Question about Sloan M-101526-F Flushmate?® Complete Replacement System for 501-B Series
Problem with flushmate m-101526-fnoe enough water
Problem with flushmate m-101526-f not enough water to flush toilet , how do I correct problem?
  • 119 Answers
Did you replace the cylinder cartridge?
Posted on Dec 08, 2009
I have a sloan toilet model M-101526/ it leaks out of top of tank when i flush it
Depending on the nature and source of the leak, it may be a maintenance issue or you may need to replace a component or the complete system.
You can find troubleshooting procedures, owner's manuals, etc., at www.flushmate.com.
For best results, jot down the serial number and toll-free phone number located on the Flushmate label and call Flushmate between 8:00 AM and 4:30 PM ET (Mon - Fri) for assistance.
Mar 18, 2013 | Sloan M-101526-F Flushmate?® Complete...
Hissing sound after flushing a flushmate
The washer that shuts the water off is failing. It shut stop incoming water completely when the tank is full.
Jan 11, 2013 | Sloan M-101526-F Flushmate?® Complete...
My flushmate toilet got clogged. I have unstopped the clog, but it won't flush. The flushing process works, but the water isn't pushed down the drain.
My flushmate toilet was stopped up after a bm.
Because I could not get to it right away, I let it
sit for several days. Tried calling the Flushmate
800 number. They don\'t work on weekends and
it was Saturday. What to do? Read the info on
the internet but could not find solution. However
first I shut off intake water valve required for any service
performed. Did that. Got a large plastic spoon.
Fashioned a container out of supermarket paper
bag cut in half. Used bottom half and inserted it
inside double Safeway plastic bags. Scooped out
the toilet paper and feces into bag. Found most
of feces had disintegrated in the toilet coloring
water dark brown. That was a good sign. Less
solid matter to flush. Tossed bag into garbage.
Flushed the toilet and it worked perfectly. This
method works for stopped toilet only. If problem
is in the sewer line, you need another method.
Oct 19, 2011 | Sloan M-101526-F42 Flushmate?® Complete...
Flushmate 503 sprays water out of top of tank, apparently coming for under the flushmate system. The valve doesn't seem to leak. Iahve pressure tested it.
Turn off the water supply at the wall, flush the toilet to relieve the pressure inside the Flushmate, and call Flushmate Consumer Services at 800-533-3460 M-F, 8:00 - 4:30 ET.
They'll need to know the serial number and approximate date of installation of the Flushmate.
You could alos fill out a confidential "contact" form on the contact page of the Web site, www.flushmate.com.
If yu need to use the toilet in the meantime, you can "bucket flush" it by pouring 2 to 3 gallons of water into the bowl. This will generate a standard siphonic flush and won't give you the pressureized extractiopn but it will keep the toilet usable until a Flushmate support tech can diagnose the issue and provide a resolution.
Aug 17, 2011 | Sloan M-101526-F31 Flushmate?® Complete...
Just hooked up new pressure asist tank & bowl,turned on water to it,and it want flush.what i mean about want flush, is it will flush but water does'nt go down,as if it's not staying open long enough.
Sounds like you have a clogged drainline or vent-stack. Fill a large bucket with about three gallons of water and dump it quickly into the bowl. If the drainline/vent is clear, the toilet will "flush" like a gravity toilet and the water will drain from the bowl almost as fast as you can pour it in.
If the water level in the bowl slowly rises (as if it's about to overflow) and then slowly drains, you have a clog somewhere.
All toilets, regardless of their flushing mechanism, require a clear, unoibstructed drain/waste/vent system to extract waste.
If the toilet "flushes" with the bucket of water, you may want to call Flushmate tech support (the number is on top of the tank) or check out the installation and troubleshooting videos at howto.flushmate.com.
Hope this helps.
Aug 18, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
We have 4 flushmates & one of them does not shutoff after flush'g & fills up our septic tank ----how do i ajust it to stop
there is no adjustments for the flush mate. only adjustment is for the handle. if your flushmate is not shutting off after flushing, you need to replace the flush valve.
Aug 09, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
I have a flushmate that is about 3 yrs old and occasionally, after a flush the water will continue to run.
the float-plunger may get stuck or there is something small in the wtaer tanks that gets lodged every so often
Jan 07, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
How do i repair an automatic toilet flushing valve ?
It really depends on the nature and cause of the problem. You can view helpful videos at howto.flushmate.com or download owner's manuals at flushmate.com.
Hope this helps.
Aug 26, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
My sloan flushmate toil I think is backiing up. When I take the lid off and flush the toilet water shoots out the front side of the flushmate. What could the problem be or is it broken.
You may have a leak in the discharge extension, lower supply, or drain valve. I suggest you call Flushmate's tech support line (on the Flushmate label) and see if they can help you out.
Good luck
Apr 14, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
Sloan M-101526-F Flushmate?® Complete Replacement System for 501-B Series Logo
597 people viewed this question
Top Sloan Home Experts
richochet
ray gallant
Ted Maxwell
Are you a Sloan Home Expert? Answer questions, earn points and help others
