Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Needle breaking-CE 250
When I attempt to embroider the needle will often hit the presser foot attachment...I have taken off the presser foot and put it back on multiple times, but the needle continues to sew right at the back of the presser foot's square--should it be in the middle?? I have finished only one embroidery design and have gone throught 5 needles........HELP PLEASE!!
  • 2 more comments
  • asanderson21 Jul 12, 2008
    This happens with mine too! Mine hits even if it's not threaded and I can't see an adjusting screw that would be any help! Do I need to send it back? have a repair technician take a look? any other ideas??
  • Anonymous Mar 25, 2014
    needle keeps hitting the presser footer
    needle keeps hitting the presser footer, for some reason it is not in the centre
  • Anonymous Mar 27, 2014
    want to ease pressure foot to sew but dont see where
I had that same problem and it was due to the thread being too tight. Put the thread net on your thread and it should be ok.
Posted on Dec 25, 2007
Needle breaking while embroidering
Could be tension is too tight. But there are also several other possibilities, ie something is not in alignment, so the needle is hitting the presser foot, needle plate, the needle is deflecting off the fabric. You might also try a different needle brand or type (ie, embroidery, top stitch, etc.)
Nov 13, 2016 | Sewing Machines
Why do needles keep breaking?
Just guessing here. Is the needle hitting the presser foot? If so, it could be the wrong presser foot for your machine (especially if it is not attaching properly), could be the wrong needle for the machine or is installed incorrectly, could be the needle bar is not centered, or the needle position setting could be off to one side or the other rather than in the middle. Hard to diagnose without more information.
Apr 15, 2016 | Sewing Machines
How can I attach a zipper foot to my unidentified machine?
Assuming you have the correct zipper foot attachment for your machine, you should be able to attach it like any other presser foot. On some machines, you may need to adjust the needle position to the right or left so the needle will not hit the presser foot when stitching.
Feb 10, 2016 | Sewing Machines
Singer futura xl400 embroidery needle keeps breaking
The problem is being caused because the thickness of the material is not allowing the embroidery foot to land squarely on the fabric. The needle is then close to the back of the foot, and when a jump stitch is encountered, the needle hits the back of the foot and breaks. We used to suggest that people take a small wad of something and stick it under the presser foot lifter to raise it a little--not enough to trigger the sensor, but enough to raise the foot. However, that\'s difficult to do and keep in place on an XL machine.
However, a much better solution is to simply switch to a darning foot. Both can be used for embroidery, but the darning foot is spring loaded and starts out flat. Plus, it\'s much easier to get on, and much easier to get past the rim of the hoop when you\'re putting the hoop on.
One comes with your machine, but if it didn\'t, I have purchased several from eBay. They are VERY inexpensive, and my personal preference is one with a closed large round metal ring at the bottom. All Futuras, including yours, take a low-shank foot. They are very used by many machines and therefore very commonly available. I think you\'ll be very pleased with the results!
Apr 11, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
Needle hitting pressor foot
Presser foot not correctly mounted, or needle bent, or needle bar loose or bent are the most likely.
Mar 18, 2014 | Kenmore Sewing Machines
I have a Toyota expert ESP 850 embroidery machine. While embroidering, the presser foot will become loose and the needle will then hit it and break. I've gone through three needles and I don't want...
Change the needle socket holder, See www.datastitch.com for new needle socket holder.
We also buy toyoa machines used in any condition
larry@datastitch.com
Jul 01, 2012 | Sewing Machines
Bernina Artista 640 - While embroidering, the sewing needle hit a pin and broke. Now that I have replaced the needle, the alignment is off. The needle point comes down onto the embroidery presser foot.
This will probably need to be handled by a professional. With this particular Bernina, you might be able to adjust the needle position so that it is slightly off center and will not hit the presser foot. That would be a temporary fix, however. If you want to be able to thoroughly enjoy your sewing time, you will be happier if you take it to a certified Bernina repair site and let them adjust the needle position.
Nov 11, 2010 | Bernina Sewing Machines
When I turn my machine on the presser foot does
This does not sound good, you may have a failure in the eletronics. However it could be a loose connection inside the machine too. I think you need to see a service tech.
May 24, 2010 | Husqvarna Designer I
The needle constantly breaks while embroidering. I tried every type of needle with no difference. It goes ok for a few seconds till the needle goes down and hits the foot and breaks. I do have on the...
Sounds like your tension is too tight and the thread is pulling your needle. Also, make your that you needle position button is on center. If it is on left or right it will cause your needle to snap.
Apr 19, 2009 | Singer CE-200 Quantum Futura Computerized...
How to put on presser foot "p" to embroider
Not shure you can embroider on an MC4000, i think this is only a sewingmachine.
But to change presser fot:
If it a "snap on" foot, when foot lifted, press the "button" on the back of the needle bar (on the bottom) this would release the presser foot.
If is a large foot, you have to unscrew the screw on the left side of the needlebar, and change the whole foot.
Jun 21, 2007 | Janome Memory Craft 4000 Sewing Machine
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
368 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
