Question about HEALTHRIDER Exercise & Fitness
I have HealthRider model HRTL71830. Was using it for about 3 years. A few days ago I moved it a bit and afterwards the console stopped responding. I'm not really sure if that's the cause of the problem or something else. When I turn the power on the console comes up as usual (with zeros), but does not respond to any of the buttons. Only Stop button makes a beep. I've checked the magnetic Reed Switch, double checked the connections and they seem to be okay.
    Habit-Forming:
  • 138 Answers
Unfortunately, you need to replace the entire console. HealthRider's consoles are notorious for this behavior. The company that manufactures them only sells the console as a whole unit so you can get individual parts. Depending on the age of the machine you'll be looking at between $300-$800.
Posted on Jun 18, 2017
5 Suggested Answers
SOURCE: Proform 730i powers on but will not move when I input speed.
I have the same treadmill with the same problem statement. Here is how I fixed it:....Open the lower shroud that covers the motor. You must remove 4 or 5 screws. Taped to the inside of the shroud should be a document with a calibration procedure on one side and electrical specifications on the other. It will tell you how to run the calibrations. You need to hold the stop button and the + speed button as you insert the safety key. This will put you into calibration mode. My treadmill started working again after I ran the incline calibration routine. Hope this helps.
Posted on Oct 31, 2009
mnwarfield10
  • 452 Answers
SOURCE: My treadmill comes on, but the control panel is
you req a new pcb (control board) look up your model number on google for spares .
Posted on Feb 26, 2011
  • 1196 Answers
SOURCE: My healthrider h120t turns on
I will suggest you try reset it, Press POWER to turn off the treadmill, At the same time, press and hold the +, -, and POWER keys. Continue holding all keys until their is nothing on the screen display. Release the keys. insert the key properly and see what happens.
Posted on Mar 19, 2011
  • 3 Answers
SOURCE: i have a nordic track
All, just figured something out. I had the evil beeping problem as well. I decided to play around and see if I could fix it. I unplugged the iFit adapter from the main control board and when I plugged it back in and tested it, IT WORKS AGAIN! NO MORE BEEPING!
Posted on Oct 29, 2011
No video signal
Check the prongs to see if any were bent in the move so the cord is no longer connecting.
Jan 01, 2018 | The Video Game Consoles & Games
Why won't myHealthrider Treadmill console lights up, but belt won't run?
There is something wrong with the panel connection to the belt. Get the panel looked at or buy another treadmill. Everything is made to last a short amount of time these days.
Aug 19, 2014 | HEALTHRIDER Exercise & Fitness
I have a Healthrider R65, engine works wellbut when I step on it skips and stops for afew seconds my husband adjusted belt on each side but is till not going smoothly please adviceI bought from my fri
1) Lube the deck belt, this produce enough friction between deck vs deck belt, and shut down for to protect the electronic system
2) lube the rollers bearing very well.
3) Test the drive belt and replace
4) Test the motor input voltage, if there are the motor need repair.
5) test the output voltage board, for input voltage motor, if there are not the board is faulty.
God bless you
May 11, 2012 | HEALTHRIDER R65 Treadmill
I need help with my ps2, its about 4 years old, The bulky model. up until a few days ago, it worked perfectly. yesterday it was a bit glitchy, but a few resets fixed it. Today i wanted to play it, so i...
clean the laser using a lazer disc cleaner not only does the disck get dirty but the lazer too when its too dirty it wont read the disc -- disc error
heres a piture of one you get them from electronics shops
Dec 31, 2010 | Sony PlayStation 2 (PS2) Console
I have a Healthrider S500i Model #HRTL12991 treadmill. On the console pad the start and stop button quit working. Most of the other buttons still work. Icalled the manufacturer and they tryed to talk me...
Unfortunately the only way to repair this is to replace the actual console. (pad and console are all one unit) The other issue is that I do not believe the console is even available for this product unless you purchase it from a third party.
iconservice.com is the official parts site for healthrider and the console is not listed as available for this model.
Hope this helps, Tim
Nov 24, 2009 | Exercise & Fitness
Exercise & Fitness Logo
174 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Shehu Pro
Shehu Pro
mburke3
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
