Question about Samsung Instinct Cell Phone
Not responding to touch screen
I have tryed every thing the side buttons work the calls come in but cant answer..
What is wrong?
Outside or returning for warranty repairs or replacement, you can try powering off unit and disconnect power battery connection and reconnecting.
Apr 28, 2014 | Cell Phones
Hello, My samsung tocco ultra touch screen is frozen. It wont respond. Also the call button and the return button(the centre one) dosent function. I tries almost all options like switching off-on,...
Hello.
It could be a software problem (but you can't connect by USB cable) or a hardware problem. Unfortunately without proper tools you can't fix either. You just have to take it to a Samsung service.
Regards, Achil
Mar 09, 2011 | Samsung Tocco Ultra Cell Phone
Most of my ds lite touch screen is not responding
try getting to the calibration menu with the buttons and calibrate if u can if not send it in to nintendo for repairs
Sep 21, 2009 | Nintendo DS Lite Console
My iphone wont respond to touch i cant use it
try hard reset (hold down the power button and the central button until you see Apple logo on screen). If this wont help then use RESTORE.
Aug 25, 2009 | Apple iPhone 3G Black Smartphone
My LG Viewty phone has been frozen for 4 days. The only thing I can do is answer calls and make calls to numbers in my call register. Everything seems to still work perfectly, exept for the screen. I've...
My LG KU990 viewty screen has frozen....meaning...the touch screen doesn't respond when I press it.
I can answer the phone and only call numbers i've already.
Does anyone know how I can fix this
I stupidly did not get it insured
I've turned it off and left it off for some time, taken the sim card out, but this doesn't help. Does anyone have a solution?
Aug 17, 2009 | LG KU990 Viewty
My touch screen is unresponsive [LG glimmer]
I have this all the time: 1. Inbox/ sent msgs are 2 full - so delete msgs 2. remove the battery out & clean sim card 3. If that doesnt work get a new simcard 4. if else fails- get a new phone
Jul 13, 2009 | HTC Touch Cellular Phone
My iphone wont respond to my touch in the bottem halk
Have you tried doing a hard shut down? Hold the silver button down on the upper right corner and also the home button (center,bottom indented button) together for about 10 seconds. the phone will completly shut off. then wait about 10 seconds and hold down the upper right hand button until the apple appears on the phone then release the button and wait (20-30seconds) . Doing this usually solves all my issues with my iphone when it gets locked up like this.
Jul 01, 2009 | Apple iPhone 3G Black Smartphone
The touch screen does not appear to be working
needs to be replaced , if it does not respond to ur taps have u tried aligning the screen does it work at all or no area is responsive on screen then u can try hard resetting it first but after that it will be guaranteed that ur touch panel is faulty which seems like to me
but one thing u shud now do all data will be lost in factory reset process and if ur touch panel is faulty u will stuck up in initial aligning process so pls backup first b4 going ahead sync contacts and sms calender an stuff then try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if u are stuck at align process then it is now pretty sure that ur TOUCH PANEL / also called DIGITIZER is faulty u can get it replaced around 60 $ or so
pls rate me fixya for my diagnosis if u like
Mar 05, 2009 | HTC Touch P3450 Smartphone
HTC Touch - Screen & touch flo problem
i did all things described to get the screen workin,pressed the red n green buttons simultaneously n with the friggin stylus i pressed the reset button underneath, pulled the battery out a coupla million timesn put it in, but it jus doesnt unlock, the touchscreen aint workin, i can call, mssag or do anything except recieve calls, Arpan
Nov 12, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Samsung Instinct Cell Phone Logo
218 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
