find the manual. Need to replace freezer and water dispenser bulbs please.
    President:
  • GE Master
  • 1,922 Answers
Main bulb is ge part # AP2006861 and is a 60 watt common light bulb/the dispenser bulb is a g.e. part # of AP3884244 and you should be able to get these at a grocery store or ace hardware
Posted on Oct 04, 2009
What bulb is required for Lemair Rd-320ff fridge. Know its a 10watt but need type?
  • Lemair is made by G.E. So even though any 10 watt appliance bulb would work for your refrigerator I found one from G.E. for their refrigerators http://www.galesburgelectric.com/GE-10S11NF-120V-10W-Incandescent-Appliance-Bulb.html
  • You can order that one or pick any 10 watt appliance bulb from your local hardware store. They should just be frosted for added life and durance in the cold elements inside your refrigerator.
  • Thanks for using FixYa
Regards, Tony
Jun 22, 2011 | Refrigerators
1995 mitsubishi mirage: i need the timing belt marks, the valves clearance,, firin order and wich one is the piston Number one, thanks o
Click on the following direct Link for the Timing Belt Marks:
http://www.2carpros.com/car_repair_information/year/1995/make/mitsubishi/model/mirage/1995_mitsubishi_mirage_timing_belt_diagram_marks.htm
Click on the following direct Link for the Firing Order/#1 Piston Diagram for the 1.5L Engine:
http://autorepair.about.com/library/firing_orders/bl-fo-6825.htm
Click on the following direct Link fo rthe Firing Order/#1 Piston Diagram for the 1.8L Engine:
http://autorepair.about.com/library/firing_orders/bl-fo-6826.htm
Let me know what size Engine: 1.5L or 1.8L for the Valve Clearance information.
Mar 23, 2010 | 1995 Mitsubishi Mirage
Our GSL25JFPD BS unit was installed 7/5/04 and in early 2009, we experienced water dispenser failure due to water line freeze-up, according to service technician. The freeze-ups resumed in February, 2010...
I found that when I used the crushed ice option, the lines would freeze up. Cubes were ok. Take everything out, including the ice, and turn it off for about 12 hours. Then check to see if it works again. If not, wait a little longer to let it fully defrost. If it still does not work after 24 hours, then you might need service.
Don't use crushed ice function.
Feb 26, 2010 | GE Refrigerators
Can I replace the LED light in my refrigerator?
I am not aware of any special tools or proceedues require to replace a LED light bulb, however,...... LED bulbs are generally very long life bulbs (read est. 10 year life, minimum). There is at least one manufacturer which has had some issues with their LED bulbs, and it is possible that GE may have outsourced some manufacturing, so we can not rule out a bad LED, however, it is actually more likely that you have a problem with the board or a switch, in which case the service tech will have to find out why your LED is not lighting.
Oct 16, 2009 | GE PFS22SBSSS Stainless Steel French Door...
GE GTS20ICNCC Refrigerator light bulb burns out quickly
Use the correct wattage bulbs. If they fail often then you may need to get it checked by an electrician.
Filament bulbs easily burn out. What you can do is to buy cheap bulbs and replace as soon as they burn. This is the problem which is why tube lights and LEDs were invented!
Sep 07, 2009 | GE Refrigerators
Water dispenser not working
This water line does not run through the freezer. You have a switch in the door where you get water that activates the water valve in the back of the Ref.
One or both of these are bad and needs to be replaced.
Dec 21, 2008 | Refrigerators
GE Refrigerator
If you have heating in the freshfood side there is only one possible. The light inside is staying on and allowing the bulb to heat up the refrigerator. To fix this you will need to replaced the door switch. To check simply unscrew the light bulbs and see if the problem goes away, or open the door and push on the door switch and see if the light is going off. Please let me know if this is not the problem and I will be happy to help. Please let me know if this did FixYa.
Mike
Sep 07, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Fridge not cooloing right
HI I'M HAVING THE SAME PROBLEM THAT YOU ARE...I NOTICED THAT THE FRIDGE DOOR WAS OUT OF LINE WITH THE FREEZER DOOR AT THE TOP...IF THE FRIDGE WAS EMPTY IT WORKED FINE, BUT WHEN WE REFILLED IT,IT WOULD STOP COOLING AGAIN,I THINK IT'S GOT TO DO WITH THE WEIGHT ON THE DOOR MAKING THE DIFFERENCE IN MY CASE...I BELIEVE IT HAS SOMETHING TO DO WITH THE SWITCH AT THE TOP, INSIDE THE FRIDGE THAT OPERATES THE LIGHT AND THE TEMP CONTROL IN MY CASE.TRY OPENING THE DOOR JUST A LITTLE SO THAT YOU CAN SEE IF THE SWITCH IS BEING FULLY CLOSED...I THINK I'M GOING TO HAVE TO ADJUST MY FRIDGE DOOR UP TO GET IT TO DO THIS FOR ME...WILL LET YOU KNOW IF THIS WORKS!!!!!
Sep 09, 2007 | GE GSL25JFPBS Side by Side Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
310 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
