Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
How do I get the handtool to work on my Hoover Steamvac carpet cleaner?
    Scholar:
  • 190 Answers
Please reference page 11-12 on this manual:
http://www.hoover.com/pdfs/manuals/F6039900.pdf
The tools are plugged on to the end of the hose, and the hose supplies water and vacuum to the tool.
Posted on Oct 05, 2009
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
How can I get power switch to work on hoover spinscrub steam carpet cleaner?
Replace the switch.
http://www.ereplacementparts.com/hoover-f5914900-steamvac-with-clean-surge-parts-c-37315_37419_37425.html
Aug 28, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover carpet cleaner dual 5
Try this site for more information on this problem
It may just need a good clean out.
http://hoover.com/support/manuals/?q=SteamVac
Feb 05, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover carpet cleaner won't dispense solution or water. Everything else works.
1.Remove bottom tank and look for pinched hose. 2.Use small screwdriver or toothpick on small holes which disperse solution-remove rotating brush first. These were problems with my steamvac (f5861-900 model).
Mar 16, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover deep cleaner brush won't work
If the vacuum cleaner comes on but the brush will not spin, try replacing the belt and clean each end of the brush from lint , string, carpet materials.
Oct 06, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
My Hoover SteamVac carpet cleaner leaks water
i have a hoover carpet cleaner and when it is not in motion it leaks water
May 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Hoover SteamVac isn't extracting solution from carpet. Motor runs and the brushes weren't turning at first but do now
That vacuum is fine on liquid extraction but often gets clogged by debris when it hits a solid. It would be better to do the clean with the steamvac then follow it with a wet/dry shop vac to be sure you got all the water. I say this because the vac built into that hoover is way too easy to clog.
Mar 13, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=624426
Posted by providence51 on May 26, 2008
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Leaking Hoover Steamvac
Either you have a crack in the tank and it is running down the indise of the handle and going out the bottom, or there is a water line off either under where the tank sits or under the top cover.
Mar 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steamvac F5892-900 leaving lines on carpet, does not seem to spray
Is the cleaner sucking up the water like it should? If not , check that the filter on the inside of the lid has a 1/4 in. gap between the filter and the top of the lid. Either that or the water isn't completely being shut off when you release the trigger, in whcih case you would probably have to take it in for service.
Jan 31, 2008 | Hoover F5892-900 SteamVac Upright Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
263 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
