Question about Cambridge Audio Azur 640A Amplifier
My line 6 amp
Ok chek this u know the cord u pop in the inpute the tip came off it and is stuck down in there i took it apart just to find out that it has a plastic end so i cant just put somethin tew the other end and nothing that i have is small enuff to get down in there and grab it so wtf do i do
    Problem Solver:
  • 14 Answers
Us a hot pin do not
Posted on Dec 22, 2007
Power and opc bottom blinking, tv won't come on
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Jan 08, 2016 | Sharp Televison & Video
I tried pull the cord stuck took it apart spring ok.the shaft from engine stuck,
Sounds like you have a bearing failure, eithe big end or crank shaft bearing. When they go they quite often knacker the piston and cylinder too as it can put them off square. Remove cylinder and the problem will be easy to locate as you can see the big/small end bearings and check for cylinder damage. Often the cost of repair far outweighs the value of the equipment.
Apr 07, 2013 | Husqvarna 128 LD Weedeater
I turn on the amp (Behringer Ultrabass BHX1800) and there is a large popping sound but then I have no sound output from either the jack inputs or the composite stereo inputs! before I take it apart, does...
I suggest you look for a new amp. My husband has had these apart and parts are almost impossible to find. One part took over 6 months to get.
That said you can look at the Jacks... they break a lot.
Jul 27, 2012 | Behringer Ultrabass Bx1800 Bass Amp W/...
My line 6 lowdown 750 keeps cutting out when i play a low b on my bass
Protective circuits kicking in. You may be overdriving the preamp to a clipping condition the amp sees as a problem. If it is under warranty, contact Line 6 and see if this is normal for this amp. It should not be, but you never can be sure.
Apr 26, 2012 | Line 6 Music
Hi, I have an RBX 374 and I cannot get any sound from it. I have got the wiring scheme but the wiring looks O.K. Some say it might be the pre-amp. Does anyone know what could be the problem...
i dont' see where this model has active pickups (guessing this is what you mean by pre-ampped).
The issue can be in a few places.
1) the strings could be too far from the pickups and the instrument needs to be tuned.
2) the pickups are bad
3) your jack is bad
4) the cable is bad
5) your equilizers are not corrected
6) your volume control is turned down or damaged
7) your amp is damaged
this is a small list of the basic possibilities.
Mar 29, 2011 | Yamaha Rbx374 4String Electric Bass Guitar
I have Mackie mixer cfx12 all the channels work except for channels 2 & 3, I turn the pre amp trim pot all the way up but no input is present, I also tried solo PFL for these two channels and no...
I suspect one of the upfront IC amps has been damaged. This can happen if people power the mixer from a receptacle that is different from where other connected equipment is powered such as amp. For example, mixer is at one end of the hall and other inouts such as an output of a guitar amp is plugged in. If a ground fault or spike occurs, teh ground bounce can exceed the common mode voltage of the input amps.
In your case, the inpout amps are discrete transistor types.
A voltage surge into the inputs of your unit would LIKELY pop two bypass caps that are 330pf. For channel 2 these are C205 and C206. Check those for shorts.
VERIFY audio is available at the "send" (tip) of the channel insert connector... this verifies the preamp stage. You can PROBABLY plug a set of headphones in to check this... ONLY one side will have sound of course. Verify this is a good test by checking a working channel. The level will be quite low and we are looking for just some signal.
IF you do have signal on the channel insert send which is the "tip" of the channel insert with the trim turned up, let me know and I will check the schematic for the next thing to check farther down the line.
Sep 15, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Took apart fuel lines as part of repair and did not label them, need schematics or other means of knowing how to properly reconnect the lines, please help
can ya chek w/the dealer, but what would it matter which line went where, go by longest to shortest all get same fuel
Aug 04, 2009 | 1994 Suzuki GSX 600 F (Katana)
Line 6 Spider 2x12 100w combo - Input jack issue
Its a 1/4" mono Panel-Mount Audio Jack
and can be bought at
Radio Shack, Best Buy, Any Music Store
Click Here
Average price about $3.00
Mar 10, 2009 | Music
Plugged in recently purchased, refurbished, ibm infoprint 1567n printer, within the first minute the cord started smoking, employee yanked cord from machine, cord was breaking down and melting. There was a...
The source of your refurbished printer either did not refurbish it completely or failed to test operation before turning it over to you. From your description, it may have been delivered wired for the wrong input voltage.
Mar 24, 2017 | IBM Infoprint 1567n Laser Printer
LG KG 800 slide
it is a pain to open these. 1. remove the battery & undo the 4 black screws. LG use a thread locking compound (loctite) on all the screws so they will be a **** to undo. 2.Prise the back cover off. 3. Pop apart the 2 rectangular connectors at the top of the keypad circuit board. 4. Lift the top board slightly & pop apart the ribbon/flex cable from the top board. The big silver bit comes off with the flex cable. There is a small bit of adhesive on this so be gentle. 5. undo the 6 silver screws holding the slide mechanism together & lift the slide off over the flex cable. 6. pop the 2 screw covers off the top of the phone then undo the 6 screws holding the front cover on. 7. pop the flex cable off. then the touch pad connector. then the camera lens connector. Gently pull the screen circuit board out of the front cover. Careful as sometimes the speaker is glued in place. 8. Unclip the lcd connector & gently remove the small battery looking thing (it's got red & blue wires on it) from the back of the lcd panel. It's glued on. Have fun. It took me ages to work this out.
Aug 05, 2007 | LG KG800 Cellular Phone
Cambridge Audio Azur 640A Amplifier Logo
55 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
