Question about JVC HX-D7 Shelf System
When attempting to turn on power, 'status protect' message is displayed, then power turns off. No solutions found in manual
    Problem Solver:
  • 5 Answers
It doesn't really power off, it's allways on and has an overheating issue even when it's "off" that you can troubleshoot by actually unplugging it for a few hours, it takes quite awhile to cool down. If it starts then (maybe even just a little while) then you have to cool it down inside. I removed the system main fan ($10) and put a bigger one (need to drill a few new holes) and turned it so it blew cool air into the circut area and heatsink for the amps, which is where the overheating is happening mostly, drill a bunch of holes in the upper part of the casing for proper ventilation. After messing with my system for months this was the trick never had a problem again. The error code my have a number of different problems that set it off though so this is just what worked for me.
Posted on Nov 03, 2009
D7160
error 0xc05d1281 mean the ink system failure
try blow reset Solutions
Solution 1:
  • Press and hold the "*" key.
  • Press the "#" key and release both keys.
  • Display should say "Enter Special Key Combo"
  • Press and release in sequence the "1", "2" and "3" buttons.
  • Screen says "support" R0631M
  • Press and release the right arrow button until the display says "System Configuration Menu".
  • Press and release the "OK" button.
  • Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
  • Display should say "Hardware failure status: Clear. Press OK to clear".
  • Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
  • Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. DO NOT TRY TO PRINT AT THIS STAGE.
  • Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
  • Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
  • Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE".
  • Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Solution 2:
  • Press * and # at the same time
  • Press 1, 2, 3 and "support R0632M" should display
  • Press > and "information menu" should display
  • Press > and "configuration menu" should display
  • Press OK and "hardware failure status" should display
  • Press OK "failure status: clear". Press OK to clear
  • Press CANCEL
  • Press CANCEL
  • Press CANCEL
  • Turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
  • If the error came back, do the sequence again and the error will be replaced with the usual print cartridge initialization screens. Print a test page to make sure.
Solution 3 (thanks to a1224imac):
  • This same error started occurring on my printer and eventually it would constantly poweron and off.
  • Apparently some defective components were used in the construction of the logic board (see photo).
  • On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer).
  • I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents).
  • On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662.
  • If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers.
Jul 22, 2014 | HP Photosmart D7160 InkJet Printer
"PROTECT" message in display.
two cables of a speaker were touching each other.
this may be the problem
Dec 29, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
I'm getting an error messege on a hp photosmart C7180 all in one 0xc18a0106. please help me. I've tried un and reinstalling the software. New ink cartriges. Nothing works.
Solution 1:
  • Push "OK", "Cancel", "Black" and "Color" all at once while turning the printer off.
  • Turn it back on.
  • One more time: push "OK", "Cancel", "Black" and "Color" all at once while turning the printer off.
  • Turn it back on.
Solution 2: Resetting the product:
  • Without turning off the product, disconnect the USB cable from the rear of the product.
  • Remove the cartridges from the product.
  • Wait for the "Insert Cartridges" message on the control panel.
  • Disconnect the power cord from the back of the product.
  • Wait 60 seconds.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Reinsert the cartridges, and then close any open doors on the product.
  • If you receive a prompt to print a calibration page, do so.
  • Reconnect the USB cable to the rear of the product, and then try printing again.
Solution 3:
  • 1. Get the unit into the "Support Menu" by following these steps: Press and hold the "*" key. Press the "#" key and release both keys. Display should say "Enter Special Key Combo". Press and release in sequence the "1", "2" and "3" buttons. Display should say "Support"
  • 2. Press and release the right arrow button until the display says "System Configuration Menu".
  • 3. Press and release the "OK" button.
  • 4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
  • 5. Press and release the "OK" button.
  • 6. Display should say "Hardware failure status: Clear. Press OK to clear".
  • 7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
  • 8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. DO NOT TRY TO PRINT AT THIS STAGE.
  • 9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
  • 10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
  • 11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
  • 12. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
  • 13. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
  • 14. If the error is still there, or reoccurs replace the unit.
Feb 24, 2011 | Office Equipment & Supplies
Code 0xc18a0201 problem comes up. What do I do?
I found this solution for a C5180 Ink System Failure....and assumed/hoped the firmware was the same....it worked!!
Press and hold the "left arrow" key.
Press the "Setup" key and release both keys.
1. Press and release the right arrow button until the display says "System Configuration Menu".
2. Press and release the "OK" button.
3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
4. Press and release the "OK" button.
5. Display should say "Hardware failure status: Clear. Press OK to clear".
6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
7. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use.
NOTE: If the error is still there, or reoccurs replace the unit.
Please dont forget to rate me.....Thanks.....
Feb 04, 2011 | Office Equipment & Supplies
Receiving error message: 0xc18a0001 error message on hp c8180 all-in-one printer. what can I do?
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If I've helped you, please vote! Thanks!
Dec 09, 2010 | HP Photosmart C8180 All-in-One InkJet...
My printer model is Hp C5383 all-in-one & the printer is flashing the message "ink system failure Oxc19a0023" on the screen. What can I do? Pls help me.
You may try this step to to fix this problem
Solution 1
  • Turn the unit off,.
  • Unplug the power cord and wait 30 seconds before reconnecting the power.
  • Turn on the printer
Solution 2:
  • Press and hold "left arrow" key
  • Press the "setup" key and release both keys
  • Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
  • Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Do not print at this stage.
  • Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
  • If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
  • To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
  • If the error is still there, or reoccurs the printer is already defective.
Solution 3:
  • Press the On button to turn the printer off.
  • Unplug the power cord from the back of the printer.
  • Remove all the ink cartridges.
  • Wait two minutes.
  • Plug the power cord into the back of the printer.
  • Press the On button to turn the printer on.
  • Install the ink cartridges when prompted.
Solution 4:
  • Wait for the 'Insert Cartridges ' message to display on the control panel.
  • Wait 60 seconds.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
Nov 12, 2010 | HP Photosmart C6380 All-In-One InkJet...
Error : Oxc 18a0206
here.. check this out. a solution to your problem.
These are reset instructions designed to clear most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to proceed..After this try to print...
If you find the reset solutions helpful...Please rate this solution and vote YES ..thanks..
Jul 30, 2010 | HP Photosmart 3210 Printer
Photosmart 7360-ink Ink System Failure error
1) Press * and # at the same time
2) Press 1, 2, 3 and “support R0632M” should display
3) Press > and “information menu” should display
4) Press > and “configuration menu” should display
5) Press OK and “hardware failure status” should display
6) Press OK “failure status: clear”. Press OK to clear
7) Press CANCEL
8) Press CANCEL
9) Press CANCEL
10) Turn printer off, unplug power cord for 2 minutes, and plug cord back in then turn printer back on.
And Thanks.
Mar 11, 2010 | Office Equipment & Supplies
Protect
The protect message indicates that a problem was found in the output stage of the amplifier. Unless this gets repaired, nothing will work. As a verification that the speakers or the wires are not the problem, unplug all of the speakers and try again. If protect still is displayed, the problem is inside the unit.
Dan
Apr 09, 2008 | Sony DAV-S400 System
JVC HX-D7 Shelf System Logo
413 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
