Question about Canon iRC3100 Printer
I have an error on my canon irc3100. the error code is E000014-0001
  • hornedp Oct 04, 2009
    Thanks for your responce. Have found the problem adn it was the two rollers in the fuser unit that have fallen appart causing the rollers to jam.
    Thanks very helpful now it just cost $$$
    President:
  • 1,462 Answers
This error is mainly due to the following reasons:
The fixing motor has faulty rotation.
• The main motor (M2) may be faulty.
• The DC controller PCB may be faulty.
• The image processor PCB may be faulty.
This error is idicating that the fuser motor is not turning. Rotate the green fuser knob to see if it is hard to turn. If freely turning then a gear, motor, or DC Controller board is bad. If hard to turn then try to find what is keeping it from turning. The motor Assy is behind the cover right next to the fuser knob.
check composite power supply, main motor and dc control
This error cannot be resetted, you should change the worn component
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Posted on Oct 04, 2009
Canon ir 5870 c showing the error code E000003 - 00051
Canon IR 5870c showing the error code E000061-0003 please tell me how to remove error E000061-0003
Apr 24, 2013 | Canon iRC3100 Printer
Canon ir 3100 error code e000070-0001
the error code appears when a tension arm (front or rear) of the ITB tension roller is broken.check the tension arms (front and rear) for breakage. If either of the arms is broken, replace it with a new one.
May 03, 2011 | Canon iRC3100 Printer
the error code appeared because a tension arm (front or rear) of the ITB tension roller was broken. check the tension arms (front and rear) for breakage. If either of the arms is broken, replace it with a new one.
Canon iR 3100 Problem Error Code E 20081
HELOW SIR UR PROBLAM E 20081 IT IS A RONG CODE?SO U WILL WRITE THE CURRECT CODE SUPPOSE EXAMPLE E021-0001
Nov 12, 2010 | Canon iRC3100 Printer
Canon iR 3100CN Error code E000732-0001
E732 Reader communication error
0001 DDI-S communication error Check on connection between the reader controller PCB and the main controller PCB, Check on the
reader power supply
Hope that helped!
Jul 25, 2010 | Canon iRC3100 Printer
Irc3100 with error code e000013-0000 help please
That means that you have ITB waste toner full error. Clean the waste toner container.
It is located behind front door, right from toner slots, you need screwdriver to unscrew one screw, and remove plastic cover above waste toner container.
When you vacume or dump waste toner, wash it very well, and dry it.
Jun 15, 2010 | Canon iRC3100 Printer
Intermediate Transfer Belt on a Canon IRC3100
Your going to have to pull off the waste toner bottle, delivery cover (buffer or internal finisher), the right swinging door, fixing unit, cleaning blade, heat shield, move the fuser drive gears. Then you have one screw on the transfer belt assy that sit behind the cleaning blade and one on the front next to the screw that hold the cleaning assy on. Then 4 screws on the side by the fuser. One connector and the whole thing should come out
Mar 10, 2009 | Canon iRC3100 Printer
Canon IRC3100 colour copier machine error code
Canon iRC-3100 Color Copier is giving Error code E-000021-0001. can anybody help me?
Aug 01, 2008 | Office Equipment & Supplies
Canon iRC3100 Printer Logo
181 people viewed this question
old marine
old marine
