Question about InFocus ScreenPlay 4805 Multimedia Projector
Lamp won't come on
I've a 2-year old SP4805 that I use sparingly. The last time I used it was a couple of months ago when I had hooked a computer to it. Since then the lamp would not come on when the unit is turned on. There is/was no indication of lamp failure (I've probably 300 hours of usage). I got a new lamp unit from InFocus and that did not make any difference. I tried troubleshooting the unit with InFocus' tech support who now thinks the lamp unit is probably ok.
Any helpful suggestion would be greatly appreciated.
  • 5 more comments
  • lewnic Dec 22, 2007
    I have the same problem. No indicator light (green or red) -- no lamp light. Everything on the inside is clean and in good repair. Cannot figure this out. Attempted to turn the unit on one day and NOTHING !!
  • fixme07 Dec 31, 2007
    Unlike lewinc, my unit would turn on and the LED indicator would stay green, just that the lamp wouldn't come on. Thus, the power supply wasn't the problem in my unit.
  • Sully100 Jan 16, 2008
    I have the exact same problem. Powers up, green light, but no lamp. Also, I can hear a very faint cyclic noise that sound that repeats itself every 2 seconds.
  • pruitt68 Feb 08, 2008
    I too am having the same problem. I push the power button, I get a flashing green light for a minute or so. Sounds like the projector is trying to turn on, but never does. The light then turns to a flashing red light. Has anyone had any luck fixing this? Not sure if it's the bulb, it has been very recently replaced. Thanks for any help.
  • eXprOg Feb 13, 2008
    I too have been having the same issue. Once powered on, I get the solid green light for a couple of second, then it starts flashing (green). Trying to troubleshoot, I removed the lamp and noticed that the color wheel spins every few seconds, witch explains the faint sound coming out of the unit everyone else is describing. The unit was only used for about 3 months (bought refurbished). I was thinking that the lamp might have burned out. It would suck to buy a $400 bulb to find out that the issue is something else.
    Any help/suggestions would be greatly appreciated.
  • John Purser Feb 14, 2008
    Hello, I am having the same problem. I took the lamp out, vacuumed the dust protector (one side was almost covered in dust), placed it back in and started up, but I still get the green light, and the fan cycles on and off every 15 seconds or so. Last time that I checked the hours, I had only used about 70. I always use the low power mode. This can't be a lamp problem yet, can it? There is no way I can buy new lamp, if it is not going to last very long :(
    Any solutions yet??
    -John
  • kcbean Jun 13, 2008
    I've been through the "have power but no lamp" issue twice now with my 4805. The first time, the light tunnel and the color wheel were both diagnosed to be bad by infocus, then after having my projector for almost 6 weeks, they inform me (after I finally call them to find out what's going on) that they've lost my projector. I got a refurb from them that's now having the exact same issue. I'm hesitant to replace the bulb given that symptomatically, it's likely something else. There are no auth'd repair dealers for the 4805, you have to send it to Kentucky. Hope y'all saved your boxes.
It could possibly be that the access door to the lamp is not completely shut. If you just hear the color wheel turing and no fans is definitely could be that as it was with mine. The little plastic piece on my door that presses the switch to let the projector know the the door is shut broke off on mine and I had to glue it back on.
Posted on May 12, 2008
As in Solution 3 even though the plastic piece on my door hadn't broken off it was not depressing the switch enough.When I pushed the door lightly the lamp lit and the fan began.Just ensure the switch is pushed in and you should be all right!!
Posted on Feb 15, 2010
I overcome this problem by removing the bulb then replacing it every time I want to watch a film. It works on mine. Rather irritating but i soon forget when the movie starts.
Posted on Apr 24, 2008
I dont want to be inappropriate, but would you consider selling one of your lamps now that you have 2? Thanks
Posted on Jan 30, 2008
It's attempting to strike the lamp, it will keep doing this for 5 times after this the led would turn to red and flashing. If it is doing this the chances are that the lamp is faulty and needs to be replaced.
Posted on Jan 16, 2008
Assuming that the power outlet and cable are OK (and is switched on, lol), then the most likely cause is the power supply.
Posted on Dec 30, 2007
Batteries failing
one would certainly think the batteries are replaceable .
Mar 19, 2015 | Panasonic Lands Phones
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
After fixing a ballast lamp and color wheel how long would a tv last?
I have the same telly for the last six years and i only changed the lamp two weeks ago i think there a very good telly
Jan 20, 2013 | Samsung SP50L6HX 50" DLP HDTV
Toshiba 52hm95 lamp breaks after only weeks of use
It is as far as the set is concerned, it sees the lamp not on.
Most likely cause would be the lamp ballast that drives the lamp.
Dec 20, 2012 | Toshiba 52HM95 52" HDTV Projection...
My camera will not charge. It was purchased just short of a year ago, so here is no reason for the battery to be broken. It will not charge at all when the memory card is inserted and when it is, the...
Hi, It almost sounds like the battery won't hold a charge anymore which means you need a new battery. Since the camera isn't quite a year old yet I'd suggest contacting Nikon and seeing if they'll do anything for you before you buy a new battery.
May 12, 2011 | Nikon Coolpix S4000 Digital Camera
Hi, I'm having a problem with my new dryer. We got this dryer about a year ago and for some reason in the last couple months, almost every 2 weeks the fuze blows. The dryer turns on but it doesn't...
Makecertain that your wiring is not exposed to anything. Be sure to turn the power off to the dryerand check the outlet. Also check to seeif your dryer cord is connected to the dryer right. Usually the outer prongs on the dryer are thehot and in the inner one is the ground.
May 11, 2011 | Dryers
The picture on my 13 yr old panasonic PT-51G44 ia darkening. Is this fixable or do I need a new tv?
Yes,the tv is fixable.When was the tv projection lamp been inside this tv was replaced in this tv,when was it the last time the bulb was replaced?The last time the probjection lamp was replaced about 1 1/2 or 2 years ago?The tv on an used at leat 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Aug 02, 2010 | Panasonic PT-51G44 51" Rear Projection...
Unable to switch off projector with remote (Infocus SP4805)
A bit unusual for the projector to stop responding to the remote. Usually it follows when someone has opened the projector, they forgot to reconnect the controls from the case top which also includes the IR receiver. If it isn't that, it could be a broken IR pc board or bad connection. I've seen that.
The worst case is that the IR controller on the main board has failed and if that's the case, you'll have to live with it as the cost of a new board is very high.
Mar 13, 2008 | InFocus ScreenPlay 4805 Multimedia...
Samsung HL-R5067W "Powering Down"
the hlr series had a few problem with intermittent turning off. one was the lamp door cover switch, the other was the thermostat.. neither one is very costly and a good tech should be able to replace bothe parts at the same time..
Nov 26, 2007 | Televison & Video
InFocus ScreenPlay 4805 Multimedia Projector Logo
654 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
