Not scanning from solution centre and it shows communication problem ,connection:: usb
  • Mujahid498 May 11, 2010
    Hi Please getback with below information as to provide solution to the problem the information you provided in sufficient. Printer Model name Operating System Connectivity to computer Yours Roger
I cant get my 4650 to scan it keeps saying downloading application list but it never does anything
If you are scanning documents to edit or save as PDF file, you will need to install the OCR scan software on your computer. The Lexmark OCR scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center to request for one.
If scanning from your printer to your computer was working previously, then it could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected) > reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to scan again once the computer fully recognizes the USB connection (if USB connected). If printer is connected wireless, wait until the WiFi light on the printer turns on solid green before trying to scan a document.
Dec 28, 2011 | Lexmark X4650 InkJet Printer
Do i need software like ocr so that the lexmark x6650 scanner can work
If you are scanning documents for editing or saving them as PDF, you will need to install the OCR scan software. The Lexmark OCR scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center to request for one.
If your scanner was working before, it could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to scan a document again to verify that the problem is fixed.
Nov 02, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Product scans but then I can't find the result
The first thing I recommend you try is a new data cable. Scanners require bi-directional communication and will fail even when the printer works. Similarly go for a direct connection instead of using a print server or USB hub. (I have a scanner that had the same problem - the preview scan started but no image saved due to a bad cable.) If you are using a parallel port connection, make sure that bi-directional communication is set for the port (in the BIOS). If you use a USB to parallel port adapter, make sure it is a bi-directional (for scanner) adapter.
I hope this helps.
Jul 24, 2010 | Brother DCP 115C All-In-One InkJet Printer
How do I scan a document with my Centre pro and
You have to scan it usually a twain program. Do a search on twain program. You have to be connected to the scanner with the usb cable.
Nov 09, 2009 | Xerox Office Equipment & Supplies
I using a HP officejet 4255 all in one printer. but two days back printer LAN does not communicate with system(Erroe shows :diagonestic error) ,any solution for rectifiying the probelem
This printer do not have LAN / Ethernet.
This printer is connected via USB cable.
Try to change the USB cable and / or clean the USB connector contacts by alcohol or suitable cleaner.
If the problem persist, contact nearest service centre.
Jun 08, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Scanning Problems
Solution This issue can be caused by the way the USB chips in the product and the USB chips in the computer interact, or it could be caused by an old version of the HP software and driver. First, make sure that the most recent version of the HP software and driver is installed on the computer, and then try testing the USB devices and ports on the computer. If the product still does not scan correctly, a powered USB hub might help resolve the USB communication issue. Follow these steps to test the USB connection and see if a hub is necessary. Step one: Make sure that you have the most recent version of the HP software and driver The HP software CD that shipped with the product frequently does not contain the most recent version of the software and drivers. To make sure that the software is the most recent version, download and install the most recent version of the software from the HP Web site. The software and driver downloads available from the HP Web site include a Basic Driver option and a Full Feature Software and Driver option. The basic driver is sufficient to perform basic printing functions with the product. The Full Feature option installs extra software to allow full use of all features available with the product. The Full Feature option also allows custom installation. Follow these steps to download the software from the HP Web site and install it on the computer.
  1. Click here to go to the HP Software Download Page .
  2. In the Enter a product number text box, type the product model name (for example, HP Photosmart C3180), and then click Submit (c01425574.gif ) or press Enter .
  3. Under Product search results , select the product model name from the list that appears on the computer.
  4. Select the operating system that is installed on the computer. The Select Software and Drivers page appears.
  5. If the Automatically check to see if you have the latest software and drivers link appears at the top of the page, click the link and then follow the on-screen instructions to check the software and driver version and update the software if necessary. If the Automatically check to see if you have the latest software and drivers link does not appear at the top of the page, continue with step 6.
  6. In the Driver section, review the list of available driver downloads, and then click the appropriate package.
  7. Click Download Only and then follow the on-screen instructions to download the software.
  8. To install the software, double-click the icon for the downloaded file and then follow the on-screen instructions to complete the installation. CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 3 m (10 feet) long.If any firewall messages appear during installation, click Unblock or Accept or the installation fails.If the User Account Control screen opens, click Allow to continue.
Step two: Test the USB connection
  1. Disconnect all USB devices, such as printers, scanners, speakers, and cameras, from the computer except the mouse and keyboard.
  2. Connect the USB cord from the HP product to a USB port on the computer that is known to work correctly. Test the connectivity related functionality of the device (for instance: scan to file.)
  3. Print a self-test page from the product. NOTE: For information about how to print a self-test page, see the user guide for the product.
  4. Test the standalone functionality of the product by using the product control panel to scan a document or an image. NOTE: For information about how to use the product control panel to scan, see the user guide for the product.
  5. If the scan from the control panel works correctly, connect one USB device at a time to the computer and test the product by scanning from the control panel after each device is connected.
  6. If the product scans correctly from the control panel after every other USB device is connected, the USB connections are working, and you have resolved the issue. If the product does not scan correctly from the control panel or does not establish communication with the computer after a USB device is connected, the computer might not have enough power to run multiple USB devices. A powered USB hub might help establish or maintain communication between the computer and the product. Go to Step three: Use a USB hub.
Step three: Use a USB hub A powered USB hub might allow all the USB devices to receive enough power to run correctly and it might resolve USB communication issues between the product and the computer. Follow these guidelines when choosing and setting up a powered USB hub.
  • Make sure that the USB hub is a powered hub and the power adapter is included. Some powered hubs do not include the power adapter as a standard item.
  • When setting up the hub, it must be plugged into a power source.
  • Some hubs cannot handle more than four full-power USB devices, such as the HP product. To connect more than four full-power USB devices, use more than one powered USB hub. Most Windows computers can support a maximum of five USB hubs.
  • If there are multiple USB hubs connected to each other or if there are more than four USB devices connected to the hub, the issue might persist. Move the HP product to the hub that is directly connected to the computer USB port.
Workaround If these steps did not resolve the issue and purchasing a powered USB hub is not possible, the issue might be resolved by turning off the Preview option in the HP scanning software. NOTE: This workaround does not resolve problems scanning from the control panel. Follow these steps to turn off the Preview option.
  1. Click Start , click All Programs , click HP , and then click HP Solution Center . The HP Solution Center window appears.
  2. In HP Solution Center, click Settings and then select Button Settings .
  3. Clear the check box next to Show preview when scanning from the Scan Picture button and then click OK .
  4. Quit HP Solution Center and then try scanning again.
May 05, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Can't scan
This sort of thing can be down to the fact the settings for communication to the printer is separate for printing/faxing/scanning. So you will need to find the scanning device (will usually be called HP3050 regardless, or something along the lines of that) and make sure it's set to communicate through USB and no other means.
Sep 07, 2007 | HP LaserJet 3050 All-In-One Printer
20 people viewed this question
k24674
