Question about Cooktops
Want to vent gas cooktop from top of ceiling cabinet down to basement and out chimmney. Distance is approximately 20 feet with four 90 degree angles. Suggestions? Thank you.
  • 1 more comment
  • mikridd Oct 04, 2009
    venting the steam and cooking odors.
    venting steam and cooking odors.
  • Danny Clark
    Danny Clark May 11, 2010
    Are you talking about the range hood venting the steam from cooking or the gas exhaust flue?
  • 156 Answers
There are special fans that are used for this. Use the web to look up exhaust fans. Normally used for boilers, tumble dryers where the distance required to run is further than the fan supplied with the item can push it. The fan will need to be wired in so that the gas cannot be turned on until the fan is running. Pick the fan that best matches flue diameter, temp, and distance
Posted on Oct 04, 2009
Testimonial: "Thank you. A secondary exhaust fan is a thought."
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    How far away do I need to sit my GE induction cook top back from the front of the cabinet?
    Try to centre it so you have an equal distance both front and back that way il has clearance and also looks better than being out of kilter.
    Ray
    Apr 22, 2014 | General Electric PHP900DMBB GE Profile 30"...
    My DGSU100-4BSS-LP Gas Cooktop spaks but does not ignite
    Check for LP leak. You also have to wait for air locks to vent out through burners to get lite the first time.
    Jul 29, 2012 | Viking 31 in. DGSU100-4BSS-LP Gas Cooktop
    High-pitched squeal/whistle noise from range
    Noise went away by itself. No root cause found. Please remove this posting, thanks.
    Dec 04, 2009 | Maytag MGC6430 Gas Cooktop
    One of 4 burners doesn't spark/light -- GE JGP979 Cook Top
    I am going to assume you hear the "clicking" sound when you try to light the burner.
    open the top of the stove. there are four burner. look at the one that is not lighting. use a straighten paper clip open the holes that is directly in-front of the tube that is facing the center of ignitor.
    also make sure that the air vent directly behind the knob is fully open.
    Mar 30, 2009 | GE 30 in. Profile JGP979 Gas Cooktop
    Hello posted this question but family getting antsy without a cooktop. I am installing a 36 inch GE Profile gas cooktop, jgp970, along with a Frigidaire downdraft vent, pl36DD. The gas inlet pipe on the...
    the reason for the fitting instruction for the regulator to be connected directly is that flex hoses deteriorate and allow a dangerous situation
    AS gas is not in the diy domain I recommend that you get in an accredited gas fitter who will make a solid pipe to allow the fitment of the regulator away from the motor
    While he is there he can adjust the regulator to get it all working correctly
    Mar 13, 2017 | GE 36 in.JGP970 Gas Cooktop
    Thermador Vent Gas Cooktop Model GGCV36 Serial # 89020071
    Just google the repair clinic and partselect,they are selling spare parts online..
    Hope this may help;
    Regards,
    VOTIT
    DON'T FORGET TO RATE:
    Aug 21, 2008 | Thermador SGS36GS Gas Cooktop
    Jenn-Air 8130 installation problem
    Rotate the blower to the proper angle
    needed for your installation. The blower
    can be swiveled 90°. To rotate the blower:
    a) Remove the filter from the blower housing
    b) Loosen, but do not remove, the nuts
    around blower inlet.
    c) Rotate the blower housing for the
    proper angle.
    d) Retighten the four nuts and install the
    filter.
    try this its general for this type of cooktop
    Mar 30, 2008 | Cooktops
    Cooktop burner problem
    Your plumber should know that the pipe service your cooker must be of a suitable size. Normal half inch pipe is only good for a couple of small burners. Most installations require one inch! There is a simple formulae for working out the flow rate of the gas. Your gas installer will know it.
    Apr 18, 2017 | Cooktops
    Gas cooktop vent code
    planning to install a 30" stovetop natural gas.need to know if i need a vent to the outside, it has 4 burners
    Nov 07, 2007 | Cooktops
    Cooktops Logo
    75 people viewed this question
    Top Cooktops Experts
    Paul Carew
    Are you a Cooktop Expert? Answer questions, earn points and help others
